[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Clayton
Jones
Sent: Friday, January 16, 2009 7:08 PM
Subject: [Digital BW] Re: Epson ABW
Hello Brian,
>I have been experimenting with different B&W tones using the ABW
>driver. When I set the tone to Warm and Light, I have noticed that
>no yellow seems to be used, at least, after many prints my yellow
>cartridge is still showing full. When I set the tone to Neutral and
>then adjust Horizontal and Vertical each to -15, I see yellow being
>used. What's up here? Has anyone else noticed the same phenomenon ?
I'm not sure about the yellow, but I think that when you select one of
the preset tones, such as Warm, that all it's doing is moving the tone
controls to preset values. Try selecting each tone from the list, and
after each one see what the values are.
One experiment that would be quick and easy is print a step wedge
using "Warm", then print another by manually setting the controls to
the same values. If a different set of inks is used they should be
different.
Clayton
