Diluting HP PK
Diluting HP PK
2009-02-06 by hp9180profile
Paul, I read with much interest your Carbon 6 whitepaper, updated to
include the HP-C6 variation. I just have one point I would like to
clarify if I may.
The main advantages of the HP PK over the MIS PK are twofold - its
neutrality (perhaps even coolness) and its ability to print diluted on
matt papers. Have I got that right or do other factors play here as
well?
Thanks and regards
Alistair
Re: Diluting HP PK
2009-02-06 by pr_roark
to
> clarify if I may.
> - its neutrality (perhaps even coolness) and
> its ability to print diluted on matt papers.
Glossy and matte papers, as opposed to the matte only for the Eboni-
based carbon inksets.
> Have I got that right or do other factors play here as well?
It is easy to keep in suspension -- a defect with the Eboni-based
inskets.  And, we at least have Wilhelm tests of the pigments
themselves.
The bar has been raised big time for B&W types since the large OEMs
entered with at least fairly serious systems.  For the top end, I
think I can defend third party 100% carbon, but I don't think I can
defend third party color, which is used in neutral "carbon"
printing.  Keep in mind that there are no problems for the vast
majority of desktop  users, but I'm interested in challenging the
best and with wide format.  Right now, I think the HP ink looks the
most interesting for this segment, but I don't want to buy a Z3200
for the volume of large prints I do.
Re: Diluting HP PK
2009-02-07 by Paul Whiting
> inksets.
I didn't know this.. does that mean we should agitate the cartridges
from time to time? I use refillable cartridges and a friend tells me
that their back and forth motion at start-up serves to agitate them. I
know that with CIS you can shake the bottles occasionally.
> themselves.
> printing.
I've been in touch with the National Register of Historic Places
lately, and sent them a few 3MK prints on Moab Lasal done on my R1800.
It's tough to keep a dialogue going, they're rather busy, but they do
seem interested. After studying Wilhelm's site, I see he approves of
the R1800 with K3 inks and has charts of expected life span which
would easily meet the Register's 75- year requirements. But doesn't
the K3 process, although carbon-based, still use some color pigment
inks, thus weakening their longevity over against pure carbon? (I
should add I'll probably switch over to a non-OBA paper soon, I'd like
to try that Premier Art you seem to use a lot.)
My basic thinking is that since carbon-based 3MK, with touches of
color pigment, easily meet Register standards then pure carbon should
be a no-brainer.
I wish there were some way to get the 3MK process on Wilhelm's charts.
Do you know how to reach him? I didn't see any contact information on
his website.
I'll be interested to see how your HP work develops. Perhaps that
process will eventually make Wilhelm's list.
Thank you!
Re: Diluting HP PK
Oops.. make this paragraph read "3K", not "3MK". Coffee hasn't kicked
in yet.
"My basic thinking is that since carbon-based 3MK, with touches of
be a no-brainer."
Re: Diluting HP PK
2009-02-07 by pr_roark
> > inksets.
> I didn't know this...
Nor did I -- thus the centrifuge to, hopefully, not get caught this
way again.  The range of Lab L changes in a 30 minute spin range from
0.03 % (HP-C6 LK [30% dilution]) to 30% (guess -- choke).
> from time to time?
Yes.  In normal use, desktop printers keep the dilute Eboni (both
Eboni-6 and Carbon-6) well suspended.  However, if the carts are
sitting on a shelf, they should be agitated, probably weekly.
> to agitate them.
Exactly.  It's the wide format printers that are the more likely
problem area.  I do still have Eboni-6 in my 7500, but the carts
require manual agitation.  In all my PDFs I stopped recommending
these inksets for wide format as soon as I discovered the problem.
> I know that with CIS you can shake the bottles occasionally.
Yes, and the problem really didn't show up in the 2200 I had with
Carbon-6 for 9 months.  I agitated the bottles occasionally, and the
carts do have ink in them that gets agitated.  So, the fluctuations
in density appear to get averaged out.
It does not appear that the "settlement" is causing significant
agglomerations of Eboni, it just gets darker at the bottom and
lighter at the top.
Note that I'm still a big fan of Eboni MK.  I probably will never be
able to test it long enough, but I would not at all be surprised if
it could beat the HP neutral grays in a fade test.  The HP PK and
grays are, after all, blended carbon-colol pigment inks.  The things
HP has done, however, that I was not able to do with third party
inks, include using very lightfast colors, balancing the fade rates
to avoid tonal shift (see a discussion of my early efforts at
http://tech.groups.yahoo.com/group/DigitalBlackandWhiteThePrint/messag
e/58048), and advanced pigment suspension via a new coating that
stops the different types of pigments from stratifying.
So, it looks like we have a new and superior PKN.  But, I still
believe a good carbon that can actually print neutral without color
inks (i.e., Eboni with a 1.5 pl printer and not diluted) will be a
better neutral matte inkset.  But, until Epson makes a 1.5 pl wide
format printer, I need a more stable insket for the 7500 (I'm tired
of picking up the 7500 and shaking it), and I think many will
appreciate an advanced, neutral and affordable inkset for their
Epsons.
> my R1800. It's tough to keep a dialogue going, they're rather
> busy, but they do seem interested.
Do they do their own testing?
> the R1800 with K3 ...
Do you have a URL for what you're looking at?  I assumed he just
tested the 1800 with OEM color inks in it.
> ...doesn't
The 2400 3K B&W "ABW" mode prints definitely use color.  I don't know
of a 3K 1800 approach aside from the 3-MK one using Eboni, and I know
of no fade tests of that by any commercial testing group.
> should be a no-brainer.
Yes.  I'm curious where the "3MK, with touches of color" is coming
from.
