Ps CS4 Printer Dialog Changes
2008-11-15 by kingdex3434
I'm Mac, Intel, 10.5.5
Is anyone grappling with the fact that in CS4 it is not possible to select "No Color
Management" when printing grayscale files? And, even though "No Color Management" is
available when printing RGB files it is not possible to print "black & white" RGB files to ABW if
"No Color Management" is selected. It seems that the only time "No Color Management" is
available is printing an RGB file and selecting the "Color" print mode in the basic printer
settings box and using any of the color mode drop down choices including "Off - No color
management"
A practical problem I'm having as a result is making grayscale, ABW profiles for my Epson
printers (9800/7800):
Typically I'd use an untagged, grayscale target image to make a black & white profile (for
ABW, not QTR) and then select "No Color Management" and then print using ABW. Since
Photoshop CS4 won't allow me to chose "No Color Management" with a grayscale file I'm left
with only two choices: "Printer Manages Color" or "Photoshop Manages Color." Intuitively
neither choice seems a good one but, since letting Photoshop manage color is the wrong
choice, it seems letting the printer manage color wins by default.
kd
Re: [Digital BW] Ps CS4 Printer Dialog Changes
2008-11-15 by amadou diallo
In 10.5 Apple has pulled back support for "No CM" so your best bet for
profiling targets is to use Printer Manages color and then make sure
the print driver is set to CM off. When set to Printer manages color,
PS just passes along embedded profile and rendering intent info. PS
does no conversion on its own, it just makes profile and rendering
intent info available to the print driver. Whether the driver receives
that info correctly and/or knows what to do with it depends on the
particular print driver. But for most current drivers Printer Manages
color should provide identical results as No CM; with the appropriate
driver settings.
> "No Color
> Management" is
> Management" is
> the basic printer
> "Off - No color
> management"
> for my Epson
> white profile (for
> ABW. Since
> file I'm left
> Intuitively
> the wrong
> Regards
> kd
amadou diallo
Author, Mastering Digital Black and White
www.masteringdigitalbwbook.com
2008-11-16 by kingdex3434
Amadou Diallo
Thought I'd post this here so we can all learn:
One last clarification from your post if you have time. You wrote:
". . . so your best bet for profiling targets is to use Printer Manages color and then make sure
the print driver is set to CM off. . ."
I assume then you do not print using ABW. Just keep print mode to "Color" and "Color Mode"
to NCM. Is this correct?
kingdex
2008-11-16 by amadou diallo
> and "Color Mode"
Correct. For BW I either use a RIP with my 9600 or use the HP Z3100. If you
wanted to print a target using ABW set PS to Printer Manages Color and set
your driver to whatever ABW settings you were trying to profile.
amadou diallo
Re: Ps CS4 Printer Dialog Changes
2008-11-17 by Roy Harrington
This appears to be a strange introduction in CS4 (not Apple as far as I can tell).
It seems that Grayscale files in CS4 do not allow printing with No CM selected on
the Preview page.   This happens with both the Epson driver and QTR driver but
curiously not with the PDF driver and my laser printer driver.
I can see a few ways to get around this:
1) You can select Photoshop Manages Color and select a print profile identical
to the document.  Since its untagged use the Grayscale working space in the
Color Settings..  You'll be getting a CM conversion but since source and dest
are the same no data will actually be changed.
2) Convert the target to RGB and then use it.  The main caveat here though is that
Photoshop uses CM when it changes Mode to RGB.  Even though the original file
is untagged it will be treated as grayscale working space and get converted to
RGB working space.  If they do not have the same internal curve the numbers will
be changed.  The easiest pair to use is GG 2.2 and Adobe RGB.  Set these in
Color Settings... before converting.  Look at the histogram while you convert
to see the before and after.  They should be identical.
-- another way to do this is:  duplicate gray channel getting 3 identical channels,
then Mode > Multichannel and finally Mode > RGB.  This avoids the CM --
Now you can select No CM when printing.
3) The suggestion Printer Manages Color may also work but I don't know for
sure that the OS Colorsync CM wouldn't get in the act too.
4) Finally, a completely different approach is to print the target using Preview
instead of PS/CS4.   This "ought" to do the same thing but testing it would be
necessary.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kingdex3434"
ABW if
is
color
> management"
Epson
left
wrong
> Regards
> kd
2008-11-17 by kingdex3434
Roy,
Here is a bit of additional information I've picked up from a very reliable colleague.
Thought you might like to comment:
The deeper explanation going on here has to do with printing interfaces on OS X changing
over time. In the past, some printer drivers (notably Canon, with its older iPF series
printers) did not interpret the image data appropriately and thus had incorrect driver
settings that could not be reset by the user. Photoshop CS3 worked around some of these
issues for specific drivers, but did not conform to Apple's OS X specifications for how to
pass image data to the print driver, leading to problems elsewhere. With CS4, Adobe has
taken the approach of conforming to Apple's latest print driver interface specifications, so
CS4 now has the same behavior as LR with regards to printing on OS X.
However, many print drivers have not been updated to conform to the OS X printing
interface, and thus some folks are experiencing printing issues, such as double color-
management. This is unfortunate, but it really needs to be addressed by the printer
drivers.
Now, back to the ABW situation: I don't know if Epson has a glitch with the ABW driver
under the latest OS X release. I have occasionally seen what you've seen: i.e., I hit "Print" in
PS CS4 and nothing comes out. But then I mess around a little with the Epson printer
driver configuration and then it works.
