--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "hp9180profile" <owens@...> wrote:
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg" <dfaprinting@> wrote:
> > So I've just flushed out some junk ink and I want to reuse the carts. These are third party vacuum fill carts with lots of nooks and crannies to hold the leftover water. Short of building a vacuum chamber to boil off the water, what do you suggest? >
> Do not apply heat or excess vacuum to these cartridges. Most have a small delicate silicon valve that if damaged will allow the cartridge contents to drain gracefully out through the printer heads. They also rely on an internal plastic membrane to remain leak-free which will also risk damage.
These are vacuum fill, so they are designed to pull a pretty strong vacuum just to allow the initial filling. I think there is a video of the proper way on the company's website (http://www.inkjetcarts.us) so applying a vacuum of some sort should be fine. Best would be putting the whole cart in a bell jar and pulling that down to vacuum but I don't have that type of rig.
And as a whole these carts are only OK, out of 18 carts I have a couple of dead chips, and a couple carts that either leak or are too restricted and cause missing jets., But the are cheap at about $22 for a set of 6. Buy enough and you'll have what you need to get going while you wait for exchanges.