> Wilhelm's charts.
So do I.  I've never had any significant contact with him.  My
impression is that his tests are just too expensive for little
outfits like MIS.  (It's a shame the supplier hasn't picked up this
ball -- hint.)
While I am convinced Wilhelm is very reputable and a very good
person, I don't think he's a charity.  It would be great if he'd do
some "pro bono" work, but I've never seen any indication of this with
respect to the inks we use.
Re: Diluting HP PK
2009-02-07 by Roger
Aardenberg's tests of Image Specialist inks in a few printers should
give some comfort regarding the fading of Eboni MK- unlike the color
inks it proved quite stable.
It is too bad MIS or Inkrepublic won't pick up the tab for Wilhelm's
tests, or for Epson to do it as they may have as part of a comparison
of third party dye inks and papers (which clearly discredited these
inferior products).
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
<pr_roark@...> wrote:
> > > inksets.
> > from time to time?
> > to agitate them.
> lighter at the top.
> Epsons.
> > ...doesn't
> from.
> > Wilhelm's charts.
> ball -- hint.)
> Paul
> www.PaulRoark.com
Re: Diluting HP PK
> > my R1800.
I don't believe so... here are two links from their site:
http://www.nps.gov/history/nr/policyexpansion.htm#digital
http://www.nps.gov/history/nR/publications/bulletins/photopolicy/photo_policy_checklist.htm
Here's a link for the 2400 using 3K Ultrachrome and ABW. (I thought it
was for the 1800, sorry): http://www.wilhelm-research.com/epson/R2400.html
As you confirmed later in your message, this process does use some
color. Still, Wilhelm's projected longevity for these prints exceeds
the 75 year standard required by the Register, and therefore our 3MK
carbon prints should do just as well and better.
> > My basic thinking is that since carbon-based 3MK prints, with the
> > ABW touches of color pigment, easily meet Register standards
> > pure carbon should be a no-brainer.
> from.
I meant to say 3K, sorry.
> > Wilhelm's charts.
> outfits like MIS.
His work has really taken off ... back in the 70's (dates me!) I
ordered a print washer from him as mentioned in the Whole Photography
Catalog, remember that spin-off of the Whole Earth Catalog? His
pioneering work with this excellent print washer was probably an early
presage to his interest in archival issues.
Re: Diluting HP PK
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger"
> inferior products).
Hello Roger,
Help me clarify what you are saying... did Wilhelm do these
comparisons, or Epson? And which are the inferior products? Sorry, I
got a little lost as in "Who's on first?, no, who's on second", etc. !!!
Thanks!
Paul W.
Re: Diluting HP PK
2009-02-07 by Roger
Wilhelm did them. Someone must have paid him so I'm speculating an OEM
maker like Epson did.
http://www.wilhelm-research.com/dpn/DPNow_3rdPartyEuropeanInk.pdf
http://www.wilhelm-research.com/hardcopy/WIR_AftermarketTests2006_05.pdf
The third party dye-based inks are far inferior to OEM dyes.
I was suggesting that maybe Epson would be interested in supporting a
similar round-up of third party pigment inks to clearly differentiate
between OEM and aftermarket.
> Hello Roger,
> Thanks!
> Paul W.
Re: Diluting HP PK
2009-02-08 by robert49brake
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger" <rsmith02@...> wrote:
If Epson pays Wilhelm to test inks the results will belong to Epson and will be released by Wilhelm only if Epson
authorizes that release.  If we want Wilhelm testing we'll have to pay for it.  Correct me if I'm wrong but I don't see
Wilhelm selling subscriptions like Consumer Reports.
Re: Diluting HP PK
2009-02-08 by Roger
Yep, that's right.  And Epson would certainly release it when they
blow (some) aftermarket color pigments out of the water.
The Aardenburg folks have more of the Consumer Reports model,
including reporting your own experiences (you can sign up for testing
using your particular inkset/paper
http://aardenburg-imaging.com/acceleratedagingtests.html ).  I find
their results more interesting than WIR as they show you fading per
color over time.
You can subscribe here and get full access to their database:
http://aardenburg-imaging.com/membership/membership1.html
Re: [Digital BW] Re: Diluting HP PK
2009-02-08 by Ernst Dinkla
> lighter at the top.
With the 9000 + my own CIS loaded with MIS VM and the 10000
with MIS 7600 the least of my problem was actually the
Eboni. The PK and lighter shades were worse on the 9000, the
ML and the Y on the color model. The 9000's shaking wasn't
enough to keep them suspended, the tubes showed
agglomeration and the dampers collected the particles so got
blocked. It worked excellent in the first year. Best case
was when a lot of work had to be done with fresh loads of
ink. It got worse in the end but even then the Eboni channel
could be kept open quite well. When looking back I am sure
the time to keep things going wasn't worth the ink price
difference on the last color model. There was no other
choice for color 8 years before than Generations and we know
there was no other choice for B&W 4-5 years ago.
I'm no longer a candidate for CIS developments but a CIS
based on HP carts with an actuator to let the pumps work on
a regular schedule would be a nice construction but even
then the tube contents should at least be renewed once a
week by some printing done.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
Of course the third party dye inks selected had to be worst
case, an OEM like Epson wouldn't pay for a test of a third
party  ink that had chances to be equal or not that bad.
Dye inks like the HP Vivera dye, the Ilford Archiva dye (and
the Lincoln inks for Epson based on it), the Epson dye that
was used in the 10600 dye model and the MIS clone of it are
not that far apart if used on compatible papers. Not the OEM
pigment fade resistance but much better than 90% of the
dilutions you can order on the web.
