B+W Scans from RGB Scanners
2009-01-04 by dale40203
How does an RGB scanner determine Greyscale equivalents? Is there a formula it applies to
the three components? If so, would the color "fringing" I see on some RGB scans contribute to
a softening of Greyscale scans?
The only way I can see to avoid this is for only one of the RGB components to be used, and I
know that would not be an accurate representation of RGB translated into GS.
Dale Hoffman
Re: B+W Scans from RGB Scanners
2009-01-05 by outdoornm
Dale,
I cannot speak to scanners specifically, but Photoshop converts to grayscale directly in the
red channel.  ie,    Image>Mode>grayscale  (100% red, 0% green, 0% blue)
There are other ways to grayscale, using various values of red, green or blue, but I would
suspect that scanners use the same 100% red channel method.
Lincoln
- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dale40203" <dhoff@...> wrote:
to
contribute to
and I
> Thanks,
> Dale Hoffman
Re: [Digital BW] Re: B+W Scans from RGB Scanners
2009-01-05 by Bill Morse
I don't believe that's true. You can test this with a Channel Mix layer,
just compare the conversion with and without.
To the OP; if you have signifcant fringing, then it likely will affect the
gray conversion as well as (though less than) the color image. That said,
you're still much better off converting in PS than the scanner software, as
there you have full control over the conversion process. Learn to use the
channel mixer.
Bill
On Sun, Jan 4, 2009 at 10:36 PM, outdoornm <outdoornm@...> wrote:
>   Dale,
> ...Photoshop converts to grayscale directly in the
> blue, but I would
> Lincoln
> - In DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>,
> formula it applies
> to
> scans
> contribute to
> and I
> GS.
> > Thanks,
> > Dale Hoffman
Bill Morse
Wm. Morse Editions
http://www.MorseEditions.com/
2009-01-05 by Steve Clark
My vote would be to scan B&W neg as a single channel on the scanner.
Especially if it's a prosumer scanner. My reasoning would be the
optics and ccd alignment on these scanners are compromised thus the
"fringing". Also, the blue channel is usually a garbage channel
contributing most of the noise that the scanner will add. So, if
channel mixing, you would really want to zero blue out and fiddle with
the red and green. Ideally a scanner with a visual (salmon) filter
would be best, but I think those days are long gone.
The argument for scanning in RGB would be that you can finesse the
channels to get what you want. So, I guess you would have to evaluate
your hardware by scrutinizing a bunch of scans to decide if the extra
size, image processing and time are worth it. I operate a Hell S3900
drum that is about as well engineered a scanner as you can get, and I
don't waste a bunch of space and time fiddling with RGB from B&W negs.
I pick either the Red or Green channel.
Just my 2 pence.
Clark
> layer,
> affect the
> said,
> software, as
> use the
> channel mixer.
> Bill
> wrote:
> > Dale,
> green or
> > blue, but I would
> > Lincoln
> > - In
> there a
> > formula it applies
> > to
> some RGB
> > scans
> > contribute to
> > and I
> translated into
> > GS.
> > > Thanks,
> > > Dale Hoffman
> Regards,
> Bill Morse
> Wm. Morse Editions
2009-01-05 by Louis Dina
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bill Morse"
> layer, just compare the conversion with and without.
Correct, Bill.  When converting from color to grayscale in Photoshop
(using Desaturate or Mode : Grayscale), Photoshop takes its tonal
values as follows: approximately 30% of the red channel, 60% of the
green channel, and 10% of the blue channel.  Works fine for some
images, but lousy for others.  "Usually", the green channel comes
closest to the true tonality, but even that is a dangerous statement,
depending on the colors and tonalities of the image.  Green is also
usually the least noisy channel, but again, not always.  Blue is
usually the noisiest.
Channel Mixer, Calculations, Apply Image and numerous plugins do a
good job on color to B&W conversion.  You can also do quite a bit of
tonal manipulation in LightRoom.
