Sent: Tuesday, July 14, 2009 9:06 PM
Subject: Re: [Digital BW] A question on MIS refill kits
Good Morning MIKE..
You don't need a re-setter with these chips..They are "auto-resetting"...Also, Im not exactly sure if their pre-filled carts are re-fillable..They probably are, but it's best to confirm that with MIS..
Eddie
Hi folks,
On Tue, Jul 14, 2009 at 08:13:14PM -0400, Eddie Wiseman wrote:
> Mike..
> I have warm tap water in a quart container in my sink..I purge any
> residual ink of EACH color back into its bottle, and then I "pump" the
> syringe 3-4 times full of the warm water and finally keep pumping it
> out of the water, until nothing more sprays out..
Ok, I see.
> If you don't buy the 4 oz bottles, you will go through those
> initial carts very quickly..
*nod* It seems like the best bet is to get a set of pre-filled carts, a
set of bottled inks, and a couple sets of syringe+needle+adapter. I
guess there's not much reason not to throw in a set of refill-friendly
carts and a resetter, too.
> Also make sure that on your "initial" cart filling, you suck out
> approx 1cc from the exit port(s) of each one of the carts using the
> "bottom-fill" adapter(rinsing your syringe out after each color of
> course!). This will help prevent getting an "air-lock" at start-up,
> which you will THINK is a clog..Good luck and have fun!
Great, thanks for the advice!
On Tue, Jul 14, 2009 at 04:45:58PM -0700, Tom Baker wrote:
> The one thing I've seen destroy others efforts using the refillable
> carts is to not keep everything clean. Â Even if you use seperate
> syringes for each color you need to keep them perfectly clean. Â So,
> cleaning and reusing the same syringe for all the colors does not
> increase your workload. Â
*nod* A good observation. I'll try to be scrupulous :)
On Tue, Jul 14, 2009 at 04:47:24PM -0700, RobLee wrote:
> I would suggest you try OCP German inks. I have a great success with
> them in my R1800
From the OCP website, it seems the 1400 inks are still under
development. But I'll keep it in mind if I find I want to switch from
the MIS inks.
| Mike Acar | | mike at waspfactory dot org |
