Rob,
Yes, I refill the R1800. I do black only printing with MIS' Eboni ink
in the two black and the glop positions, using Paul Roark's workflow.
In the color positions, I use the OEM color carts in their original
positions. After the color ran out I refilled them with MIS Cleaning
Fluid and do so whenever the Tool Kit shows them to be low. As for the
three black positions, I started with the MIS carts pre-filled with
Eboni, from MIS, and now that they've run out I refill those as well.
The refill techniques are different. For the OEM carts I use the MIS
OEM refill kit and for the black positions I use the MIS technique for
the spongeless carts. I hope this is the information you're looking
for! Let me know if I can tell you more,
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, RobLee
<roblee007@...> wrote:
> do you refill R1800, if so what carts and ink do you use?
> --- On Tue, 12/23/08, Paul Whiting <paulmwhiting@...> wrote:
> From: Paul Whiting <paulmwhiting@...>
> Subject: [Digital BW] Re: Refilling OEM Epson Cartridges
> Date: Tuesday, December 23, 2008, 12:27 PM
> --- In DigitalBlackandWhit eThePrint@ yahoogroups. com,
Brubaker family
> <brubaker_family@ ...> wrote:
> > One trick I've used to prevent the printhead spikes from drying out
> is to cover them with (clean) wet toilet tissue while I have the carts
> out.
> > Mike Brubaker
> Thanks Mike, sorry I didn't see your suggestion earlier. I'm a bit
> behind in my forum reading. I'll try your tip next time I refill, it's
> very simple and elegant - I like it!
> Paul
