R2400 ABW Printing Light
2009-03-15 by steveh0607
Hello Everyone,
Lately the R2400 has been printing light. I've had to reduce the brightness by (-8) to get a screen match. This problem has never happen before.
When I run a nozzle check, the test print is good. So it does look like it could be the nozzles or a clogged head.
The problem only manifests when I use the Advanced Black and White driver, either toned or neutral, and/or with everything at default or not.
If I apply any kind of tone (heavy or light) and print using the color profile (by-passing the ABW), the print looks as it should.
Color prints looks fine.
I'm thinking this must be a software problem. If a nozzle check is good, and if it only happens using ABW driver what else could it be?
Has anyone else had this problem?
Any thoughts?
Perplexed,
Steve
