Hello Paul,
I have been following with much interest your work on Arches paper, that complement what I have been doing in the two-three years. I still use Eboni for testings.
Regarding washing the paper, I use a sligthly different approach.
1) Ink is allowed to dry a very minimim of 48h, otherwise the carbon pigments have a high chance to go leave the paperr during the washing phasr
2) First phase washing
The print is layied on a moschito net. The whoele thingh is, then, totally immersed in still water for about three hours. Most of the stuff the ink is made of other than pigments (mostly glycols and preservatives) are softened by the bath and dissolved into the water.
3) Second phase washing
This is done with running water. Its pourpose is to carry away the dissolved substances
Dmax of the print is very much unaffected.
Few words about Fine Art papers.
I never liked very much Arches Watercolor Hot Press; although the Dmax is very nice for B&W, its tooth daes not appeal to me.
I have been recently in the US to promote my photography. While there, I stopped at Blick's to look for new papers (much easier than in Souhern Italy where choices are very limited). While I am perfectly happy with Magnani pesci for Carbon-Gelatine process, its Dmax is much too low (to my taste) for regular Giclee.
In fact I found three papers which I liked very much, and I purchase them to test with Ebony and an Epson 7800.
You know what? I forgot thos papers in my Hotel.
If you like to experiment, here they are:
1) Arches Multimedia (it was in the Arches rack, bottom place, with no name). I was not aware of this paper at all, nor could find any info on Internet. The store attendant checked on her computer and confirmed it is a 100% cotton paper
2) Arches Cover (also 100% Cotton)
3) Arches 88 (also 100% Cotton)
The latter two are for ink processes (as etching), much like Magnani Pescia while the first is, to my understanding, a watercolor paper.
Ciao,
Mantinieri
P.S. Thanks for quoting my work in your document
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <paul.roark@...> wrote:
> I've summarized my latest findings in this effort at
> http://www.paulroark.com/BW-Info/Arches.pdf
> One of the significant things I've found is that briefly rinsing Arches has very little impact on the image.
> (A watercolorist and I are currently in a collaborative effort to see what happens when the media are mixed. We're using the Cold Press version of Arches for this. They also have a "Rough" version for even more texture. I'll look at that at some point.)
> I've noted in my PDF that Jon Cone's carbon sepia should behave similarly to the dilute Eboni I'm using. It would be interesting to see what a very warm Arches looks like. I'd say we ought to have a medium sepia that is better than any of the traditional methods.
> I've posted my QTR setup. Note that this is for the 7800 C6 "Dual." Other inksets will need different arrangments, but the key is to keep the midtone ink limits very low. (The limits I show in the PDF are when a "toner" channel -- still carbon -- is used. So, the ink limit is split between them.)
> Paul
> www.PaulRoark.com
