ImageNest
ImageNest
2009-06-16 by photog0946
I'm reasonably certain that this subject has been tossed around before on this forum, but once again I am considering this software RIP and would like to get some feedback. If anyone is presently using ImageNest, please respond.
Thank you.
Gary
Re: ImageNest
2009-06-16 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "photog0946" <photog0946@...> wrote:
> Thank you.
> Gary
A quick look through what little information is there and all I see is an image layout application that interfaces to the manufacturer's printer driver and uses the regular RGB features of the printer.
If you are looking for a workflow tool, then it might be worth having. If you are looking for something that will give you control over ink limits and linearization (and several other key areas), I saw no indication that you have this level of control. In fact the online manual left a lot to be desired and I would probably skip it based on that manual unless it was really cheap.
It wouldn't surprise me if most of the code came from Open Print Maker, Gimp, and Gutenprint.
