Some Questions on MIS inks
2008-11-20 by hp9180profile
I am in the UK and I currently have an Epson R1800 and an HP B9180. I
am short of space and want to get rid of the B9180 and make the R1800
work harder for its keep. I would like to use it for color IMK and PK
papers) and BW (again MK and PK papers) by switching inks every now
and again (not too often) between MIS's R1800 color set and an MIS BW
set.
So my questions are:
1. Is there a BW inkset that is compatible with the MIS color R1800
inks and do not react with them to clog the heads?
2. With (1) above in mind, can someone please recommend an ink set
for this printer that will work with papers requiring photo black as
well as with matt papers? I have used QTR in the past with a 2100 so
am happy with that workflow and I do have a Colorvision spectro to
linearise and undertake any other requisite measurements.
2. What is the best way to deliver the inks - use the MIS refill kit
to refill the OEM Epson cartridges or get some refillable cartridges
off Ebay? If the latter, is there a vendor that folk here have
experience with and can recommend? I would prefer not to go down the
CIS route.
3. I know this is a BW group but has anyone here had experience with
the MIS R1800 color inks? In particular I want to get rid of the
bronzing and metmerism of the Epson OEM inks and MIS claim that their
inks are much better in these two regards but at the expense of less
gloss than the OEM inks. Can anyone who has used MIS R1800 color inks
collaborate this claim (or refute it for that matter!)?
All and any assistance very much appreciated!
regards
Alistair Owens
Re: Some Questions on MIS inks
2008-11-20 by pr_roark
Alistair Owens wrote:
> ... have an Epson R1800 ... I would like to use it for
> color MK and PK papers) and BW (again MK and PK papers)
> by switching inks every now and again (not too often)
> between MIS's R1800 color set and an MIS BW set.
> R1800 inks and do not react with them to clog the heads?
The 1800 3-MK setup described at http://www.paulroark.com/BW-
Info/R1800.htm can handle the matte paper, but not the glossy.
Some people use a 3-PKN approach with the 1800.  Those are compatible
with the MIS color inks.  I found the PKN approach a little rougher
than I liked, but that's a subjective issue.  While all the MIS UT
inks are compatible with the MIS color pigments, I have never written
up a specific 1800 glossy workflow using PKN inks.
The UT14-C is a good, cool (40% blue), PKN.  See
http://www.inksupply.com/ut14_black_and_white.cfm  The UT-RC inkset
has cool (30%) and neutral (20%) PKNs also.  See
http://www.inksupply.com/r260_blackandwhite.cfm  All of the "warm"
PKs for these inksets are the same K4-PK.
> refill kit to refill the OEM Epson cartridges or get some
> refillable cartridges off Ebay?
I use MIS re-fillable carts.
MIS Quality Control ??
2008-11-20 by Brian Corll
Anyone else had problems with quality control on MIS cartridges ? I just
received the UT-3D set for the Epson 2200 and the locking tabs on the back
of the M and LM cartridges were missing ! The orange wedges were in the
package so obviously someone just packed them anyway - tabs or no tabs.
Needless to say I was not impressed !
Brian Corll
2008-11-21 by hp9180profile
Thank you Paul for those thoughts. Looking through the excellent
material on your site, I am drawn to this approach for BW:
http://www.paulroark.com/BW-Info/Eboni-1800.pdf modified either by
replacing one of the ebony MK's with GLOP or by using a spray as
described in this paper: http://www.paulroark.com/BW-Info/R1800-
Glossy.pdf
On the occasions that I need to print color, I can batch them up and
swap out the entire inkset for MIS R1800 color.
Some experimentation and trial and error will clearly be required on my
part but can you see any problems with embarking on a journey along
this route Paul? Or indeed offer any insights that you may have already
come across regarding this approach that you have not already talked
about in the papers on your site?
Thanks and regards, Alistair.
2008-11-21 by pr_roark
Alistair wrote:
> ... I am drawn to this approach for BW:
> Glossy.pdf
If you didn't want to use the 3-MK approach, relying on the Eboni-6
(in the R1800 configuration), you could have both the PK and Glop in
their normal OEM positions.
Dilute Eboni prints very warmly on glossy papers (my new recommended
sepia approach).  If you want a more neutral 100% carbon print, the
straight 100% Eboni would be needed.
> up and swap out the entire inkset for MIS R1800 color.
> required on my part ...
Yes, but then isn't developing your own unique workflow part of the
fun?
> this route Paul?
If you use MIS PK, stay with the K4-PK or one of the several newer
PKNs.  The MIS-Pro PK seems to be too high a load for the 1.5 pl
printers.
I'd keep an "insulating" Eboni between the dilute Eboni-6 inks and
any glop or PK.  I'm not sure PK or Glop and the Eboni-6 dilution
base are very compatible.  Keep an eye on whether they are forming
agglomerations on the pad that then stick to the surface of the
head.  I'm not saying they will, but that is one possible problem to
look for.  Eboni is compatible with all of them, so it can be between
them in the printer and help keep them apart.
If you use a straight 3-MK and then try to nail it down with a post-
printing spray, it just takes too much spray to work well.  Using a
PK at the end of a 2-MK + PK approach might make it a lot easier to
get a good, even finish with the spray.
Glop in the printing step, added in proportion to the amount of
carbon, also makes getting a good finish easier.  My memory is that
as you add glop, you'll warm the image a bit.
With a solvent-based spray, a nice finish can be produced with these
combinations.  Spraying is just a hassle and the VOCs are not very
environmentally friendly or healthy.  I'm not sure my favorite
Premier Art Print Shield is sold in the UK, but I suspect there is an
alternative.  You have Lascaux there, but it's too thin for good
glossy prints.
Good luck with the setup.
Re: MIS Quality Control ??
2008-11-21 by donbga
Oh yeah! I stopped doing business with them long ago for the reasons
you mention and for poor customer service.
Don Bryant
just
the back
tabs.
> Brian Corll
