Ink mixing base pH control with Triethanolamine (TEA)
2008-12-21 by pr_roark
My reading indicates that electrostatically stabilized pigment dispersion approaches are pH sensitive. That is, if the pH is off too much, the pigments may not stay suspended as well. I believe this form of stabilization approach is used by Eboni (some speculation here) and the HP Vivera pigments (HP in combination with steric stabilization). My cheap new pH meter indicates that Eboni and HP Grey inks are close to pH 8 (HP perhaps a bit above and Eboni just below). The bases I most often use today are closer to pH 6, if not a bit less. I think that increasing the pH of the base we use to dilute the carbon inks might improve the ink mixes we make. Triethanolamine (often referred to as TEA) is, according to Wikipedia, often used as a "pH balancer in cosmetic preparations in a variety of different products - ranging from skin lotion, eye gels, moisturizers, shampoos, shaving foams etc." The HP Vivera MSDSs disclose that it is used in them. TEA has been used for some time in photographic applications and is available at Photographers' Formulary. See http://www.photoformulary.com/DesktopModules/StoreProductDetails.aspx?pr\ oductID=588&tabid=0&tabindex=0&categoryid=0&selection=0&langId=0&Search=\ triethanolamine <http://www.photoformulary.com/DesktopModules/StoreProductDetails.aspx?p\ roductID=588&tabid=0&tabindex=0&categoryid=0&selection=0&langId=0&Search\ =triethanolamine> Just a few drops of TEA in 10 grams of C6 base (http://www.paulroark.com/BW-Info/Ink-Mixing.pdf <http://www.paulroark.com/BW-Info/Ink-Mixing.pdf> ) takes the pH up to 8. Cheap Litmus paper makes it easy to mix and measure, slowly, until the pH test strip indicates that pH 8 has been reached. TEA might be a contender for the next ink mixing base. (Again, I'm not a trained chemist, and all comments are most welcomed.) Paul www.PaulRoark.com <http://www.PaulRoark.com> [Non-text portions of this message have been removed]