In particular, I found that if I had an older "saved setting" or preset within the Epson driver
that I used to recall a particular ABW driver setting, then it would fail. So I deleted all my
Epson driver presets and started again from scratch (manually selecting media type, color
mode, ABW settings, paper config, etc.) Then I haven't had any trouble printing ABW
images since.
kingdex
2008-11-18 by Roy Harrington
I've done some testing of various color management approaches and it is indeed confusing.
Here's what I've deduced using CS3 and CS4 with QTR drivers printing stepwedges.
CS3 with No Color Mgmt I consider the "correct" result.  The driver gets 21 evenly stepped values.
With CS4, only Photoshop Manages Color with Print Profile = Working Gray Space gives
the identical results.  (assuming grayscale, untagged file).
Printer Manages Color makes a default conversion to Generic Gray Profile which is a gamma 1.8
profile.  If you happen to use GG 1.8 as a working space this conversion may not hurt but if
you use GG 2.2 it'll darken the print.   I think this has been true in PS for several versions.
To make things more complicated OS X 10.5 has a new print dialog pane called Color Matching
which allows you to select Colorsync vs driver based mode and ICC profiles.  I don't know
how this will affect things -- I'd leave it alone.
No Color Management is selectable with an RGB file but I just got blank pages with this option.
-- QTR definitely received a blank page from the system.  This is probably related to your
ABW printing not working.
Note that the CS4 documentation specifically states to use No CM for making custom ICC profiles.
I'd be curious if your colleague has any more detailed info about Apple and/or Adobe color
management.   (Does "CS4 now has the same behavior as LR" mean that CS4 broke NoCM so
that it matches LR which lacks the feature?  :) )
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kingdex3434" <kingdex3434@...> wrote:
> Roy,
> drivers.
> images since.
> Regards,
> kingdex
Re: [Digital BW] Re: Ps CS4 Printer Dialog Changes
2008-11-18 by Steve Kale
Sounds like this should be raised in the PS forums where Chris Cox
will pick it up.   (I raised the colour mgt issues of Bridge there and
they picked that up.)
> stepwedges.
> Gray Space gives
> CS4 broke NoCM so
> Roy
> don't know for
> > Roy,
> reliable colleague.
> X.
> the OS X printing
> > drivers.
> with the ABW driver
> the Epson printer
> > images since.
> > Regards,
> > kingdex
2008-11-19 by kingdex3434
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale <stevekale@...> wrote:
I have a thread going in the Adobe Photoshop Mac Forum as well:
http://www.adobeforums.com/webx?13@@.59b7055a
kingdex
2008-11-26 by kingdex3434
A brief update post may be in order here:
The problem of ABW profiling and ABW workflow in CS4 is still unresolved. Specifically,
PSCS4, LR2 and Mac Leopard are all presently having trouble living together. This
manifests in particular when it comes to using ABW profiles for b&w output in LR2 or
PSCS4. In CS4,  profiled printing using "Photoshop Manages Color" and the ABW driver do
not produce expected results. Until this situation is resolved it is recommended that
PSCS3; CS3 ABW profiles and  "Photoshop Manages Color" be used for accurate printing to
the ABW driver.
The situation is maddening since it restricts controlled ABW printing as well as profiling in
LR2 and PSCS4. The situation is being aggressively pursued with "The Big Three" Adobe,
Apple & Epson.
kingdex
2008-11-26 by Carl Schofield
You can add Canon to your list because there are also CM problems
using the Mac iPF Canon drivers with LR2.1 and CS4.  Just look at the
Canon iPF wiki for the gory details.
> together. This
> output in LR2 or
> recommended that
> the ABW driver.
> Big Three" Adobe,
> Apple & Epson.
> Regards,
> kingdex
2008-12-20 by kingdex3434
> The problem of ABW profiling and ABW workflow in CS4 is still unresolved.. . .
Thought I'd chime in here since I started this pesky little thread: Hopefully those here printing b&w
have been following this same thread in the Adobe forums as well (Adobe Product Forums>Adobe
Photoshop>Photoshop Macintosh).
Eric Chan and I have been hammering this topic to death over there. And, Eric has found what seems to
be an air-tight workaround for using ABW profiles and printing accurately in PCSC4 using ABW. This is
how it works:
in CS4:
- Edit -> Convert to Profile. Choose your custom B&W profile. Preview image should look ok.
- Edit -> Assign Profile. Choose Generic RGB. Preview will look bogus. Ignore it.
- Do File -> Print. Choose Printer Manages Colors. Rendering Intent doesn't matter.
- Set ABW driver settings as desired.
I might add on a very important note that, on Eric's recommendation, I'm printing my ABW targets
using PSCS3 and building ABW profiles from those CS3 targets. I use these profiles when printing from
CS4. This is a very important point! And, needless to say, prints are consistent with the soft proofs from
those profiles. Speaking of which, if you soft proof from PSCS4 using the above mentioned profiles,
make all your output adjustments and do your soft proofing BEFORE you do the Convert/Assign
workaround. If you try to adjust your screen image after doing Convert/Assign it will screw up
everything on output!!
Eric's more detailed explanation as to why this works and what we can look forward to insofar as a fix is
concerned can be found on the Adobe. Don't know if this will take you there or not but try it:
http://www.adobeforums.com/webx?13@@.59b7055a/34
Hope this helps. And again, Many thanks to Eric's diligent work.
kingdex
