Working with Eboni-6
2008-11-18 by tcoen
I have been working with Eboni-6 for about a month on an Epson 1400.
I
would like to share some observations and hopefully learn some new
ideas for using Eboni-6 from other forum members.
The pdfs written by Paul Roark have been an excellent way to learn
about grayscale inkjet printing, as has searching this forum. So
thank
you Paul and members of this forum.
I have found Eboni-6 to produce extremely smooth prints, with good
blacks and great transitions, especially in the highlights. However,
the color tones available are the biggest weakness to me. Not in the
range of tinting available, but rather the greenish tint I find the
cool inks to
have. All observation are for PremierArt Hot Press, but I have found
them to be generally applicable to other papers I have tried.
The warm inks (K, C and LC) are very nice. Prints made using just
these
three inks (or just K) in QTR are very nice, but too warm for my
tastes.
The cool inks (M, LM and Y), however, have an unpleasant greenish
tint.
I find this basically rules out the possibility of cool-toned prints.
The biggest challenge in using Eboni-6 has been to offset the warmth
of
K, C and LC without allowing the greenish tint to creep in.
I tried printing from Photoshop, using Color Control gamma 2.2, as
per
Paul Roark's suggestion, but found the shadows to have a strong green
cast (the dMax, contrast and sharpness were excellent though). I
spent
many hours tweaking the CMY sliders in the Epson driver, but was
never
able to get an acceptable color tonality from shadows to highlights.
I also tried the QTR profiles provided by Paul Roark in message
#94068,
but these produced extremely bizarre results.
The best method for me has been to use QTR to produce a warm profile
(K, C and LC) and a cool profile (K, M, LM and Y). When printing I
use
the QTR split blending sliders to mix the profiles. Usually about 70%
to 80% warm, with more cool inks in the highlights. For example, the
warm contribution might be [H, M, S] = [65%, 75%, 75%].
I realize the Eboni-6 inkset was probably not intended for split-
toning, but this works quite well for me. I find I can get almost
neutral to pleasantly warm prints. I can post the QTR curves
somewhere
if anyone is interested. I wish I had a spectrometer, in order to
better communicate these issues, but I only have a scanner, which
isn't sensitive enough to these small shifts near neutral.
Have others come up with other methods of using Eboni-6? Also, has
anyone found a paper where the cool inks take on a more bluish tone?
This would be great, because then cooler images could be made.
I have a question about the inks themselves. I have read on this
forum
that carbon pigments are naturally warm. What then makes the cooler
inks cool?
Best regards,
Tyler Coen
Re: Working with Eboni-6
2008-11-18 by pr_roark
> Epson 1400. ...
> However, the color tones available are the biggest weakness
> to me. Not in the range of tinting available, but rather
> the greenish tint I find the cool inks ...
> The warm inks (K, C and LC) are very nice. ...
> greenish  tint.
Are you sure you have Eboni-6?  It's a monotone carbon inkset with no
cool inks.  See http://www.paulroark.com/BW-Info/Eboni-6.pdf
The other 1400 inkset I've been involved with that MIS sells is
UT14.  See http://www.paulroark.com/BW-Info/UT14.pdf
While UT14 does, indeed, have quite warm carbon inks, as well as a
cool ink channel, the warm ones are in the M channel.
So, I'm not really sure what you have in that printer.
2008-11-18 by ebenostby
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
<pr_roark@...> wrote:
> > Epson 1400. ...
> > greenish  tint.
> Paul
> www.PaulRoark.com
It sounds like you got the same inkset I did when I ordered pre-filled
E-6 inks for the 1400. I got warm inks in C and LC, cool inks in M and
LM, K in K, and LLK in Y. As Paul has confirmed, this isn't E-6, nor
is it UT14, so I'm sending it back. I think that MIS has mislabeled or
misfilled some cartridges.
RE: [Digital BW] Re: Working with Eboni-6
2008-11-19 by Gary Wagner
Can someone tell me if when using matte paper will be black be the same
density on UT14 as it is on Eboni-6? I am currently using UT14 with my 1400
and was thinking of trying Eboni-6 if the black would be of a higher
density.
Gary W.
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of pr_roark
Sent: Monday, November 17, 2008 7:46 PM
Subject: [Digital BW] Re: Working with Eboni-6
> Epson 1400. ...
> greenish tint.
2008-11-19 by pr_roark
UT14 and Eboni-6 use the same black -- 100% Eboni.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gary Wagner"
same
my 1400
> density.
> Thanks,
> Gary W.
2008-11-20 by Gary Wagner
Paul,
If they both have the same black will a print made on matte paper with
Eboni-6 look much different than a print made on the same paper with UT14?
Does one give a better tonal range? Why would I want to use Eboni-6 instead
of UT14?
Gary W.
Sent: Wednesday, November 19, 2008 8:04 AM
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "Gary Wagner"
same
my 1400
> density.
> Thanks,
> Gary W.
2008-11-20 by pr_roark
"Gary Wagner" <gcwagner@...> wrote:
> Paul,
> If they both have the same black, will a print made on matte
> paper with Eboni-6 look much different than a print made on
If you use them in Black Only mode, they'll look identical.
> Why would I want to use Eboni-6 instead of UT14?
The Eboni-6 has light ink and, thus, can print more smoothly.
However, the 1400 is very good with black only.
While my 1400 usually does not band with BO, I think having more
channels printing is usually a good thing.  So, if one is not
interested in glossy printing and wants to be able to make really
smooth prints, Eboni-6 makes sense.
I'm actually considering going to a 3-Eb6Y and 3-MK on the 1400 and
just ignoring all the other densities.  The 3-MK 1800 workflow has
been very successful, and the Eb6-Y is the ink I try to use the most
of due to both smoothness and tone.  So, I might just go with a
combination of the proven 3-MK plus best of the Eb6.  Just having 2
inks, yet all 6 positions firing, might be a nice, easy combination.
The ability to use QTR sliders to combine 3-MK and the Eb6-Y gives a
lot of control over tone v. smoothness.
