ICC profiles
ICC profiles
2009-02-12 by Randy Rancier
I have created some icc profiles with QTR-Create_ICC.app using readings of my final print
out of the 21-step wedge after linearization using no color management for my warm and
cool curves; I also plan on doing some others for varying degrees in between my cool and
warm. I have seen the immediate benefit of these icc profiles for soft proofing.
As far as using them for printing I have some questions. First when using these icc
profiles for printing, I'm assuming that you use them with the Epson driver or other RIPs
for the printer you are using; is my assumption correct? Second, can you use them when
printing through QTR, and if so, do you use them in conjunction with the same curve
settings as was used to create the icc profile??? And if you can print with the icc profiles
through QTR what are the advantages of doing so???
Another question I have is about the other ICC application with QTR, QTR-Create_ICC-
RGB.app. Ii is my understanding that this application is for creating icc profiles with ACV
curve adjustments to adjust the tone. I'm not sure what the advantages of doing so; so if
someone could explain I would appreciate this. I'm also assuming that this is also only for
when using full color inksets and not for use with gray scale inksets. I'm guessing the
advantage is when using full color inksets is that you would be able achieve any tone
desirable and the tones should match a calibrated monitor.
Thanks in advance for your comments,
Randy
Re: ICC profiles
2009-02-12 by pr_roark
"Randy Rancier" <randy_rancier2004@...> wrote:
> I have created some icc profiles with QTR-Create_ICC.app ...
> soft proofing.
> First when using these icc profiles for printing, I'm
> assuming that you use them with the Epson driver ...
The Photoshop (or Elements) print preview is the main application I
know of that recognizes these ICCs.  So, you go through the print
preview to the Epson driver.
>... can you use them when printing through QTR, ...
No -- aside from the soft-proofing aspect.
Re: ICC profiles
2009-02-13 by Michael
Note that the color seen in the image when using Element's print
preview is not meant to be accurate; the preview is only meant to show
image placement on the paper.
-MK
