matching monitor to print
2008-12-04 by Stephen Kobrin
Thanks to everyone who provided advice on matching the monitor and
print.  Two adjustments got me reasonably close.  First, I used the
advanced rather than the easy mode for the Xrite oneeye2 software and
second, I reduced the luminance of the monitor substantially.  While
the controls on my Dell 24" monitor would not allow me reduce the
brightness sufficiently to get to the target luminance of 90 cd/m(2),
I got most of the way there. I still need a slight brightness
adjustment curve to align the print and monitor, but that is easy
enough. Furthermore, since I use monitor's DVI connection to my Mac
for photography and the VGA connection to a PC for work, the dimmer
setting does not pose a problem.
Steve
Re: [Digital BW] matching monitor to print
2008-12-04 by Mark Savoia
Just curious why you used that target, I have all my monitors set for
120 cd/m.
Mark
http://www.stillrivereditions.com
On Dec 4, 2008, at 8:31 AM, Stephen Kobrin wrote:
> While
2008-12-04 by cdtobie
120 cd/m.
Display brightness (technically "white luminance") needs to be set to relate to your ambient light and proofing light. 90 cd/m would be good for near darkness; like old CRT workspaces. 120 is good for dim but not dark conditions, more common today (mostly because LCDs make it possible).
C. David Tobie
WW Product Technology Manager
Digital Imaging & Home Theater
Datacolor
CDTobie@...
www.datacolor.com/spyder3
I am dim (pun intended).
Mark
> 120 cd/m.
> make it possible).
> C. David Tobie
> Datacolor
> CDTobie@...
> If you wish to receive no emails or just a daily digest, or you
> wish to unsubscribe, please edit your Membership preferences by
> visiting this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> - By posting on this forum you agree to abide by the group rules
> and guidelines, and to abide by the actions and decisions of the
> group Owner and Moderators. See �Group Topic, Rules and Guidelines�
> in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER
> INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL
> BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF
> SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO
> OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO
> GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
2008-12-04 by Louis Dina
Hi Mark.  Here's my perspective on monitor luminance.
I use 90 cd/m2 regularly for white luminance, even on my LCD.  I
generally start with my normal viewing environment (where the picture
is hung) and work backwards.  Most display environments (homes,
offices, etc) are fairly dim, and 90 has always worked well for me.
The next step backwards is the viewing light or booth, which I try to
keep at a fairly low level, so that it comes reasonably close to
approximating the final viewing environment.  Stepping backwards, that
translates into a lower monitor luminance.  They are all equal
partners in the chain.
If I were viewing my final prints in a very bright environment, or
under dedicated spotlights, then I would consider a higher white
luminance.  They are all parts of a "complete system".  But, I have
found that using high white luminance often translates to dark, muddy
prints, unless of course, you proof AND display them under bright
light conditions.  Usually, people who complain their prints are too
dark solve the problem quickly and easily by lowering their monitor
luminance (assuming they are printing with accurate custom profiles).
It makes no sense to me to look at a print in a very bright viewing
booth (except to get a look at details), then display the print in a
relatively dim environment.  The print will just end up looking dark &
muddy, with loss of shadow detail and separation.
I advise people to use whatever works for their "system", but if they
are complaining about dark looking prints, try a lower luminance and
see if that works for them.  In my experience, more often than not, it
does.
Regards, Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia
> 120 cd/m.
> Mark
> > While
Mark,
Basically advice from various members of this group.  It does seem to
work. I have know way of knowing how close I got to the target.
Steve
> 120 cd/m.
> Mark
> > While
That should be I have no way of knowing.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Kobrin"
<kobrins@...> wrote:
> Mark,
> Steve
