Soft proofing cold paper
2008-11-17 by pr_roark
Is there a way to have Photoshop show the actual tones that are
recorded in the ICC? In this case the ICC is one made with Create ICC
RGB.
That is, when I use "convert to profile" and that profile is of, for
example, a cold paper the tones that seem to be previewed on the
monitor always set the white point to R,G,B = 255, 255, 255 (Lab 100,
0,0) even though the ICC clearly contains the paper cold paper tone.
Likewise, where the range of, for example, Lab B is -2 to +2, it
appears what shows up in the PS Information palette is a range from 0
to 4.
It looks like the system always adjusts the white point to neutral and
then shows the relative tones.  Is there a way to avoid this?
Re: Soft proofing cold paper
2008-11-17 by Tyler Boley
Paul, not in the conversion preview or normal Photoshop viewing. But
in soft proof, yes. You'll see the paper white check box there...
Tyler
http://www.custom-digital.com/
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
> RGB.
> to 4.
> Thanks,
> Paul
> www.PaulRoark.com
Thanks Tyler.  What I'm trying to do is get people a visual example
of print tones as well as the graphs I publish.  It appears many
don't understand the graphs and are surprised by the print tones
they're getting.  It may be that the soft proofing, then a screen
grab, and finally fine-tuning to match the PS info palette readouts
to the actual spectro values may be what I'll have to do.  (There's
got to be a better way.)  Even when I do that, my calibrated monitor
still doesn't really look like what is on my walls.  I think at the
low Lab A & B values I'm dealing with the print lighting and display
may have too much impact on the final display look to have any
computer monitor be a very good predictor.  Oh well...
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
> Tyler
ICC
> > RGB.
for
100,
tone.
from 0
> > to 4.
neutral and
> > Thanks,
> > Paul
> > www.PaulRoark.com
ah, got it. Try this, convert to your profile, then convert again to
sRGB, assuming they are for web display, or maybe dropped into a pdf,
but use Absolute Colormetric for the rendering intent. That will
accurately put the paper white point and ink black points into the
sRGB space without endpoint correction. Is that more useful?
Perhaps ARGB depending on where and how it will be used...
T
> Paul
> www.PaulRoark.com
> > Tyler
> ICC
> > > RGB.
> for
> 100,
> tone.
> from 0
> > > to 4.
> neutral and
> > > Thanks,
> > > Paul
> > > www.PaulRoark.com
Tyler,
>... Try this, convert to your profile, then convert again to
> sRGB, ... but use Absolute Colormetric for the rendering
> intent. That will accurately put the paper white point
> and ink black points into the sRGB space without endpoint
That almost works.  The 5% patch for some reason gets too light -- only
one Lab L unit darker than the 0% patch.
the continuing and constantly changing but never diminishing mysteries
of color management, there may be no perfect solution.
By the way, I've had this wind up displaying very yellow in some
browsers or apps, for no apparent reason. The massive bulbous brains
on the colorsync list ignored my alerts and went back to who has the
biggest pocket protector, so I don't know what's up there.
The solution, if this happens to you, is first convert to a nice bigs
space (ARGB or whatever) with Absolute Colormetric, the once more to
sRGB with Relative. I know I know, but it worked. Coverting in PReview
worked to, but that's a Mac app.
T
> Tyler,
> Paul
> www.PaulRoark.com
Re: [Digital BW] Re: Soft proofing cold paper
2008-11-18 by Cdtobie
Can't speak for the bulbous brains on the ColorSync list: but an AbCol
conversion, followed by a RelCol return is how you convert to show
your paper white in the final image. So you've got the right process,
Tyler.
C. D. Tobie
WW Product Technology Mngr.
Digital Imaging & Home Theater
DataColor.com
CDTobie@...
> T
>> Tyler,
>> only
>> Paul
>> www.PaulRoark.com
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in
> the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNE
> R” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DA
> MAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE L
> OSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW,
> THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH D
> AMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIG
> ITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTER
> ATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF
> ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) AN
> Y OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2008-11-18 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Cdtobie
<CDTobie@...> wrote:
> Can't speak for the bulbous brains on the ColorSync list...
I know, a noticeable absence of productive threads there for some
time, as well as productive threaders, including you... <G>
Tyler
2008-11-18 by cdtobie
On Nov 17, 2008, at 10:34:30 PM, "Tyler Boley" <tyler@...>
___
Well, there's not much for me to say to gratuitous posts stating how
wonderful the ColorMunki is, by people who should know better, and
probably do know better... those are advertisements, not color
management posts, and I refuse to start a dog fight over them. So
until the list actually starts discussing interesting topics in color
management, I'll spend my time some place productive.
C. David Tobie
WW Product Technology Manager
Datacolor
CDTobie@...
www.datacolor.com/spyder3
