DSLR Optics -- slightly OT
2009-01-08 by pr_roark
This  is a bit OT.
In a previous thread "Michael King" <drmrking@...> wrote:
> Paul,
> If you want to get the best out of the 5D2 wide angle,
> get some of the new Zeiss lenses for Canon...
The sharpness information on some of the Zeiss optics are very good
indeed.  While the new ZE series for Canon are not out, at least for
what I was looking for, the old Contax 28mm f2.8 appeared to be an
amazingly good lens in numerous tests.  The Photodo rating of 4.3 put
it ahead of all but the very best Leica M wide angles.
Not infrequently, however, Zeiss lenses are criticized for actually
being too contrasty.  Frankly, this seemed a little odd to me.  One
tester actually appears  to have shown the higher contrast of the
28mm Zeiss with a comparative histogram.
See http://www.16-9.net/lens_tests/28mm_3.html
At any rate, I bought a used Zeiss Contax Distagon 28mm f2.8 and
tested it both with resolution charts and outside shooting.  At f8 is
was very sharp with very little color fringing.  However, due to an
apparent decentered element, the lens would not focus at infinity and
was not good wider than f8, so I returned it.  Overall, the Canon 35
f2 is where I'll probably stay for the time being.
The amazing thing, however, was that the contrast of the Zeiss lens
may have actually caused it to blow out highlights on the Canon 5D2.
In comparison shots with the Canon 35, the Zeiss simply did not work
as well as the Canon with respect to how the exposure was
determined.  Is it possible we actually benefit from a little
flare?  I used to pre-flash slide film to increase its ability to
capture wide dynamic range scenes, and I suppose this same thing
might be happening with our less than perfect optics on DSLRs.
Re: [Digital BW] DSLR Optics -- slightly OT
2009-01-09 by Michael King
If you are interested in finding out more about these Zeiss lenses real
world performance, check out Lloyd blog (free) and Zeiss report ($). He is
one of the few people I actually respect, for his factual, no
bullshit/advertorial information.
http://diglloyd.com/diglloyd/blog.html
Mike
2009/1/8 pr_roark <pr_roark@...>
>   This is a bit OT.
> > Paul,
> Paul
> www.PaulRoark.com <http://www.paulroark.com/>
