UT14 Glossy 100% Carbon Prints that are Neutral
2009-02-12 by Randy Rancier
This question is directed at Paul, but feel feel to chime in with your knowledge and
experience.
Paul, as you mention in your white paper on the UT14 inkset I would like develop a OTR
curve and icc  with the UT14 inkset on the current baryta fiber based glossy papers such as
ILFORD Gold Fibre Silk (IGFS) that are neutral.  I have recently become familiar with QTR, but I
am not sure as how to set up the profile.  You were not specific on the nuts and bolts, but
you did mention that you use the Eboni, glop and PK ink form the inkset.  It also sounds as
though the PK is used for the darker tones and pure black, so I'm assuming that the Eboni is
more neutral in tone and  is used for the highlights and mid-tones; you also mention that
glop is used to hold the Eboni down, as I know from experience that Eboni on glossy paper
will smear even after it is dry.
Do you have a QTR curve available for this setup?  If I need to develop my own what do I use
as far as ink limits for the Eboni and the crossover points.  Also, I don't know the procedure
for applying the GLOP along with the Eboni.
Any assistance is appreciated.
Randy Rancier
Re: UT14 Glossy 100% Carbon Prints that are Neutral
2009-02-12 by pr_roark
I mostly supported the Epson driver workflow with a QTR "Create ICC-
RGB" approach to make ICCs that had Photoshop curves embedded in
them.  The basic curves for this are in a Zip file.  I tend to leave
the rip to those who are familiar with it.
True.
> from the inkset.
Yes, you can see the PS curves to see the general pattern of glop
useage.  The PK and PKn are the dark midtone inks.
For the glossy papers, I recommend using no Eboni at all.
> ... glop is used to hold the Eboni down,...
You don't need to worry about that with the UT14 inkset.  Don't use
any eboni on glossy papers.
One approach you might consider is making separate warm and cool
profiles with just the 2 midtone inks.  Then combine them as needed
with the sliders.
2009-02-12 by dileepawijesundera
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Randy Rancier"
your knowledge and
> experience.
like develop a OTR
> Randy Rancier
Randy/Paul/Anyone who can help
Its a steep learning curve and these threads help a lot, having said
that all the terminolgy used confuses the beginners, I am sure. If I
understand correctly the UT14 uses
1. Photoblack (PK)in the K slot
2. GLOP in Y position
3. M/LM/C/LC ( all diluted blacks or carbon as they say say!!!, I
presume), when you say "no Eboni" on gloss paper does it mean "no K"?
Therefore on gloss simply use the M/LM for warm and C/LC for Cool. Am
I right?
Further, to bring in "GLOP" on MATT (to keep the K down as said in
Paul's thread) paper if a COPY_CURVE_Y=K is included in the ink desc
file will it follow the PK ink? OR AM I TOTALLY ON THE WRONG TRACK!!!!
dileepa
Re: [Digital BW] Re: UT14 Glossy 100% Carbon Prints that are Neutral
2009-02-12 by Eddie Wiseman
Hi..
I'm using a UT14 settup with MIS UT14 inks, , and NO PK ink is used all..
EBONY ONLY goes into the K slot, and is used ONLY when the curve/profile calls for MATTE type paper....
Eddie Wiseman
  Sent: Thursday, February 12, 2009 3:42 AM
  Subject: [Digital BW] Re: UT14 Glossy 100% Carbon Prints that are Neutral
  your knowledge and
  > experience.
  like develop a OTR
  > Randy Rancier
  I right?
  dileepa
2009-02-12 by hp9180profile
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "dileepawijesundera"
<dileepa@...> wrote:
> If I
K"?
Dileepa, I will try and help.
Looking at the first page of Paul's PDF on this in inkset (
http://www.paulroark.com/BW-Info/UT14.pdf ), I do not think you are
entirely correct. Rather, Mk (Eboni) is in the K slot. A 100% carbon
Photoblack (PK - presumably K4-PK) which produces warm tones is in
the M & LM slots. A 60% dilution of non-100%-carbon PK (Presumably R2
PK which comprises a blend of 10% blue pigments and 90% carbon) is in
the C & LC slots. This latter PK produces cool tones.
Am
> I right?
Yes, noting the inclusion of blue pigments to make cooler prints.
desc
TRACK!!!!
No, you will need no GLOP on matt paper.
> dileepa
Paul, thanks so much for your reply.  That's good to know, I have already developed warm
and cool curves.  I'm assuming if I want 100% carbon on IGFS that I will need to use 100%
of the warm curve.  Only thing is the warm inks in the M and LM slot, (if you remember
from earlier post my warm curve on IGFS uses only ink from the LM position), and is very
warm, especially on IGFS.  I was hoping to achieve a more neutral print on IGFS using 100%
carbon inks which was what I thought you were talking about in your white paper as is
memtioned in the subject line of this post.  I had figured that the Eboni must have given a
more neutral print on the IGFS with the GLOP holding the Eboni down and then finishing
off with a coat or two of Premier Print Shield.  If we are not supposed to print with Eboni on
glossy papers what is the purpose for the GLOP?  If things have changed since this inkset
was developed perhaps a better use of the "Y" inkslot would be a lighter such as LLPK for
smoother highlights.
