Self-Resetting Chip Advice
2008-12-15 by Bob Marsolais
Here are a couple of points that may help those of us using self- resetting chips. 1) There are two types of self-resetting chips - those that reset when you cycle the power (usually the oulder type) and those that reset themselves when they go below a certain level. If you have the later type, disable the Espon status monitor or else you printer may stop printing when the INDICATED levels get too low. Disabling the Epson monitor will allow you to print throught the low level indication until the chip resets itself. 2) You cannot mix OEM, self-resetting, or manual reset chips. All chips installed should be the same type. The printer will usually report a bad cartridge or "cannot recognize cartridge" message if chips are mixed. 3) Because self-resettng chips reset themselves, you never need to remove the cartridge from the printer and risk getting air in the jets. Just refill the carts in the printer. This is the biggest reason to use this type of chip. I had more problems with air in the R1800's jets than the 1280, C84, and C86 I also have owned. By not having to remove the carts, the problems went away. However, you need to keep track of how many pages yu've printed and refill before the carts go dry. That is the down side. Once you've done it a couple of times, you get used to it and it's no big deal. In fact, it's faster than refilling and reinstalling carts unless you keep extras on hand. But if you remove and reinstall, you risk getting air in the jets... 4) The Espon Status program is disabled as follows from the driver preferences window: from the Maintanence tab, click "Speed and Progress", then check the "Disable Epson Monitor 3" box. My source of information is Ross Hardy at InkJetCarts.us who is very helpful. They are also a good source of refillable carts and ink. They sell Image Specialists inks. Ross claims (and my experience verifies) they are interchangable with Epson and MIS inks. I use the Image Specialist R1800 matte black interchangeably with Eboni black with no mixing problems. As far as the carts go, I have not found any source that ships 100% good refillable carts for the R1800. Considering they all come from the same place, I am not surprized. After all, consider baby food, pet food, children's toys, etc. The problem is not who sells them. I must say, MIS's carts for the R1800 seem to be the most robust of any I've seen.