It's a long time ago that Mediastreet's Generation pigment
ink has been tested by Wilhelm, Lyson's Lysonic and Fotonic
dye by the same institute (and failed), MIS hybrid inks by
RIT and some lesser known brands by Wilhelm.
Aardenburg is the better concept in test method and
organisation but it will be difficult with the hard times
ahead. Let us hope that some institutes like musea etc get
involved. The German Image Engineering that does its tests
for magazines is less sophisticated in test method but could
possibly stand the time better by its other financing
structure. Time will tell.
|             ( unvollendet )            |
2009-02-08 by pr_roark
> Eboni.
Full strength, 100% Eboni is not really a serious problem.  I'm not
sure if it stays in suspension better at the higher loads (some
electrostatically stabilized pigments appear to) or if its just that
at that high pigment load the load-to-print density relationship is
so non-linear that we don't notice the changes.
I've rather assumed that the weaker a color pigment is, the larger
they grind the particles in an attempt to offset the oxidation rate
with size.
One thing I used to do is just put a drop of the dense ink into the
base and see if there was visible settlement.  Both MIS M and Epson
UC M showed settlement at the bottom of the test tube.  Eboni did not.
>... the Eboni channel could be kept open quite well.
I continue to favor Eboni in the K position.  I think it's a great
MK, but I just do not know how to keep it stable *when diluted* (nor,
apparently, does MIS and its supplier).  Again, in the desktop
printers, this is really not an issue.
2009-02-08 by Roger Sopher
Kind of sounds like eboni has a small net negative surface charge  and a
relatively large particle size. That would tend to keep the particles in
suspension when fairly concentrated and allow for a more rapid sedimentation
when relatively dilute. One sees the same phenomenon with red cells. The
matrix effect of the suspending liquid can influence the surface charge but
I am too many years away from this kind of chemistry to go much farther...
Roger
Reply-To: DigitalBlackandWhiteThePrint
<DigitalBlackandWhiteThePrint@yahoogroups.com>
Date: Sun, 08 Feb 2009 16:15:05 -0000
Subject: [Digital BW] Re: Diluting HP PK
> charge  and a relatively large particle size.
> more rapid sedimentation when relatively dilute.
That's exactly what I suspect.  The various forces that seem to be at
work are effective at different distances.  There may be a specific
distance at which the matrix of particles are in relative
equilibrium, but when diluted that average distance is too much.  So,
they tend to settle back into the more stable, denser matrix.
The centrifuge I'm using is a used medical lab desktop unit.  I
assume blood separation was it's main purpose.
> The matrix effect of the suspending liquid can influence
> the surface charge ...
I've tried to find a different base mix that would help, but so far
without success.  Frankly, I think the supplier is in a better
position to know which way -- if any -- to go in this respect, so I'm
not going to put more effort into dilute Eboni.  It's a very nice
100% MK, and the diluted Eboni mixes work well on the desktop.  Wide
format diluted Eboni, however, is not recommended (even though I'm
still using it).
2009-02-08 by Greg
> It's a very nice
> still using it).
> Paul
> www.PaulRoark.com
Paul, does it settle in the ink lines or just in the carts? If it is
stable in the lines then you could probably make a vibrating mechanism
that keeps the carts agitated enough to keep it in suspension. Inside
the 9000/9500 there would be plenty of room in the cartridge holder
box to strap a motor with an off balance wheel to cause a vibration
(pager/cell phone vibrator), not sure about the 7000/7500. Would
probably be easy enough to rig up a timer that runs it for 30 minutes
every couple hours and always when the printer is turned on. That
said, when the printer is printing there is a lot back and forth
movement of the inks. This has something to do with the movement of
the tubes as the head moves back and forth. Net change is several ml
of pulsing. Maybe not as much on the 7xxx since the lines are so much
shorter, but very apparent on the 9xxx when you build a bottle system.
I'm not sure, but I think it's the wide format printer carts where
the problem is.  From what I can tell once the 7500 starts to print
the dampers and lines get agitated enough to take care of whatever
problems may have been there.  Also, the dilute Eboni positions in
the 7500 virtually never show a bad nozzle check even after
relatively long periods of non-use.  (The 100% Eboni will sometimes
need a cleaning cycle.)
> If it is stable in the lines then you could probably make a
> vibrating mechanism that keeps the carts agitated enough
> to keep it in suspension. ...
You're probably right.  What I do now is just roll the cart end of
the 7500 back and forth occassionally -- vigorously.  It's actually
very simple.
But if I didn't have very clear warnings about this problem in my PDF
and here there would be too many people who would put the inkset into
wide format type printers (including 3800) and then complain loudly
that the inkset is a dog.  Likewise the 1800 sponge-
containing "spongeless" MIS carts that cause a tone change with Eboni-
6.  These types of problems really blow up for MIS and I if the
issues are not very clearly disclosed when found and avoided whenever
possible.
I might add that the old sepia and other blended inks in MIS mixes
also have these problems, as discussed at page 4 of
http://www.paulroark.com/BW-Info/4K+.pdf
This tone shifting problem was first noticed by a wide format user
who did not use a stand.  Those of us who regularly printed with a
stand found that the rocking of the stand did the job -- as long as
the printer was used often.  But if no stand is used -- as in many
3800, 4000, etc. installations -- these problems can (will) show up
even with regular use.
One of the interesting issues with the HP neutral pigments is whether
HP's pigment and stabilization advances will avoid this even when the
inks are diluted.  The HP neutral greys and PK are blends of
different types of pigments from what I can tell, and the literature
on pigment stabilization is consistent with what I've seen -- blends
tend to separate.  Particularly with electrostatically stabilized
matrices, the particles that are dissimilar just don't fit in as
well, so the fall out of the matrix.  The trick appears to be to very
closely match the pigment characteristics that affect the
stabilization.  So far, the tone changes I'm seeing with the HP
pigments in the centrifuge tests -- diluted or not -- are minor.
