epson 1400: What clean/purge cart?
2008-11-17 by Matthew Newhook
What cleaning and purge cart do you need for an Epson 1400? I'm ordering the UT14 cart
set from http://www.inksupply.com and want to ensure the heads are cleaning when
switching from the original ink to the UT14 set.
Re: epson 1400: What clean/purge cart?
2008-11-17 by pr_roark
For 1400 cleaning carts, see
http://www.inksupply.com/epson_cartridges.cfm
Scroll down to the 1400 line.  The cleaning carts are just under the
OEM Epson carts.
Thanks! Is it necessary to buy a full set (all 6)?
Regards, Matthew
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote:
> OEM Epson carts.
> Paul
> www.PaulRoark.com
> Paul
> www.PaulRoark.com
Matthew,
I don't really know if it's necessary to buy any.  They are nice to
have around if you should get a bad clog or if you're going to leave
the printer unused for a long period (which is the main way to get a
clog).
Just so I'm clear, I'm going to get the UT14 ink set which I plan on using with the 1400
once the carts that come with the printer are finished. I don't need to use a cleaning cart
when I change from the factory carts to the UT14 carts?
Regards, Matthew
> Matthew,
> clog).
> Paul
> www.PaulRoark.com
> with the 1400 once the carts that come with the printer
I can't say for sure whether cleaning carts are needed, but it's the
safe way to go.
Out of curiousity, I just pulled the Claria carts from my 260 that
were in there only because someone wanted a profile for that setup.
I re-installed the MIS carts.  They were color carts with Eboni, but
the MIS color inks use the same base as the UT inks.  I printed a
purge page and checked the nozzles.  I did, in fact, have one gap.  I
can't tell what caused that, but it's possible there is a slight
incompatibility between the inksets.  So, to be totally safe, you
might want to go ahead and purchase the cleaning carts.
