InkAid...Potential...Spray finishing advantages????
2009-11-24 by KentB
I have my first sample of inkaid. I decided to try the semiGloss. I used at as my first test paper Rising Stonehenge. I am initially very enthused. It receives Ebony just fine...I am using a test profile for matte papers for commercial papers...nothing rubs off. Excellent basic test print. Paper is what I would call semi-matte...slight gloss at an angle. I have not tested dmax, but is visually relatively high. The biggest issue is that the paper texture gets a bit in the way, due to the semi gloss. This exaggerates the texture with light from an angle. So I have a questions. 1. Does Premier Spray or other sprays equalize gloss differential? --- What does impress about my first inkaid test is that there is a presence...kind of like the image is in the paper...not on the surface. But there is an annoying reflection of texture. I have seen this in two commercial papers....Ink Press Warmtone Fibre...and Premier Platinum Rag. --- My question is....does spraying help this bothersome surface differential? My initial test of Inkaid is worth exploring. There is a wonderful presence....better than I typically see in commercially coated papers. I look forward to hearing from you users who regularly spray your prints...I have never sprayed an inkjet print. Is this a way to take care of surface differential issues??? Thanks Phil
