Poor man's densitometer
2009-01-14 by kwalsh74
I just wanted to post a note that some might find helpful. I don't own a densitometer and wanted to linearize some profiles. I saw Paul's write up on using a scanner, but unfortunately my scanner is a junky all-in-one deal with no real controls and thus the highlights are always blown making it useless. I did however get surprisingly good results using my camera using the method I'll describe here. 1. I got a calibrated 12-step reflection wedge from Stouffer ($24 shipped, uncalibrated are about $10 less) but any sort of reference with a few steps will do. 2. Place the 12-step reference right next to the 21-step profile to be linearized on the floor. Make sure the two are as close as practical and oriented the same way (white to white, black to black). 3. Put camera (a Rebel XTi in this case) on tripod directly above the step sheet. Use as long a focal length as possible and get the camera as high as possible, this will reduce the possibility of picking up direct reflection of the light sources from the paper under measurement. 4. Place two light sources as far as practical to each side illuminating at a 30 to 45 degree angle. Try to make sure the sources are the same brightness and are the same distance from the step sheet. Make sure the angle of illumination won't produce specular reflection at the camera. I used off camera flashes, but desk lamps would do just as well with longer exposure. The goal is to get the illumination of the paper as even as possible and to not have any direct reflection from the camera's viewpoint. 5. Take photos at a few different exposures, my XTi has enough dynamic range that I could get reliable measurements using just two exposures when shooting RAW but you may want to take more, especially if using JPEG. The goal is to make sure among your exposures there are some in which the darkest patches aren't too close to black limit and some in which the lightest patches aren't too close to saturation. My first try I did four exposures and it was over kill. 6. Load photos into Photoshop/Gimp or whatever, ideally 16-bit data. Convert to Lab color. Apply some Gaussian blur. Measure the L values of each reference step. Measure the L values of each of the 21 paper under test steps. You may not be able to get all measurements from the same exposure, you might have to do mostly highlights with one exposure and mostly shadows with another. 7. Using the known densities from your reference scale and its measured L values you can then calculate the densities for your 21 step test using cubic spline interpolation. You can get free cubic spline tool sets for Excel or you can even do it online here: http://www.akiti.ca/CubicSpline.html Obviously you'll need to do different fits for each exposure. 8. That's it, the results from your interpolation will tell you the densities you need to plug into QT RIP to linearize. Some notes: - Getting even illumination of the paper is difficult, that's why densitometers and scanners are a better choice. But with proper light placement and aligning the reference steps and test steps close to each other and in the same orientation you minimize the effect. Also, you can check by seeing how the paper white varies across the image and can even use the measurement of this variation to correct for any error but I believe that to be very much overkill for doing a linearization. Also you could move the reference wedge to be closest to the portion of the 21-step that you are measuring with a given exposure. - If shooting RAW resist the urge to output linear data from the RAW converter. It seems like a good idea, but since we're interpolating to a log scale (density) it actually makes the measurement and interpolation more fussy and less reliable. Using a standard tone curve and 2.2 gamma space gets things into a power law that jives with density interpolation better. - Even if you have 8-bit data, going into 16-bit mode before doing the Gaussian blur will gain you more precision. - Note that (at least in CS3) the eyedropper can actually display 16-bit values. In the info panel where the values are displayed note that there is a tiny tiny arrow next to the little eyedropper which if you click you can choose 16-bit display values. - In the middle portions of the exposure the results were surprisingly consistent, density interpolations varied by less than 1% from exposures differing by 1eV. Nonetheless, as stated above you can have a systematic error if the illumination is not even enough. - One might be able to use Photoshop's "Merge to HDR" feature to combine all your exposures into a single one for measurement. I haven't tried this. - Given it appears you can get a pretty amazing Epson scanner (16-bit per channel, LED illumination, 3.2 Dmax, built in transparency adapter, 4800 optical DPI) for just $100 setting up the camera and doing multiple exposures may be more trouble than it is worth. That said, using the reference wedge and doing cubic spline interpolation to get accurate results would still apply with scanned input. Well, hopefully this helpful to someone someday. At least it is here in the archives now... Ken
