Automate nozzle checks?
2008-11-24 by Michael
Has anyone heard of a way to automate nozzle checks on the 2200? With
winter coming on in the north (MN)the humidity is falling and even with
a continuously running humidifier, it's hard to keep the humidity high
enough to prevent clogs, without having too much condensation forming
on the windows. If there were a little program that would run a nozzle
check every couple of days it would solve the problem. Sometimes I
don't use my printer for a couple of weeks and that's too long in the
winter. It would be great to put a bunch of cheap copy paper in and let
it print a check all on its own. Years ago I recall coming across a
program that would take note of what you click with the cursor and then
duplicate that on a schedule.
-MK
Re: Automate nozzle checks?
2008-11-25 by pr_roark
MIS recommends an "Auto Print" program for this purpose.  See
http://inksupply.com/cobra.cfm#ap
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael"
With
with
high
forming
nozzle
let
then
> -MK
2008-11-25 by Michael
Thanks, Paul. I had searched all over the Inksupply site but couldn't
find it (someone else had thought they saw it there). Thanks again.
Michael K
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
> Paul
> www.PaulRoark.com
2008-11-25 by John
Paul have already provided the link to the page that you can download
it, in his reply to you (see below Pual's reply please!).
Anyway if this direct link can helps:
PC version: http://www.inksupply.com/html/zip/refresh.zip
Mac version: http://www.inksupply.com/html/macautoprt/daily_print.sit
> Michael K
> > Paul
> > www.PaulRoark.com
2008-11-26 by Michael Hung
I have a AutoNozzleCheck.zip in the Epson Wide format forum archive to
do auto nozzle check for 4800..
It will not likely work for 2200.. But you can try something similar..
Set your 2200 to print to file and ask it to do a nozzle check to the
saved file. Then use RawPrint.exe from that package.
Although I stopped using it myself.. I found turning off the printer
more economical and make sure I do the nozzle cleaning at least a day
before I need a print..
-M
With
with
high
forming
nozzle
let
then
> -MK
