accurately rendering grain - noob question
2008-12-27 by David Murphy
So I'm new to this but am now at least knee deep in seeing what is
possible w/ modern inkjets for b&w.  At the moment I have an Epson R280
loaded with the 6 cartridge Eboni inkset from MIS.
I shoot two films, Ilford HP5 and Delta 3200 in both 35mm and 120mm.
I'm quite happy w/ my film and processing methods.  Scans look great.
Traditional wet prints look great.  Some of my new inkjet prints look
great, others look very bad.
As a generalization it seems like in some circumstances and with some
photos the printer is able to convincingly render the film grain and
it's gradations smoothly and in other cases it can not.
Where I notice this most is usually with people's hair or beards.  They
often appear very splotchy as if the printer is printing straight black
or white and doesn't understand that there should be a gray transition
in between.  These are mostly natural light candids on 35mm where grain
is fairly visible.  I like grain.
What confuses me somewhat is that if I take the identical file and print
it out with QTR in Black Only mode, QTR seems to handle these
transitions in tone much more smoothly and hair is rendered much more
convincingly as opposed to splotchy. I would just print with QTR but I
do not like the brown look and I greatly prefer the overall tonality of
the 6 cartridge setup.
So, if the above makes any sense, am I running into a limit of the
technology or am I doing something wrong?  Why is QTR rendering hair
much more convincingly using only one cartridge?  What should I be
experimenting with?
Re: [Digital BW] accurately rendering grain - noob question
2008-12-27 by Ernst Dinkla
> experimenting with?
In your case it is more  likely the better tonal
distribution through QTR than what is possible (or harder to
achieve) with the normal driver. But it could as well be one
of the issues below.
At some stages in the process aliasing can occur. At the
scanning phase the actual grain can more or less accumulate
to larger digital grain. Grain effect (and noise in digital
images) can also increase when downsampling is done without
proper anti-aliasing filters. If the software you print from
leaves the downsampling to the printer driver and the last
has inferior downsampling routines then aliasing can happen
there too. There are ways to avoid that. Lanczos
downsampling shows the effect less for example. Using a high
quality printer setting requires a higher native resolution
and the chance your data is downsampled is less likely.
There's another issue with grain and pixels: to the eye both
grain and pixels have the tonal information and they
interfere with one another. For example sharpening will
increase general contrast much more in a digital image with
grain than one without grain, the other way around a general
contrast change will increase grain. If the software applies
a smart print sharpening on the fly when printing, grain
will become more visible and contrast increases.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
Re: accurately rendering grain - noob question
2008-12-27 by pr_roark
David Murphy <dm1000@...> wrote:
> ...I have an Epson R280
> ... it seems like in some circumstances and with some
> film grain and
> or beards.  They often appear very splotchy as if the
> a gray transition in between. ...
> ...QTR in Black Only mode ... seems to handle these
> rendered much more
> overall tonality of the 6 cartridge setup.
I can't tell from this just what workflow you're using.
In addition to what Ernst noted, one difference between the QTR black
only and the full inkset is the amount of ink (water) that is being
put on the paper.  Blotchiness can be caused by overloading the paper
with too much light ink.
This appearance can also be caused by a profile that is not
appropriate for the paper-ink combination.
If the profiles are made right and the printer is working correctly
(perfect nozzle check, for example), the full inkset should render
the gradations as well as the black only.  In fact, many have found
that the graininess of the black only approach combines with the film
grain to make an image rougher than if it were a darkroom print.
Testing the system with 21-step test prints makes it easier to spot
were the problems are.  One such test strip is posted here:
http://www.paulroark.com/BW-Info/21-Step_0-100_L16_16-bit-top.zip
2008-12-27 by ben schneider
Ernst,
I was thinking in a similar line.  If the films scans were ever converted to Jpeg files, many of these subtle tones could be lost in the compression, then decompression of the file.  Also, he didn't mention files size.  Enlarging a small file could also make details blotchy.  David didn't mention file type and size.
Ben
Re: [Digital BW] Re: accurately rendering grain - noob question
Not sure that I am following one of your pdf workflows precisely but the
process goes like this:
1. Scan film negatives w/ Silverfast SE at 3200 dpi(usually 3200 for
35mm and 1600 for 120mm), using Silverfast's internal 16bit>8bit
conversion, saving as uncompressed TIFF.
2. Import into Lightroom 2.2, crop, spot, sharpen, minor tonal adjustments.
3. For QTR printing I export to TIFF w/ Lightroom.  For Epson driver
printing I am using Lightroom's internal print module set to 360 ppi,
usually standard print sharpening, and have it set to have the profile
managed by the printer.
4.In the Epson Driver I am using the settings that are outlined here:
http://www.paulroark.com/BW-Info/R260-BW-GS-Eps.pdf
I'm proofing using Epson Ultra Premium Presentation Paper Matte.
I think the nozzles and such are likely ok as I can take a non difficult
image and get a great print and then immediately go back to a grainier
image and have it look bad.  I made 4x4 and 8x8 prints of a well
exposed, natural light head and shoulders portrait I shot on HP5 120mm
on both the Epson paper and PhotoRag and it turned out fantastic.
Intricate details of hair were rendered well but there was fairly little
visible grain in the negative.  My success with this image gave me the
impression that I couldn't be too far off with workflow/settings.
35mm negatives of HP5 that have a fair amount of grain seem really
problematic.  For example, a man's 5'oclock shadow ends up looking more
like he has polka dots or chicken pox than a beard when printed with the
Epson driver but not in the scan, not in a wet print and not when
printed with QTR BO.  Really well exposed 35mm with less apparent grain
seems less problematic.  I've printed some of the problematic images
from 4x6 up to 8x10 and it behaves the same way.  Very distracting.
I don't know if it worthwhile but is there a way to try printing with
all 6 cartridges under QTR rather than just BO?
2008-12-29 by David Murphy
> That's an unusual film format.
Indeed.  Not sure what I was thinking.  Maybe I had it confused with the
120mm artillery I have in the back yard.
In any case, is it possible to use QTR to print with all 6 cartridges?
I searched the list archives and found a similar query regarding the
Epson 1400 here:
http://tech.groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/93208
to which Mr. Roark supplied a file but both the original poster and
myself received an error message when attempting to import this into
QTR.  The thread seemed to die after that.
Anybody else try using all 6 cartridges w/ QTR?  Any hints on how to
make it work?
2008-12-30 by pr_roark
> ... is it possible to use QTR to print with all 6 cartridges?
I missed your 12/27 post.
You're apparently using the UT-RC (260) inkset that I wrote up at
That inkset was made to be a very simple one with 2 levels of midtone
density and 3 hues each.  I did not make QTR profiles for it, but it
can be printed with QTR.
The problem you'll have with QTR if you use the standard profiling
procedure is that you don't have 6 different density levels that QTR
can sequentially partition.  There are several ways around this.
Probably the easiest way is to make a profile that uses only one
light gray, one dark gray, and the K position inks.  Once that
profile is done but before it's linearized, copy the light gray ink
to the 2 other light gray positions and cut the ink limits to 1/3
what they were for those inks. Copy the dark gray curve to the other
dark gray ink and cut those 2 ink limits to half what the one was.
This will use all the inks, but the cross-overs will be at the same
places.
If you see these cross-overs there are other refinements that can
spread them.  But each refinement gets more complex.  So, try this
approach first.
Hope this helps.
