"Sarah Renkes" <sagaface@...> wrote:
> I'm about to hurl my r1800 out the window. ...
> I have shut it off over 20 times in the last hour, trying
> to get it to properly load paper,
> front or rear it just doesn't want to, and won't reset
> unless I shut it off. ...
Some have had luck cleaning the rollers with either commercially made
cleaning papers or a cheap matte paper with Windex sprayed across the
middle. The feed on these printers seems to be not only related to
the model but also whether you happened to get a good one or not.
> I'm using 3mk on this thing, and the MIS carts are see-through.
> I got my first ink-out notice and see that there is still 1/4
> left of ink in the cart. Is there some way I can
> keep using the cart?
I refill them when the light comes on. The MIS 3MK carts are
refillable. Bulk Eboni is the most economical printing I'm aware of.
> I used to have a chip resetter for Epson ink carts but it
> died after only a few uses.
I've had several. Some last a long time, others not. They're cheap
and worth buying when one crashes. I just had to get a new one also.
> Suggestions?
A printer that is nearly impossible to feed takes the fun out of
this. So, if it does not clean up, I'd probably dump the 1800. But
do try to clean those rollers first. The 1800 3MK system is still
very good when the 1800 (and carts) are working as they should. Most
of my frustration with it has been leaky carts (about 1/3 of them, it
seems) and problems with non-3MK workflows. Good 3MK carts and color
or clear in the other spots is still a viable workflow. Beyond that,
it's a crap shoot.