2009-02-08 by Greg
> very simple.
Since the 9000/9500 has carts in both ends, a different agitation may
need to be used. I've often thought about adding a brace to the 9500
to stop the swaying when printing, maybe making it stiffer would be a
bad idea.
Red cells have a net negative surface charge and repel each other. The
surface charge can be modified by the composition of the protein matrix
surrounding them. For example, if one has an acute inflammatory condition
the charge on the red cells is diminished and they tend to clump forming
larger ³particles² and fall out of suspension more rapidly. This is more or
less the basis for the old ESR (erythrocyte sedimentation rate) test. If the
problem were in the concentrate then it might be possible to find a
suspending medium that would increase the surface charge on the particles.
In a dilute system that would have little or no effect. Sounds to me that
diluting eboni is fighting physics. I suppose it would be possible to boost
the viscosity of the suspending fluid but that would open a whole other can
of worms and would only slow not solve the sedimentation problem.
Roger
Date: Sun, 08 Feb 2009 17:38:34 -0000
2009-02-09 by pr_roark
> Eboni. The PK and lighter shades were worse on the 9000, ...
That made me curious about how the MIS PK and Epson UC 7600 PK would
do in a centrifuge test if both were put into 10% dilutions of my C6
generic dilution base.  A couple of us are looking at using the C6
base to dilute PKs for use in warm carbon channel to go with the HP
cool dilutions.  The results of a 30 minute spin were that the 10%
MIS PK had a change in Lab L (top of test tube to average) of 0.4%.
The 10% 7600 PK changed 1.4%.  (A lower change is better.)
The relationship of the Lab L change to Lab B was the same as I've
seen within other black pigment types: The larger the change in Lab
L, the cooler the pigment.  Here the MIS 10% PF in the draw dawn on
EEM had a Lab B = 4.4.  The 7600 had a Lab B = 2.8.
For comparison, Eboni-6 Y (the lightest at 2% Eboni and also the most
stable of the Eboni dilutions) has a Lab L change of 2.9% and a Lab B
= 1.3.
I've put a graph of these results on the web at
http://www.paulroark.com/BW-Info/light-Warm-Spin-Graph.jpg
Here, heavier appears to correlate with cooler.
2009-02-09 by Michael T. Murphy
> channel to go with the HP cool dilutions.
Thank you for all of the research and information sharing Paul.
I have been looking for a good "photo black" only (glossy and semi-
gloss) ink set.  I am going to let the matte papers go in favor of
the new baryta's, and the standard Epson Luster etc., that I use for
color printing.
After testing the Carbon 6 on matte papers last year, I mixed up a
test "glossy" ink set for my 7600 using the Epson PK and the C6 base
last summer.
I wound up with a 5K+GLOP ink set that I was quite happy with.  I was
going to use the last channel for a magenta/cyan toner ink, but never
quite got around to it. ;>)  The PK mixture was a bit brown and
green, as expected with the Epson, but I was happy with it for
proofing.  I never envisioned using it as a final ink set.
I also mixed up an Epson PK ink set on the 2200 using the 3 K3
blacks - PK, LK, LLK.  I saw no real reason to prefer that ink set
over the one on teh 7600, just starting with PK and making my own
dilutions using the C6 base.
I am going to try the same kind of mix using the HP PK, as you have
outlined.
To make a set of 250 ml cartridges of eack ink in the 5K+GLOP mix
requires about 500 ml of the base "K" ink to start. To mix, I just
used 250 ml bottles and put 1/2 as much K ink in each successive
bottle as in the preceeding. Then I "filled up" the bottle with the
C6 base.
So I started with 250 ml of K in the first bottle, then 125 ml, 60ml,
30 ml, and 15 ml, and finally 5ml for a 6K set.  I need to take a
close look at the Lab A and Lab B tone curves of an HP PK only mix
and decide on the final channels.  I will probably try a 6K+GLOP with
all HP PK and no toner first, then see if I really need a toner. I am
not quite as obsessed with longevity and will probably just use color
inks as toner in the 6th "K" channel if needed.
Cost would be for two double-packs of the 130ml HP PK carts, or about
$200 from mpex.com, plus the small cost of the C6 base (maybe $10?).
That will make 6 x 250 ml = 1.5 liters of ink. Add in about $25 for
250 ml of GLOP if I remember pricing correctly ($50 per 500 ml?)
It may be a week or 2 before I have a chance to mix and profile the
inks.  Just getting back after many months off (neck pain problems.)
Best,
Michael
(Was:Re: Diluting HP PK) HP PK BO?
2009-02-09 by scott_now_coming
Pul,
Have you tried the HP PK in a B.O. situation? Will it work in the 1400?
It would be great if it would work in the 1400 and could print on the
papers such as Ilford Gold Silk.
Scott
2009-02-10 by pr_roark
> gloss) ink set.  ...
> I mixed up a test "glossy" ink set for my 7600 using the
> Epson PK and the C6 base ...
> The PK mixture was a bit brown and green, ...
On my draw-down test of the 10% Epson PK, 90% C6 base mix on EEM, I
measure a Lab A = 2.1 and Lab B = 2.8.  So, I don't see any green,
though it is warmer than I like.  Maybe this is mostly a matter of
what paper is used, and I did not test this mix on any glossy paper.
Did you have any problem with clogging or inconsistent ink densities?
> outlined.
