Hi Paul,
Thanks, but would you recommend flushing before swaping in new carts
with EB-6, or should running a few purging patterns suffice? I'm a
concerned about a possible reaction btwn the two inks that could gum
up the works, but I'd obviously like to avoid having to buy the
cleaning carts if they're not necessary.
Jens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
<pr_roark@...> wrote:
> I don't recommend mixing inksets in a CIS. Use clean, new carts
to try
> a new or different inkset first.
> Paul
> www.PaulRoark.com
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "JensGerbitz"
> <jensgerbitz@> wrote:
> > Hi there,
> > I recently installed a Piezography CIS for the Epson 1400. At
some
> > point I would like to try out the MIS EB-6 inkset as a
comparison; I
> > would probably swap in pre-filled carts before committing to
> > purchasing bulk ink.
> > My question: are there any known chemistry issues when mixing
these
> > two inksets that would require a thourough flushing before
installing
> > the EB-6 inks, or could I simply run purging cycles to get rid
of the
> > Piezography inks?
> > Thanks,
> > Jens