Lou
2009-01-05 by Lincoln Michaud
It is true that the direct conversion to greyscale from  RGB  in
Photoshop  changes to the red channel.  You can check this easily by:
converting an image to greyscale in PS by: Image>mode>grayscale.  Go
to Edit and select 'change profile to rgb'.  Go back to Mode>Channel
mixer and you will see that the red channel is at 100%  Don't know
about scanners.
Lincoln
2009-01-05 by Jules
I agree. Don't do the conversion with the scanner as it's software is
poor compared to the ways in which PhotoShop can convert. Scan in full
colour and import into PS first.
 Jules
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "outdoornm"
> Dale,
> Lincoln
> to
some RGB scans
> contribute to
> and I
translated into GS.
> > Thanks,
> > Dale Hoffman
RE: [Digital BW] Re: B+W Scans from RGB Scanners
2009-01-06 by E Neilsen
If you have PS CS3 or CS4 why would you even consider just hitting
mode>grayscale when you could convert to B&W with image>adjustment>B&W
complete with preset that you can load for yourself? As for just using the
red channel? I don't think so. It just does sound right at all.
Just did a screen capture of a red channel only B&W, and a convert to
grayscale screen capture and the numbers don't match. Close but not a match.
There are default setting lurking in PS and I think that you idea about what
is being done there is just that. I'd ask some Adobe folks about it.
As for scanning, you can use the channels for sharpening, noise control, etc
in the scanner software. It is a whole new exposure of a scene. How would
you like to render it? That is the first question and the beauty of it is
there is no ONE answer, but many equally valid choices.
Eric Neilsen Photo
4101 Commerce Street, Suite 9
Dallas, TX 75226
214 827-8301
SKype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Lincoln
Michaud
Sent: Monday, January 05, 2009 9:25 AM
Subject: [Digital BW] Re: B+W Scans from RGB Scanners
about scanners.
Lincoln
2009-01-06 by outdoornm
Eric,
I'm not arguing that direct grayscaling is the best method.  I am just stating what the
default is in my CS2.  If you do the check I mentioned it will show you that is exactly the
case. I  have also read it elsewhere, but I can't find reference to it at this point. You guys
need to come up with some authentication for your opinion- it sounds to me like you just
think it is improbable.
Personally, I choose to use direct grayscale because you can drive yourself crazy seeing
what tweak works the best using channel mixer.  I have found it much more effective to
convert to grayscale directly  Image>mode>Grayscale and then work on the image in
curves.  I find it gives me much more control.  You wouldn't think so, but for me, it does.
Like anything in Photoshop there are many ways to achieve what you want.
Lincoln
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "E Neilsen" <e.neilsen2@...>
> Eric Neilsen Photo
> Dallas, TX 75226
> 214 827-8301
> SKype ejprinter
>   _____
> From: DigitalBlackandWhiteThePrint@...m
> Michaud
> about scanners.
> Lincoln
2009-01-07 by Eric Neilsen
Lincoln, I understand were not arguing, just stating observations. When I
did my test of the screen capture done two ways; 1) using the convert to
gray and screen capture that and 2) show only the red channel and screen
capture that. I got two very different results. And I'd love to see an
attributable adobe source that states that grayscale uses red channel only
or as ??? suggested a % of R, %G, and small % B.
I rarely use the convert to grayscale unless I'm in a hurry. Each conversion
is specific to that image and what you want to do just as with each camera
exposure can have a red filter or orange filter or.
I have seen several people suggest that PS has a better conversion of RGB to
grayscale than does the scanning software, but I have not seen them mention
published test that show this. I have seen Epson and Imacon side by side at
demo events and they would NOT make the best scan they could and show the
difference. Why? Could it be that much of it is operator experience and an
equal part software/hardware driven? Could have simply been time.
 Eric
Eric Neilsen
Dallas, TX 75226
214-827-8301
www.ericneilsenphotography.com
SKYPE ejprinter
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of outdoornm
Sent: Tuesday, January 06, 2009 4:34 PM
Eric,
stating what the
is exactly the
like you just
crazy seeing
effective to
image in
me, it does.
Lincoln
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "E Neilsen"
<e.neilsen2@...>
match.
what
etc
Image removed by sender.
