First printer: Does Epson 1400 still make sense?
2009-03-28 by seablister
First time poster looking to buy first printer, having given up on setting up a traditional darkroom. I've been reading back posts for the last several weeks and kind of decided that the 1400 with some variation of Eboni 6 would give me the look that I'm after. (Also being enticed by the 3800 but don't really need the size.)
But I'm wondering if the 1400 still makes any sense as a new purchase, given the uncertainty of Eboni inks continuing. Might it be time to just go with the latest technology (3800) instead?
Cost of printer not really an issue, but I'm sure ink costs will be annoying.
Thanks for your thoughts.
Re: First printer: Does Epson 1400 still make sense?
2009-03-28 by pr_roark
"seablister" <seablister@...> wrote:
> ...kind of decided that the 1400 with some variation of
> Eboni 6 would give me the look that I'm after. ...
> But I'm wondering if the 1400 still makes any sense ...
> (3800) instead?
The 1400 is the platform I recommend these days for 13" dedicated B&W.  I use it and find it the best value.  The 1.5 picoliter droplet allows things that the older technologies (including the 3800) cannot do.
I know of no serious threat that Eboni will not be available.  The ink is also sold by competitors under different names and is produced by a much larger company that will almost certainly be in business for some time regardless of what MIS does.  (I assume MIS will also be a viable source for the foreseeable future.)
Additionally, there are a number of different workflows and inksets that run on the 1400.  So, it's a well supported platform.
I have several workflows noted on my main B&W Info page at
http://www.paulroark.com/BW-Info/ and Jon Cone also supports the printer, I believe.
Note I'm not being critical of the 3800.  I'm sure it's a fine machine if one wants color and B&W with the OEM approach or QTR.
Re: [Digital BW] Re: First printer: Does Epson 1400 still make sense?
2009-03-28 by Terry Ritz
Paul, what are your thoughts on the 1900? Do the same comments apply?
Terry.
RE: [Digital BW] First printer: Does Epson 1400 still make sense?
2009-03-28 by Gary Wagner
Hello,
I have a 1400 and a 3800 and they both work great. If you don't need the
size of the 3800 the 1400 is excellent. I have been trying a variety of MIS
inks using refillable cartridges and am now using the C6 formula from Paul
Roark. You can't beat it for under $200. The only problem I have had is when
using glossy paper I have had some minor tire markings on the print but for
matte it is not an issue. As for the 3800 there are some CIS available and I
am using one without issue but I still have not seen refillable cartridges
for this printer. Being able to use other inks is an advantage. Hope this
helps.
Gary Wagner
seablister
Sent: Saturday, March 28, 2009 5:53 AM
Subject: [Digital BW] First printer: Does Epson 1400 still make sense?
annoying.
2009-03-28 by andre1moreau
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gary Wagner" <gcwagner@...> wrote:
> You can't beat it for under $200. The only problem I have had is     > when using glossy paper I have had some minor tire markings on the   > print but for matte it is not an issue.
This has been my experience with the Epson 1400 as well. I now print only on matte paper.
Andre
2009-03-29 by pr_roark
I've never used a 1900.  So I can't really say much about it.  I suspect with QTR the 1800 3-MK workflow will be fine, but, again, I have not tested it.
I, frankly, find hextone printers to be easier to deal with when the Epson driver is used.  Hopefully the 1900 does not band the way my 1800 does, but, again, I'm not in a position to know.  The 1400 just seems like a real bargain for what I do.
Re: [Digital BW] First printer: Does Epson 1400 still make sense?
>... The only problem I have had is when
> on the print ...
That's interesting.  So far, I have not seen these with the NC2 (see http://www.paulroark.com/BW-Info/1400-NC2.pdf) setup and HP inks I'm using with it now.  I don't do a lot of glossy work, but the brochures I print have some heavy black areas that I would think would show them.
2009-03-29 by grangermacy
I recently bought my second 1400 for UT14 inkset.  I'm very pleased with this printer on all counts and especially like the way 300+ weight papers have loaded without a problem.
I haven't seen any tire marks on glossy either.  But I would also think that this is very variable with inkset, paper type etc.  With the claria inset, for example, you can use swellable papers. But overall I find these papers problematic.
Granger
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote:
> > on the print ...
> Paul
> www.PaulRoark.com
2009-03-31 by Tyler Boley
get some Epson cleaning sheets to run through when it doesn't want to grab paper any more...
Tyler
--- In DigitalBlackandWhiteThePrint@...m, "seablister" <seablister@...> wrote:
> Thank you all for your responses. That's exactly what I was hoping to hear.
