HP 8850 for glossy B&W?
2009-01-25 by Roger
I'm thinking about the HP 8850 or 9180 for larger than letter sized
glossy B&W.  I currently use UTR2 in a letter sized R220 and like it
but haven't had much luck getting 3MK to work in a R1800, and it
doesn't do gloss-type papers anyway.
I wondered how the bronzing and gloss differential is on papers like
Epson Premium Semigloss, Silver Rag, or Harman FB Al Baryta?  I'm
looking for print quality on par with the entry-level R220, which has
next to no bronzing and gloss differential is hidden on papers like
the Harman.
Re: [Digital BW] HP 8850 for glossy B&W?
2009-01-26 by Tony Sleep
> the Harman.
The HP's have 3 B&W modes.
- Black & gray only is very neutral but only works on matt papers (on
which it's excellent). Bronzing and GD is substantial on gloss papers,
though can be largely cancelled by overcoating with lacquer. I've seen
very good B&W on Harman FB AL glossy from the Z3100, which has a GLOP
channel - probably the closest ever to unglazed bromide. The extra gray in
the Z3100 (over the B9180/8850) doesn't make much difference. It is the
gray ink/s that are responsible for bronzing on gloss.
- Composite B&W largely avoids bronzing and GD and gives a slightly better
DMax, but the tone colour is cyan-magenta (varies some depending on paper
used), and cannot be controlled. Unfortunately there is no ABW-like
facility to alter tone colour, and that makes composite of limited use.
- Print B&W as colour. Best DMax of the lot and minimal bronzing and GD
with gloss papers. This is (far) my favourite (for printing quadtoned B&W
converted to sRGB). Quality and visual appearance on papers such as the
Harman is excellent, matching or exceeding papers such as Agfa Record
Rapid from the 1970's before Agfa ruined it by removing the cadmium for
environmental reasons. This is really rather wonderful from my PoV; I have
30+ years experience of darkroom B&W and gave it up because my favourite
materials had disappeared or been reformulated to mediocrity. However I
favour warm tones. If you are chasing neutrality I think you'll struggle.
The HP's do have some issues with curl (due to expansion of the coating
when wetted) causing headstrikes with large sheets of most baryta papers,
but this can be largely avoided by careful dressing of the paper before
insertion, and supporting the paper at the rear of the printer. Printing
borderless is best avoided too.
I've not used Hahnemuhle Silver Rag but Neil Snape reviews it with the HP
at www.neilsnape.com
You'll find much more info about these issues and relative quality of the
different modes on these and various other papers at
http://groups.yahoo.com/group/hp9100/
Tony Sleep
http://tonysleep.co.uk
Re: HP 8850 for glossy B&W?
2009-01-26 by Barrett Benton
Tony's recital of the issues printing glossy black-and-white with the
8850 and 9180 are the reasons I've stuck with HP's Photosmart 8750 Pro,
which does wonderfully with HP's Premium Plus glossy and
satin/soft-gloss papers (yep, the Vivera inks used in the 8750 are
primarily dyes, but appear to be *quite* stable with HP's swellable
papers). THe 8750, alas, was discontinued some months back, with no
mention of a replacement. The bese we can hope for now is for a little
more of the Z-series' tech to trickle down to HP's 13-inch-carrier line
(GLOP would be a good start). Meanwhile, my 8750 stays put.
- Barrett
