Thanks for all your help! I finally got a good print using the
inkset as-is, as per your directions. I did a bit more reading and
finally figured it all out. I just wanted to let you know that I
appreciate your responses. This can be confusing for a newbie, and
your guidance was invaluable. Now if I'm successful removing those
damn pizza wheels then I'll be in business....
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
<pr_roark@...> wrote:
> "buck caberney" <brianbarger01@> wrote:
> > After a little research, I've come across some references
to "ICC"
> > online, but still no definite explanation of what it is or how
to
> > create one. It seems like it's a bit techie and complicated,
which
> > leads me to wonder: Woudn't it just be easier to swap out the
> > Eboni cartridge for a PK cartridge when printing on glossy paper?
> You'll get a better black with the UT14 as is than with a PK if
> you're using the Epson driver.
> I have posted some UT14 profiles in a Zip file that is linked to
> main UT14 URL below. See http://www.paulroark.com/BW-Info/1400-
> Profiles.zip There is also a link to a tutorial on how to make the
> ICCs. These tutorial also tell you where to put the ICCs in the
> computer for different OSs. I think the main UT14 paper included
> information on how to load the ICCs in the print preview.
> Paul
> www.PaulRoark.com
> > > > Hello. I'm trying to print on Museo Silver Rag (semi-gloss)
> with
> > the
> > > > UT-14 inkset in an Epson 1400. I'm obviously not doing
> something
> > > > correctly as I keep getting prints that have obviously used
> > black
> > > > (eboni ink) cartridge-
> > > UT14 can definitely print on glossy paper.
> > > See my write-up at http://www.paulroark.com/BW-Info/UT14.pdf
> > > On page 7 I discuss glossy printing. It requires an ICC or
curve
> > > (which is in the ICC) that prints the 100% blacks using the C
and
> M
> > > inks and not the K, which is Eboni MK.
> > > Paul
> > > www.PaulRoark.com