> I am not ... obsessed with longevity and will probably just
> use color inks as toner in the 6th "K" channel if needed.
I think the Wilhelm HP numbers give sufficient confidence for most.
One of the major concerns with color inks in B&W is the differential
fading and green or other tone shifts.  In this respect, not only do
the superior HP color ratings give confidence, but a major part of
the HP effort here has apparently been to get color pigments that
will fade evenly.  So, they've really focused on the issues we've
discussed here over the last several years.
Keep us posted on your progress.  Right now my test 220 is sitting
idle for the month to see if it'll clog with the HP mix.
I have not tried the HP PK in the 1400.
I did print with the HP stock Grey ink in my 1800, and it didn't micro-
band any worse than the other B&W inks I've used in the printer when
only one jet is working.  While this doesn't tell us a whole lot, at
least the results did not show any problems that clearly related to the
HP ink.
Yes, it could be interesting.
In addition to whether the ink will print well print is whether the
viscosity is at least high enough to stop the ink from running straight
through the head.  This would get expensive.  In one stored printer I
found that the cleaning fluid that was made with 50% MIS base and 50%
water had simply run through the heads and emptied the carts.
I just printed a 1400 HP-PK black only test strip on some old
Kirkland glossy paper.  With QTR I was able to get a dmax of about
2.4.  The tones are shown in this Lab A & B graph:
http://www.paulroark.com/BW-Info/1400-HP-PK-BO-Kirkland.jpg
The reflective artifacts are minimal.
With normal reading glasses, I can't see individual dots, but I do
get a sense that it's not totally smooth.  Even with a magnifier, I'm
not seeing any microbanding.
So, although I can't say anything about clogging or other issues that
might crop up, it looks like it'll work quite well.
I'd had 30% HP-PK mixed with 70% C6 base in that spot, sitting idle
and next to the Eboni, in the yellow spot, for about 3 weeks.  All
inks had a perfect nozzle check after these two inks had been sitting
idle for this amount of time.
2009-02-11 by pr_roark
A full image on the Kirkland paper has low enough reflective
artifacts that I don't think any glop is warranted.  A smooth sky is
still smooth; there was no build-up of grain that way we've seen with
the 3-MK process.  So, it looks good.
Ilford Gold FB hits a dmax of 1.72 at an ink limit of 100.  The tones
are very neutral through the midtones. See
http://www.paulroark.com/BW-Info/HP-PK-Ilford-Gold-tones.jpg
I'm not thrilled with the "glittery" reflections of the Ilford
surface, but overall, this is looking like an impressive approach if
it doesn't clog.
2009-02-11 by Greg
Paul,
In the testing that you've done, have you noticed any oddities from
spraying the HP inks in a piezo head? Just wondering if the lack of
heat is helping or hurting the ink.
> Paul,
So far, the prints made with HP PK look just like ink that was designed
for Epsons.
2009-02-11 by Ernst Dinkla
Greg wrote:
> Paul,
Greg,
I wondered about that too but in reality just a very small
amount of the ink vaporises to blow the droplet out, a
pi\ufffdzohead will create heat as well when it is working. In
the end both are cooled by the ink flowing through.
|             ( unvollendet )            |
RE: [Digital BW] Re: Diluting HP PK
2009-02-12 by Gary Wagner
Paul,
What about diluting Epson black K3  inks. Have you tried them and what were
the results?
Gary Wagner
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of pr_roark
Sent: Tuesday, February 10, 2009 10:36 PM
> Paul,
for Epsons.
HP PK BO
2009-02-20 by pr_roark
I wanted to update and correct my previous post on printing Black
Only in a 1400 with full strength HP Z3100 PK.
First, after just over 1 week on sitting idle, the 1400 had no clogs -
- a perfect noozle check.  I had the HP PK in the Y position, which
is right next to the Eboni K position.  PK next to MK has been the
most likely to cause clogs in other printers and with other PKs.  So,
going a week with no clogs might indicate that the HP PK is at least
not more likely to clog than other PKs.  The 1400 also has Eboni-6 in
2 position (and a full 3MK of Eboni).
Second, I found a significant error in my previous post.  The 1400
with HP PK on Crane Silver Rag hits a dmax of 2.72, not 1.72 as
written in the original post.  The 2.72 100% QTR patch has now
dropped to 2.61 after over a week of drying.  Needless to say, this
is outstanding.
> > some old Kirkland glossy paper.  With QTR I was able
> > to get a dmax of about 2.4.
> A smooth sky is still smooth; there was no build-up of
Wrong -- it hit 2.72.
> The tones are very neutral through the midtones. See
> approach if it doesn't clog.
> Paul
> www.PaulRoark.com
Re: HP PK BO
I've posted a graph of the Crane Silver Rag tones when printed with
HP PK, black only, on the 1400.  See
http://www.paulroark.com/BW-Info/Tones-HP-PK-CSR.jpg
CSR even hits 2.4 with the 50% dilution of HP-PK that I'll likely use
in a matte-paper, 7500 inkset.  This will allow me to print very good
glossy prints when I need to, and on a very stable no-OBA paper.
(Most papers have weak maximum blacks with the 50% dilution.)
The previously posted tone graphs are linked to below.
> Ilford Gold FB ...
> Old Kirkland glossy paper ...
Re: HP PK BO
2009-02-22 by Randy Rancier
Paul, I am very excited about trying the HP PK  since I generally like the higher dmax you
can achive with the newer semi-glossy fiber based papers, especially after reading the
high dmax you are obtaining with the Cranes Silver Rag paper (over 2.6 after several
days... WOW!  I can't wait to see this for myself).  I am using the 1400 with the UT14 inks
and have been generally pleased with their flexibility.