Also, I am not very familiar with using the icc profiles along with the ACV curves in PS, and
I believe I've read most if not all of your papers on the subject, is there someplace with a
good description of the process or a step by step for developing or for that matter using
these curves and profiles in PS.  I do understand that the ACV curves are presets in PS for
curve and tone adjustments, and have played with them to familiarize myself with them.  I
have a more detailed post outlining my questions on this subject that I had posted on the
QuadTone forum, that I didn't get a response too on ICC profiles that I will post here after
this post; so if you would take a look at that post before responding concerning my
questions on the use of ACV curves I'd appreciate it.  Right now I'm more concerned with
the first paragraph of this post.
I apologize for the multitude of questions, I'm just attempting to make the most out of my
UT14 setup as it appears to be the most versital inkset for prints 13 inch wide and
smaller.
Much Thanks,
Randy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote:
> True.
> > from the inkset.
> with the sliders.
> Paul
> www.PaulRoark.com
I've clarified in http://www.paulroark.com/BW-Info/UT14.pdf what the
inks are.  C is PKN, LC is a dilute version. M is k4-PK, LM is LK (a
dilute version of PK).  K is Eboni.
> ...I'm assuming if I want 100% carbon on IGFS that I will
> need to use 100% of the warm curve.
You can, with more work, make a neutral image using Eboni (K), but
it'll need spraying.  See page 10 of
> ... If we are not supposed to print with Eboni on glossy papers ...
It's just more work and not something a novice ought to try.  One can
certainly combine Eboni, PK, glop and probably a post-printing spray
to make a neutral, 100% carbon print.
It's often very handy to control the reflective artifacts that one
sees with most pigments on glossy papers.  The UT14 artifacts are not
as bad as many, but glop can still improve the results.
>... perhaps a better use of the "Y" inkslot would be a lighter
> such as LLPK for smoother highlights.
That is certainly an option I point out.
> with the ACV curves in PS, ...
See http://www.paulroark.com/BW-
Info/Embedding_Photoshop_Curves_in_ICCs.pdf
The Epson driver with one of these ICCs makes not only a "color
managed" (with respect to relative densities) workflow, but also a
high bit pipeline to the paper, unlike the vast majority of workflows
that people use in B&W.
Hope this helps.
Thanks Paul for your response; some things I need to clarify further as noted below!
Yes, I understand the inks and there placement.
Yes, this is exactly what I am wanting to do!
Yes, I understood that from your paper on UT14, which I've read several times.  I don't
mind post-print spraying or going the extra mile to learn how to do this.  I can develop
my own curves in QTR, but I wasn't sure at what density to crossover from using the Eboni
to the PK inks?
I'm also not exactly sure, but I think I have a good idea, as how to make sure the GLOP
gets laid down with the Eboni; but if you're not that familiar with QTR I can inquire else
where on this.
I haven't seen this paper and I'm sure will help clarify my questions on using Photoshop
curves in ICCs.
One final question: Does you profile "1400-IlfordGold-N-1-nca-rgb.icc", which i've
downloaded from your site, use the Eboni (K) with GLOP in this profile for making neutral
prints as discussed above?
Thanks again so much for your help,
Randy
2009-02-13 by pr_roark
> > Eboni (K), but
> ... I wasn't sure at what density to crossover from using
> the Eboni to the PK inks?
This may be the QTR profile I used:
http://www.paulroark.com/BW-Info/Eb-IlfordGold-Spray-3.zip
No, that uses the usual blended color inks in cool channel to make a
neutral glossy print.
2009-02-13 by Randy Rancier
Thanks Paul for the QTR profile, I'll give it a try.  Could you possibly send the txt file used
to create this profile below, so that I could see how it was created and possibly edit if
needed for other glossy papers?
I also downloaded and read your paper on "Adjusting Monotone Photoshop Curves for
Inset Control"  which answered most of my questions on how you create and use curves to
control the inks with PS.  This is a must read for those wondering about how curves are
used and created and also the paper "Embedding Photoshop Curves in ICCs" for how these
curves are used to create ICC profiles.
Randy
> > > Eboni (K), but
> Paul
> www.PaulRoark.com
There is no more than is in the profile.  The curves were hand made.
So the linearization reading is the only spectro text output that was
used.
Thanks Paul, I didn't realize you could open quid & quad files as txt and view them; I thought
they were binary files.  I'll take a look at the densities or curve data and see what I can figure
out!  I may have a question or two once I try to figure out the curve data!
Thanks again,
Randy
> used.
> Paul
> www.PaulRoark.com
