OT - New monitor on the market
2009-02-12 by Richard Smallfield
in case anyone on a budget is looking for a graphics monitor, this one looks very promising - the Dell UltraSharp 2209WA 22 inch.
It's an e-IPS panel with 178 deg viewing angle and matte surface - I've found nothing comparable in the price range.
Richard
____________
www.richardsmallfield.com
   "Nothing in the world can take the place of persistence.
   Talent will not; nothing is more common than unsuccessful
   men with talent. Genius will not; unrewarded genius is almost
   a proverb. Education will not; the world is full of educated
   failures. Persistence and determination alone are omnipotent."
   --Calvin Coolidge
Re: OT - New monitor on the market
2009-02-12 by densible
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Smallfield
<r.smallfield@...> wrote:
> Hi,
> Richard
> ____________
>    --Calvin Coolidge
>Do you know what % of RBG 1998 color space this monitor renders?
Mark
Re: [Digital BW] Re: OT - New monitor on the market
Hi Mark,
Here is the spec sheet:
http://www.dell.com/downloads/global/products/monitors/en/monitor-dell-2209wa-spec-sheet.pdf
Richard
____________
   "The gladiator is making his plan in the arena." (i.e. too late.)
   --Lucius Annaeus Seneca, the Younger 4 B.C. - A.D. 65
2009-02-12 by Bill Morse
Hi Richard-
Not much there-more of an addy than a spec sheet. Why do you think this is
such a good monitor, other than the monitor type?
Bill
On Thu, Feb 12, 2009 at 3:22 PM, Richard Smallfield <
>   Hi Mark,
> Richard
> ____________
Bill Morse
Wm. Morse Editions
http://www.MorseEditions.com/
According to the spec sheet the monitor achieves 83% of CIE1976 color space. If anyone can
chime in and correct my thinking that this spec would be even a smaller percentage of
Adobe RGB 1998 space?
Mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Peter De Smidt <pdesmidt@...>
wrote:
> The monitor type is pretty important, and the comments from people on
> various forums has been pretty positive.  It's certainly worth looking into.
RE: [Digital BW] Re: OT - New monitor on the market
2009-02-12 by Robert Paup
How many adjustments does it have?  This is important for calibration.
Bob
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Bill
Morse
Sent: Thursday, February 12, 2009 4:27 PM
Subject: Re: [Digital BW] Re: OT - New monitor on the market
Hi Richard-
Bill
r.smallfield@ <mailto:r.smallfield%40paradise.net.nz> paradise.net.nz>
wrote:
> Hi Mark,
> http://www.dell.
<http://www.dell.com/downloads/global/products/monitors/en/monitor-dell-2209
wa-spec-sheet.pdf>
> Richard
> ____________
Bill Morse
Wm. Morse Editions
http://www.MorseEdi <http://www.MorseEditions.com/> tions.com/
It's the only monitor on the market in its price range with a 178 deg viewing angle and it has a non-glare surface.
I believe the gamut is not as good as the more expensive ones, but if we are printing primarily Black and White, I think other considerations like viewing angle might be more important.
Some more expensive models, like the Samsung 215TW, which have been well reviewed, have only a 170 deg viewing angle.
Richard
At 10:27 a.m. Friday 13/02/2009, you wrote:
>Hi Richard-
>Bill
><mailto:r.smallfield%40paradise.net.nz>r.smallfield@....nz> wrote:
>> Hi Mark,
>> <http://www.dell.com/downloads/global/products/monitors/en/monitor-dell-2209wa-spec-sheet.pdf>http://www.dell.com/downloads/global/products/monitors/en/monitor-dell-2209wa-spec-sheet.pdf
>> Richard
>> ____________
>Regards,
>Bill Morse
>Wm. Morse Editions
><http://www.MorseEditions.com/>http://www.MorseEditions.com/
____________
   "Experience is that marvelous thing that enables you to
   recognize a mistake when you make it again."
   --F.P. Jones
2009-02-13 by Clayton Price
Richard -
Can you even discern a difference of 8 degrees in the viewing angles
of two different monitors?
You really should be paying attention to the gamut and tonal
qualities of a monitor. Black & White is just as important
as color gamut, and IMO, a slight difference in viewing angle would
be the least important reason for purchasing a monitor.
Clay Price
: "Richard Smallfield" -posted:
Thu Feb 12, 2009 3:41 pm (PST)
<<<It's the only monitor on the market in its price range with a 178
considerations like viewing angle might be more important. Some more
reviewed, have only a 170 deg viewing angle.>>>
2009-02-13 by Richard Smallfield
Hi Clayton,
the figure of 178 deg was got from this (admittedly brief) article:
http://web.me.com/thecolourlady/CM_Site/Knowledge_files/TPM183_LCDMonitors.pdf
My desire for a wide viewing angle may be exacerbated by the fact that at present I'm working on a laptop PC with no external monitor - so I may have less than a 170 deg viewing angle at present. However, the dedicated graphics monitors seem to be at 178 deg.
Richard
At 06:40 a.m. Saturday 14/02/2009, you wrote:
>Richard -
>Clay Price
____________
   The more you say, the less people remember.  The fewer the words,
   the greater the profit."
   --Felelon
2009-02-14 by scanzzz
of two different monitors?<<
Yes, especially on wide format monitors.  You can look left and right
a relatively larger amount without seeing what appears similar to a
shift in gamma.  Same thing for up and down movements of your head.
You will of course eventually move enough to start seeing a shift but
it takes a deliberate shifting of your position.  The difference
between a laptop and this monitor should be very satisfying!
This monitor has an amazing price. The one thing I don't know about is
how the E-IPS panel differs from the other flavors of IPS.
Richard, let us know if you get one.  I look forward to more
real-world reports on this monitor.
Doug
www.BetterScanning.com