2009-01-07 by Tyler Boley
hey folks, it's well documented what the RGB combo is they use for
straight grayscale conversion, I can't recall what it is though, it's
a mix. I'm sure someone here knows...
Tyler
http://www.custom-digital.com/
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eric Neilsen"
When I
channel only
conversion
camera
of RGB to
mention
side at
show the
and an
>  Eric
> Eric Neilsen
> Dallas, TX 75226
> 214-827-8301
> SKYPE ejprinter
outdoornm
> Eric,
> stating what the
you that
> is exactly the
to me
> like you just
yourself
> crazy seeing
> effective to
> image in
but for
> me, it does.
> Regards,
> Lincoln
> <e.neilsen2@>
using the
> match.
about
> what
control,
> etc
How would
of it is
Tyler, I asked my friend Dan Burkholder and here is his reply,
 Hey Eric,
I asked Julianne Kost of Adobe that very question a few years ago and can't
find her response. I'm pretty sure it was either 70G/20R/10B or
60G/30R/10B...but with my memory who knows. Guess you could manually do
those and see which more closely matches the RGB>Grayscale conversion.
But certainly not 100% red.
Eric Neilsen
Dallas, TX 75226
214-827-8301
SKYPE ejprinter
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Tyler
Boley
Sent: Tuesday, January 06, 2009 9:03 PM
Tyler
_
2009-01-07 by John Vitollo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eric Neilsen" <e.neilsen2@...>
Photoshop's default grayscale conversion is: R-30%  G-60%  B-10%
2009-01-07 by Ernst Dinkla
That's what I recall of the Vuescan default settings for the
greyscale scan mode, the green dominant in the mix.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
2009-01-08 by outdoornm
John,
If that is true, why don't you see those values in the channel mixer of a directly grayscaled
image?  If you directly grayscale an image Image>Mode>Grayscale, you can no longer
access the image via the channel mixer. However, If you change the profile of that same
image to RGB and go back in thru'  Image>Adjustments>Channel Mixer you will see that
the default is 100% red.  ????? Why doesn't it read   R30% G60% B10% since those are
supposed to be the values in each channel?
Lincoln
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo" <jvlist@...> wrote:
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eric Neilsen" <e.neilsen2@>
2009-01-08 by Louis Dina
Lincoln,
Channel Mixer simply defaults to 100% of the red channel upon opening,
but that doesn't mean it is the default B&W conversion formula for
Photoshop.  When you click 'grayscale' in Channel Mixer, it just jumps
to the first available channel, which is red, and leaves it at 100% so
you can start fiddling around with the sliders.  That gives you a
display of the Red channel only, with both Green and Blue channels set
to 0%.  It's just a blank canvas and a starting point.
Looking at any grayscale conversion using Mode>Grayscale, you can see
that the result is not the Red channel only.  All the information I
can find suggests 30%R, 60%G, 10%B is about right for a standard mode
change.  If it isn't that, it is close.
Sometimes a single channel provides the best conversion, or at least
comes close to the desired result.  It may be the red, green or blue
channel, but usually it is some combination of at least two channels.
 Since Hue and Saturation are no longer relevant in B&W, it's a matter
of selecting and blending those channels that give you the tonality
distribution and separation you want between tones.  And since we
don't see in B&W, we get to select the relationships we want.  Adobe
decided 3/6/1 was a good "general" formula for the "average" mode
conversion, but one size definitely does not fit all.
Regards, Lou
> John,
can no longer
you will see that
since those are
> Lincoln
ago and can't
manually do
conversion.
2009-01-08 by pr_roark
"Louis Dina" <lou@...> wrote:
> ...  All the information I can find suggests 30%R, 60%G, 10%B
> is about right for a standard mode change.  ...
> Sometimes a single channel provides the best conversion, ...
With my older DSLR, the blue channel was very noisy.  With the new
Canon 5D2, for at least some lenses, blue is sharper and noise free,
at least outside the deep shadows.  The shorter wavelengths are
affected less by diffraction, so it makes sense blue would be
sharper, all else being equal.
> ... it's a matter of selecting and blending those channels
> that give you the tonality distribution and separation you
> want between tones.