I am considering replacing the cool PK in the UT14 inkset with the HP PK as you have
mentioned in this thread; I am also wondering about using a dilute HP PK in place of the
light PK in the UT14 as well, since you had mentioned that you sensed that the HP PK BO
approach wasn't totally smooth.  You had also mentioned in one of your post that the
dilute HP PK has some bronzing or gloss differential that GLOP may help with.
My questions:
***Since I like printing primarily on the semi-glossy fiber papers I am wondering if GLOP
might be a suitable base to dilute the HP PK, as I believe i've read some people doing with
other inks???  I figure this might help with the bronzing and gloss differential with the
dilute HP PK.  What are your thoughts on this?  If this is possible what do you think a good
dilution ratio would be to help smooth out the print?  Perhaps a 30% HP PK and 70% GLOP;
or maybe even substituting some C6 base for part of the GLOP if this would be too high of
a GLOP ratio in the mix, perhaps adding some Edwal LFN?  Another question, if it is
possible to use GLOP as a diluting base would it still be compatible with matt papers;
which isn't a major concern of mine, but would be nice for proofing?***
Some background of what I have achieved with the UT14 inksets:  After getting through
the learning curve with QTR I was able to profile or create cool and warm curves fairly
quickly for Epson Double Sided Matt, and ILFORD Gold FS and combine the two curves to
create a fairly neutral print; achieving a dmax just under 2.30 on the Gold FS.
I was inspired by what you wrote about creating a fairly neutral 100% carbon glossy print
using the Eboni in the K position and using the warm PK to get a higher dmax, which
must have a protective spray of Premier Print Shield to prevent the Eboni from smearing.  I
started with your EB_ILFORDGold_Spray_3.qidf file and tweaked it some and raised the
GLOP level to a little over 60%, to reduce the gloss differential at the higher percentages,
and was able to achieve a dmax of around 2.50 after spraying with Print Shield; i have
noticed that it drops slightly after a few days, still in the mid to higher 2.40's.  I also
noticed that the higher dmax was primarily due to the Print Shield as the dmax was quite
a bit higher after spraying than before spraying.
I was blown away with how much "richer" the blacks and shadows were in the 100%
carbon glossy print looked when compared to the neutral equivalent using the cool/warm
blend of PK only inks.  There was much better separation in the shadows which revealed
better shadow details.  The 100% carbon prints just looked richer with a greater depth,
deeper perceived blacks than with the PK only prints.
That is what I liked about the 100% carbon glossy prints on the ILFORD Gold FS.  What I
didn't like about them was the visible dots or graininess, although at normal viewing
distances isn't that bad, but it would be nice to get smoother mid-tones.  They are also a
little warmer than what I would like, although it is a beautiful warmth that could grow me;
I would say it is certainly on the warm side of neutral, at least with the Gold FS, which
tends to produce very warm results with the warm PK inks in the UT14 inkset.
Sorry for the dissertation, I didn't mean for it to get so long, but felt that others might be
interested in what I am desiring to achieve and my results so far.
Much thanks for your input,
Randy
> is outstanding.
> Paul
> www.PaulRoark.com
> > Paul
> > www.PaulRoark.com
Re: HP PK BO
2009-02-22 by pr_roark
"Randy Rancier" <randy_rancier2004@...> wrote:
> I am very excited about trying the HP PK ...
> with the HP PK as you have mentioned in this thread ...
> My questions:
> papers I am wondering if GLOP might be a suitable base to
> with other inks???
The HP pigments are coated.  So, they do not need the binder in glop
to hold them down.  I'm not sure if the glop as a base would lead to
more clogging or if it would reduce bronzing. I'd probably stick to
the C6 base, with the Edwal wetting agent, using glop as a separate
channel, the way it's currently set up in UT14.
>...what do you think a good dilution ratio would be to help
> or maybe even substituting some C6 base ...
Yes.
Yes.
Let us know how it works out.
Re: HP PK BO
Thanks Paul, one question I have about using the the Edwal LFN that I was not sure about
when reading your pdf was, is the LFN used in place of, or in addition to the Photo-Flo in
the C-6 base?  Also, if I experiment some and try to dilute the HP BK with GLOP, instead of
the C-6 base, do you think I should add some LFN to the mix as well?
Your input is greatly appreciated,
Randy
> > My questions:
> > with other inks???
> Yes.
> Yes.
> Paul
> www.PaulRoark.com
Re: HP PK BO
> ... about using the the Edwal LFN ...
> the C-6 base?
The Edwal LFN is used in addition to the Photo Flo in the latest C6
base mix (sometimes referred to by me as "C6c").  Photo Flo has yet
another surfactant in is as well as some glycol that is probably useful.
> ith GLOP, instead of the C-6 base, do you think I should
No, I'd be curious how the glop does as a base.  See if it, in fact,
reduces the bronzing.
Re: HP PK BO
Ok, I'll give the glop as a base a try as soon as I can get some of the HP PK.
Also, I'm curious if the HP PK from the HP Z3100, I believe you said you are using, is the
same as the PK used in the HP B9180 which i also have; I have been very impressed with
the B&W prints I get out of it and are beautiful, but I was concerned about their permanence, and thus the whole ordeal with the 1400.  It would be somewhat humorous
if the pigments in my HP B9180 were in fact more stable than the pigments in the Epson
inks.  I'll look at some of the references you have given on the Wilhelm test to see if the
inks from the HP B9180 are included in the test.
