Imac Screen
Imac Screen
2009-07-14 by mcenigma
Hello,
 I am sure that somebody on the group have and Imac, I got one and I am so frustrated, no matter what I do ( xrite, spider, etc ) the screen is really bright.. I have it to the lower value and still to bright.
 I send some e-mails to apple and there answere is ( change the light on the print view to more bright )
 NAPP ( national asosiation of photoshop ) tec suport told me, yes is a problem and no solution.
 ... so does anybody have a solution of this problem?
 thanks
 Juan
Re: [Digital BW] Imac Screen
2009-07-14 by C D Tobie
> bright.
The best solution (and the one you don't want to hear about) is not to
use iMacs for serious image editing. But, the larger iMac does have a
better grade of screen than the smaller model, though still not as
good as the Cinema Displays. You can start by increasing your ambient
(room) lighting, to make a better balance between the lowest the iMac
setting and the ambient lighting. We plan to offer brightness-dimming-
in-software functionality in an upcoming version of our Spyder3
products, mostly to deal with these insufficiently dimmable iMacs
(though dimming displays in software is a compromise). In the
meantime, the software that currently offers this capability is
ColorEyes Display, which can be used with the Spyder3, if you already
have one, or purchased with a Spyder3 if you do not.
C. David Tobie
Global Product Technology Manager
Digital Imaging & Home Theater
CDTobie@...
Datacolor
www.datacolor.com/Spyder3
2009-07-14 by jim kitchen
Dear Juan,
Take a look at this software...
<http://www.integrated-color.com/cedpro/coloreyesdisplay.html>
It will do what you ask regarding the screen brightness and monitor
calibration. You can buy the software alone, or the kit with a puck.
jim k
2009-07-14 by mike-theprint@waspfactory.org
>  bright.
Does your iMac support a secondary display? If so, buy a high-quality
LCD and do your image editing on that.
  | Mike Acar |                                | mike at waspfactory dot org |
Re: Imac Screen
2009-07-14 by jesse.boles
I was just talking to someone at my local photo shop about this apparently color eyes profiling software can lower the brightness beyond normal adjustments during the profiling software, you can download a trial version and it supports most colorimeter/spectros.  Haven't tried it myself and don't own an imac. Not even sure how we got on the topic. The website is http://www.integrated-color.com/cedpro/coloreyesdisplay.html
Hope it works,
Jesse
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mcenigma" <mcenigma@...> wrote:
> Hello,
>  thanks
>  Juan
Re: [Digital BW] Re: Imac Screen
2009-07-14 by Mark Savoia
I have color eyes and it does work on my iMac screen. It does have a
preset in the software for iMacs. Only big issue is where to place the
puck, the brightness from left screen to right is almost a full f/stop
(after three replacements from Apple). I will never get one for
critical work again, sticking with my Eizos.
Mark
http://www.stillrivereditions.com
> Hope it works,
> Jesse
>> Hello,
>> bright.
>> thanks
>> Juan
> Hope it works,
It works, but it loses you levels in the process. If you dim the
display to half its lowest physical setting, then you have lost half
the available levels; instead of being able to display 256 levels, you
can only display 128. Thats the compromise this entails.
C. David Tobie
CDTobie@...
Datacolor
2009-07-15 by Platinum Jim
C. David:  I have Spyder 3 and an Apple Cinema display, but the lowest I can go is 120 or so.  Will the Datacolor solution still maintain 256 levels even though it might use 80 or 90 for the Cinema display?  When will the Datacolor solution be ready?  Thanks in advance.  Jim
  Sent: Tuesday, July 14, 2009 3:27 PM
  Subject: Re: [Digital BW] Re: Imac Screen
  > Hope it works,
  C. David Tobie
  CDTobie@...
  Datacolor
2009-07-15 by C D Tobie
> display?
I am certainly agitating with the OS manufacturers and other related
companies to provide a high-bit videostream, so that software dimming
will no longer cost levels and cause potential posterization. But at
this time software dimming (beyond what the hardware controls can do)
still has to work by losing levels, so the more you have to dim in
software, the more levels you have lost. No magic, just a compromise...
Sorry, I can't provide dates for future features. Just wanted to note
that its on our radar screen, since its becoming a more common issue...
C. David Tobie
CDTobie@...
Datacolor
2009-07-15 by Howard
As everyone noted, you can't lower the iMac screen enough in hardware.
and yes, there is also a significant brightness difference across the screen.
ColorEyes (or BasicColor) adjust all 3 primaries to lower the brightness but that affects the overall levels.
In the end, I got a Dell 2209WA to use as my proofing monitor.  it was only slightly more than just the ColorEyes software and it solved all the problems.
2009-07-15 by photog0946
Here's a little app that will lower the brightness of your display. It may or may not work the way you need for image editing, but I've tried it and it certainly does dim the display. I would not suggest be overly aggressive with it, since it may also create other issues. The loss of levels is something you may want to be aware of. I don't use it, but it just might be what you need as a workaround until you can solve this issue in another manner. The name of the app is "Shades" and it's free, but you can donate if you find it useful. I've included the link below.
http://www.charcoaldesign.co.uk/shades
Gary
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Howard" <howardm4@...> wrote:
2009-07-15 by Mark Savoia
It really messes up a monitor profile. Beware.
Mark
> Gary
2009-07-16 by Cdtobie
This app trashes your calibration LUTs; it is totally incompatible
with color management.
C. D. Tobie
Global Product Technology Mngr.
Datacolor.com
CDTobie@...
> Gary
>> hardware.
>> the screen.
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in
> the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNE
> R” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DA
> MAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE L
> OSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW,
> THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH D
> AMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIG
> ITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTER
> ATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF
> ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) AN
> Y OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2009-07-16 by renato cury
Would a " true" neutral filter ( which is neutral for LDCs spectra and 5000K? Rosco or Lee Neutral filters are not for their color temperature. They are made neutral  for 3200K )  or a polarizer, like 3M's Vikuiti ( if it does not introduce a color bias, too ) work ? I did'nt give it a try cause I still use my olds CRTs ( and cheap LDCs only as a second monitor, just for the tools, not images ) .  Just an idea ...
         Renato
--- Em qua, 15/7/09, Mark Savoia <mark@...> escreveu:
De: Mark Savoia <mark@...>
Assunto: Re: [Digital BW] Re: Imac Screen
Para: DigitalBlackandWhiteThePrint@yahoogroups.com
Data: Quarta-feira, 15 de Julho de 2009, 19:54
Mark
http://www.stillriv ereditions. com
> http://www.charcoal design.co. uk/shades
> Gary
Veja quais são os assuntos do momento no Yahoo! +Buscados
http://br.maisbuscados.yahoo.com
2009-07-16 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, renato cury <yrucotaner@...> wrote:
Any ND filter that you put in place and calibrate/profile through should be fine, but they do fade unless you get the extremely expensive Rosco di-chroic filters that they recently introduced. I tried to get some samples of their colored di-chroic filters and they said it was so new that they didn't have any samples available, and then when I saw the price I decided we could go a long way with gels and still not hit the price point of the di-cro material.
Disadvantages would be the shiny surface and almost impossible to keep the "wrinkles" flat.