I split the RGB channels so that I can compare the B&W images of
each.  Then I clone/pull image information from each as needed.
> Adobe decided 3/6/1 was a good "general" formula for the
> "average" mode conversion, ...
And often if there is no significant color information in the shot,
I'll just use their mode change.  It's easy.
2009-01-08 by Dana H. Myers
Louis Dina wrote:
> Lincoln,
According to _mastering black and white digital photography_ (
http://www.amazon.com/Mastering-Black-White-Digital-Photography/dp/1579907075 ),
Photoshop uses 30% red, 59% green and 11% blue, which jives with
the 30/60/10 number.  Desaturate gives equal weight to all the channels.
Dana
2009-01-08 by Eric Neilsen
I have done a bit more research on this and I think that the %s given might
be old hat. The speed at which information changes from books, articles,
even internet blogs, can be inaccurate. I checked with another source and a
more current conversation indicates a  reduction based on HSL; Hue
saturation and Lightness.
And with all the programs that are active; CS 1-4 and before it is quite
possible that many answer will remain correct. I pointed this out about
internet information in a previous thread and one member took great offense.
But it remains a real aspect of the digital information and digital
processes. The actual conversion is going to be an elusive answer unless
some can get Adobe to post it for specific version unless that information
is in Freeman's book.
Eric Neilsen
Dallas, TX 75226
214-827-8301
SKYPE ejprinter
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Dana H.
Myers
Sent: Thursday, January 08, 2009 10:56 AM
Subject: Re: [Digital BW] Re: B+W Scans from RGB Scanners
5 ),
Dana
given might
> be old hat.
Eric, I suspect you are right.  I opened an sRGB color image in PSCS2
and made three duplicates.  The first I converted to grayscale
(Mode>Grayscale) using gamma 2.2 space.  The 2nd duplicate used
Hue/Saturation, and the saturation slider was totally desaturated.
The 3rd duplicate used Channel Mixer and I played around with the
sliders.
The mode conversion and desatuated images were totally different.
Channel Mixer did not match either when set to 30R, 59G, 11B.  In
fact, it was tough to duplicate the mode conversion without also
adjusting the "constant" slider, and even that was just close.
To me, it is a moot point, since I rarely find that any of the default
conversions work well (unless, as Paul Roark pointed out, you are
starting with a relatively low key image to begin with).  Sometimes a
single channel works, but I find I need to blend channels to get a
grayscale image that works.
Lou
Thank you, Lou,
What you say, makes sense.  I could see the diff'  between direct grayscaling and running
100% red in the channel mixer, but I thought that was because Photoshop was
automatically adjusting for the luminescence values.
I assume from what you are saying that Photoshop has some set ratio(possibly 30%R,
60%G and 10%B)  However, If one wishes to modify the results he can use the channel
mixer.  It would be good to get the actual percentages from Adobe so that we would all
know the actual percentages without guessing.
Well, they don't call Photoshop the most complicated software system on earth for
nothing.  I thought the 'learning curve' would flatten out after a while. :-)
Lincoln
> Lincoln,
> Regards, Lou
> <outdoornm@> wrote:
> > John,
> can no longer
> you will see that
> since those are
> > Lincoln
> ago and can't
> manually do
> conversion.
> Thank you, Lou,
>ratio(possibly 30%R, 60%G and 10%B)
You're welcome.  Glad it was clear.
Not so sure that the 30/60/10 balance is correct, even though it has
circulated in many forums and become widely accepted as true.
http://tech.groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/94784
Lou
2009-01-09 by Steve Clark
It seems you could test it by creating an RGB document with solid 100%
Red, Green and Blue bands that do not overlap and then do
Mode>Greyscale. Then eyedropper the resultant greyscale in each of the
corresponding bands.
Clark
> given might
> articles,
> source and a
> quite
> about
> offense.
> unless
> information
> Eric Neilsen
> Dallas, TX 75226
> 214-827-8301
> SKYPE ejprinter
> Dana H.
> Myers
> To: DigitalBlackandWhiteThePrint@...m
> 5 ),
> channels.
> Dana
2009-01-10 by br80906
Please check out this page...it helped me a ton on b/w conversion.