Randy
> Paul
> www.PaulRoark.com
Re: [Digital BW] Re: HP PK BO
2009-02-22 by Ernst Dinkla
> Thanks,
> Randy
AFAIK the B9180 Vivera pigment inkset is the same as the one
of the Z2100 + Z6100 which is again very similar to the
Z3100 inkset. Where the last has the extra Orange, Green,
Violet inks, the Z2100 and B9180 have two cyan inks instead
of the single one in the Z3100. The same 130 ml PK cart is
used for the Z2100 and Z3100. And for example the No 70
Photo black and Light Grey head is usable on both the B9180
and Z2100.
|             ( unvollendet )            |
RE: [Digital BW] Re: HP PK BO
2009-02-22 by Gary Wagner
Paul,
I would like to try the HP PK mix but am a little uncertain on how to
achieve the dilutions. I read the HPC6 article and it says to use by volume
62% distilled water, 28% glycerol and 9.7% Photo-Flo. I assume I will change
all of these to mls and create a standard clear base to use for all
dilutions is this correct?
I then add an amount of HP PK for the  50% and lesser amount for each other
dilution. Does this mean I would add 10ml of ink and 10ml of clear base to
make 20ml for the 50% dilution?
Also 4ml of ink and 16mls of clear base to make a 20% dilution?
I would like to do this correctly the first time before I make a big mess in
the kitchen.
Thanks for your help.
Gary Wagner
Sent: Sunday, February 22, 2009 8:16 AM
Subject: [Digital BW] Re: HP PK BO
> the C-6 base?
2009-02-23 by pr_roark
> > ... I'm curious if the HP PK from the HP Z3100, I
> > stable than the pigments in the Epson inks.  ...
Ernst Dinkla wrote:
> AFAIK the B9180 Vivera pigment inkset is the same ...
I believe the Wilhelm tests give an edge to HP over Epson.
The third party B&W inksets do rather well compared to the Epson ABW
mode printing, but this is probably due to the excess of color the
ABW mode uses.  If one uses QTR to print Epson OEM inks, I think the
story would be differnt.  I believe http://www.aardenburg-
imaging.com/ rates the Epson color pigment as better than the MIS
color pigments.
While MIS and Epson carbon inks are very lightfast, when it comes to
making a neutral inkset that uses color pigments to cool down the
carbon, the stability of the color pigments become very important to
the overall print stability.  This gets even more complex when one
considers differential fade of the different color pigments used.
Matching the fade rates of the color pigments is, quite simply,
beyond what I can do with the resources and time I have.  So, while I
think for the vast majority of desktop printers the MIS B&W inksets
such as the UT14 are very good, I expect the HP-PK based inkset to be
more stable, but it will not show up in a very long time.
I may be wrong, and will attempt to do a comparative fade test if and
when I'm actually using the HP approach more, but I expect that among
the inksets I use, only the 100% Eboni carbon approach (on non-
brightened paper) will be more stable than the HP-based inkset (on
the same paper).
> on how to achieve the dilutions. I read the HPC6 article
> and it says to use by volume 62% distilled water, 28%
> to use for all dilutions is this correct?
Yes.  I'd also use the 1% Edwal wetting agent.
> amount for each other dilution. Does this mean I would
Yes.
By the way, some are starting to use a 30% - 9% HP mix in a cool-
neutral channel and then LK-LLK in the other, warm channel.  If you
have a modern printer, this will probably work well and allow warm
printing and easy profiling with both the Epson driver and QTR.  Then
you can also use Glop in the Y position if you're doing glossy
printing.  You'd have to change black inks to switch between glossy
and matte.
My use of the 4 HP PK dilutions is aimed at my old 7500 with its
relatively huge droplets.  It needs the additional dilutions, but
this restricts my tones and glossy printing options.  Since I won't
be able to switch black inks, I'll at least have the 50% HP PK and be
able to print a good glossy on Crane Silver Rag, which gets a very
good dmax (2.4) with this 50% mix (other papers are down at about
1.8).  My focus is neutral images on matte paper, so this glossy
potential is a "just in case" solution that I don't recommend for
modern printers or those who want to be able to print a wider range
of tones on a wider range of papers.
Yes.
Good luck with the approach.  Let us know how it works out.
I'm still testing this approach.  I have a printer sitting idle that
I won't test again until the first week of March.  So far, I've seen
no problems with either the full strength or dilute HP pigments.
2009-02-23 by Gary Wagner
Paul,
Thanks for the clarification. I was planning on trying this in my 1400 which
currently has Eboni 6 in it. I am planning on leaving the Eboni K and LK  in
the printer and replacing the 4 other dilutions with the HP inks. I was
going to print on matte paper and initially use the Epson driver as I am now
doing with Eboni 6. Is this all correct?
My understanding is that by doing this I should get a neutral to cool tone
on most matte papers.
Gary Wagner
Sent: Sunday, February 22, 2009 7:23 PM
Yes.
and matte.
Yes.
Messages
<http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/95128;_y
lc=X3oDMTM2N25jM2FyBF9TAzk3MzU5NzE0BGdycElkAzM3MDIzMTEEZ3Jwc3BJZAMxNzA1MDE5M
TgyBG1zZ0lkAzk1Mzk0BHNlYwNmdHIEc2xrA3Z0cGMEc3RpbWUDMTIzNTM1OTM2NQR0cGNJZAM5N
TEyOA-->  in this topic (42)
<http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/post;_ylc=X3oDMT
JxMG43MXB1BF9TAzk3MzU5NzE0BGdycElkAzM3MDIzMTEEZ3Jwc3BJZAMxNzA1MDE5MTgyBG1zZ0
lkAzk1Mzk0BHNlYwNmdHIEc2xrA3JwbHkEc3RpbWUDMTIzNTM1OTM2NQ--?act=reply&message
Num=95394> Reply (via web post) |
JlMnRyOXFuBF9TAzk3MzU5NzE0BGdycElkAzM3MDIzMTEEZ3Jwc3BJZAMxNzA1MDE5MTgyBHNlYw
NmdHIEc2xrA250cGMEc3RpbWUDMTIzNTM1OTM2NQ--> Start a new topic
>... I was planning on trying this in my 1400 which
> the Eboni K and LK  in the printer and replacing the
> neutral to cool tone on most matte papers.