You need to experiment w/your scanner, but the end result will give
you what you are looking for...
http://www.butzi.net/articles/colorscan.htm
2009-01-10 by Roy Harrington
There are no fixed ratios.  Photoshop uses color management to convert Modes.
So if you convert RGB to Grayscale you are preserving the L values of the RGB
profile space -- converting them to identical L values in the grayscale working space.
This is easy to see: take any set of RGB patches, using the eyedropper look at the
L values, convert to grayscale and all the L values remain the same.
Conversions using desaturate, channel mixer, black&white, I think use ratios
but they are all different.
Roy
2009-01-10 by Eric Neilsen
What I find interesting is no conversation about refocusing the scanner.
While we know that RGB channels don't always focus at the same distance,
isn't it possible that the real difference is simply a matter of how the
focus was achieved? And has really nothing to do with a superior channel for
the conversion.  It might be a sensor issue which was discussed. And the
stouffers step wedge is a Tech Pan film stock, or at least they were made
from that, it may also be allowing light to pass differently than Elfe,
Adox, Ilford, etc.
And Roy, Do you know for what version of PS your information pertains to?
All?
Personal testing is still the order of the day.
Eric Neilsen Photography
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of br80906
Sent: Friday, January 09, 2009 9:59 PM
> All?
Hi Eric,
Color Management has been used for Photoshop Mode conversions for quite
a while.  At least all the CS versions (CS,CS2,CS3,CS4) do it that way.
It's also worth mentioning that the Info Palette also uses this.  If you display say
RGB values when you have a grayscale file, you are seeing the ICC converted
values based on the RGB working space.  In other words since K values are
displayed in values 0-100 you don't see the full 8 bits that are really there.
Often people will look at the RGB values 0-255. But they aren't the files values
they are the converted values from K to RGB -- matching Lab Luminosity.
Roy
Yes, testing is always worthwhile.  It's a great way to learn what's going on
"under the hood" -- if you are curious about it.
R
> Suite 9
> Dallas, TX 75226
> Skype ejprinter
> All?
Hi Eric,
Roy
R
> Suite 9
> Dallas, TX 75226
> Skype ejprinter
Roy, Yes, Color management has been a round in PS for many generations. And
the values to look at are not just the RGB values. But that doesn't answer
the question of,  "Has the conversion to grayscale been the same from PS6
through CS4 the same"?. Are those stating the best way to scan is from RGB
convert to gray in PS talking about a particular workflow; scanner, software
with Version, PS what version, etc. Without the stated workflow, the answers
may not be valid today with the next users workflow.
The issue surrounding what conversion method Adobe uses when applying
convert to gray have presented themselves because we have received various
answers without a version and source. I have contacted several people that
work in the industry and have either direct working relationships with Adobe
or deal with writing plug ins for Adobe products. I have received
indications that at one point they used a conversion that included the RGB %
values that were stated. It was expressed to me that at some point that was
true, but has since changed to more of the HSL conversion method.  I really
don't care as I use other methods to convert a RGB file to a K.
Rereading the answer to the OP, Peter answered it; it depends on the
software. But I  also say what hardware too.
The thread moved away from just what the scanner does to how PS converts to
gray -K. Including references to books, contacts, etc and we have several in
the specific values camp of RGB and some that are in the HSL camp. I am
saying it sounds that both are valid for various times in the life of Adobe
PS. And now we have Lightroom that will take a scan and whether it was
output from the scanner with a gamma 2.2 or whatever, will output it as an
RGB file to PS and beyond.
So to Dale, run tests in the scanning software to determine what works best
for your set up paying attention to the controls available for noise, focus,
etc. All things that contribute to the proper exposure for your image
intent.
Eric Neilsen
Dallas, TX 75226
214-827-8301
SKYPE ejprinter
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Roy
Harrington
Sent: Saturday, January 10, 2009 12:23 PM
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "Eric Neilsen"
<e.neilsen2@...>
> All?
Hi Eric,
display say
there.
values
Roy
R
> Suite 9
> Dallas, TX 75226
> Skype ejprinter
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of
br80906