Yes, that should do it.
2009-02-23 by Paul Whiting
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" > I may
> the same paper).
Hello Paul,
The other Paul here, still hanging in with your 3MK approach. Glad to
hear your continued support of the 100% Eboni method as the most
stable. Sorry to have to tell you I still haven't heard back from the
National Register on my suggestion that they accept 100% Eboni prints
in nomination applications. I may have to nag them again soon.
Speaking of non-brightened papers, did one of your favorites get
discontinued, ie Premier Art Matt BW? Perhaps it was another of their
papers you preferred.
Paul W.
I thought it was a good, inexpensive matte paper.  However, there are
others that are very similar.  Red River's Polar Matte is about the
same -- very bright with a 1.70 dmax -- but also with a bit more weight
(225 gsm) and no curl.  So, it's a good substitute.
See http://www.redrivercatalog.com/browse/60lb-polar-matte.html
2009-02-24 by Randy Rancier
Paul, rather than diluting the HP PK with glop as I had discussed with you a couple of days
ago in order to try to reduce the bronzing and gloss differential, I was thinking that using
the other gray inks in the HP Z3100 inkset might work better.
If I was going to try this with just one of the gray inks along with the HP PK in the 1400,
which would you recommend using along with the HP PK; the HP Gray, or the HP Light
Gray?  I figured rather than trying to save a few cents per print and save the trouble of
mixing this might be a good alternative.  I also thought since this is an OEM mix that it
might do better as far as the bronzing and gloss differential is concerned.  What are your
thoughts on this?
I suppose one could use both the HP Gray and Light Gray inks along with the HP PK.  I
supposed I could put the light gray ink in the Y position instead of the glop if you thought
I might not need the glop with this approach.  But I did noticed that the HP Z3100 inkset
also has a glop included, so the glop might still be required; perhaps it is only required
for the "extra" glossy media.  Again, what are your thoughts on this.
Also, are there certain places where you have found the HP inks to be less expensive.  FYI, I know if you look around on the web for coupon codes HP has some usually $10 off per
$50 order and they deliver overnight for free to boot.  i usually break my order up into
smaller lots and use the discount with each of them, which has always worked for me.
Randy
2009-02-24 by Bill Morse
Try Provantage for HP inks.
Bill
On Tue, Feb 24, 2009 at 9:39 AM, Randy Rancier
> thinking that using
> PK in the 1400,
> HP Light
> the trouble of
> OEM mix that it
> What are your
> thoughts on this?
> HP PK. I
> glop if you thought
> Z3100 inkset
> is only required
> order up into
> worked for me.
> Thanks,
> Randy
Bill Morse
Wm. Morse Editions
http://www.MorseEditions.com/
2009-02-24 by Michael T. Murphy
Midwest Photo Exchange usually has the best prices, or close to it.
www.mpex.com
Great customer service if you get to know someone there. Web ordering
is OK, not always as good.
Best,
Michael
2009-02-24 by hp9180profile
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Randy Rancier"
with the HP PK.  I
the HP Z3100 inkset
Randy, having used the B9180 fairly extensively it is my experience
that the HP inkset really needs GO to avoid GD on all PK papers when
just using black and gray inks. GD does not show up using the full
color inkset to print BW but does so badly when just using the grays. I
guess that is why the wide carriage HP printers have GO on board.
Much thanks for your replies. I've decided to experiment by diluting the HP PK with glop
hoping that it will help or eliminate having to use glop from the Y position with other UT-14
inks on the 1400 as mentioned earlier in this thread.
Give me a week or two and I'll report on my results of using the HP PK for the cool PK and a
30% dilution of HP PK and 70% glop for the cool Light PK.  Otherwise, for those of us wanting
a better cool LT PK will have to use the C-6 base with a coat of glop.
Randy
2009-02-24 by pr_roark
The availability of the HP grey inks is part of why I like their PK.
Those who do not want to deal with diluting can just pony up the
bucks for the HP OEM inks.  They appear to use the usual
dilutions/densities, so the workflows should be rather transferable.
Be aware, however, that the HP grey inks also suffer from bronzing.
I think the PK black only might be the most free of it, probably due
to the high density of the inks.  I think I found the same thing with
MIS PK.
> the HP Gray, or the HP Light Gray?
I think the 1400 is smoth enough to just use an LK, but some do think
an LLK makes a visible difference.
Yes.
> I supposed I could put the light gray ink in the Y position
The HP inks bronze, so you may want glop in the printer.
Re: Diluting HP PK
Thanks Paul for your response.  I'm sure you saw by my last response that i'm going to try
the diluting HP PK with the glop route and see how that works!  I figure as long as they
mix well, stays in solution and doesn't clog that it should work; I guess that is a lot of if's,
but I'll keep my fingers crossed.
If you get a chance and don' mind, would you check and see how the HP PK mixes with
glop, I would certainly appreciate it; it will be a few days before I will get a chance to mix
the solution up myself.  If not, are there any mix test I could do myself?  I don't have any
lab equipment other than some syringes.  I would hate for it to clog the heads.  If it does
clog, is it possible to unclog it?
Randy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote:
> MIS PK.
> Yes.
> Paul
> www.PaulRoark.com
