Generations Alise Papers - A Review
2010-01-01 by ClaytonJ
Hello All,
I have been testing these new papers and have good things to report, especially for the Natural version (called "Museum" on the Premier Art web site).
Main points:
1) Dmax (with K3 inks) is excellent on both, with slightly better result on the natural version, 1.72, with 1.71 on the BW version. Only VFA is higher at 1.75.  Results may be different with Eboni-based inks.  These numbers are an average of 4 to 6 readings done by Steve Karafyllakis with a ColorVision SpectroColorimeter.
2) Both versions render cool ink tones.
3) The paper color of the Natural version is not as warm as most other non-OBA papers.
4) Prints easily, meaning the prints match the EEM proofs in contrast and density and don't require adjustments.  Seems almost effortless.
5) The smooth surface has very little bleed and renders extremely sharp details.  Things just look real crisp.
My Impressions of the Natural version:
This is the highest Dmax non-OBA paper I've tested.  It is also the least warm non-OBA paper I've seen.  Because of these qualities, I feel this is the most significant new paper to come along in a long time (there are some other new papers I haven't tested yet, so it's possible there are others that share these qualities).
I am currently printing a family reunion portrait job with it and I'm getting gorgeous results.  My impression is that this is new technology.  It's not yet another version of the same old coating technology we've seen for years.  It takes inks differently than anything else in my experience.  It's the first new paper to get me excited in a long time.
A more detailed review can be found at this link
   http://cjcom.net/articles/digiprn5b.htm
Clayton
I-Trak 2.1   http://www.cjcom.net/itrak.htm
Re: Generations Alise Papers - A Review
2010-01-01 by shileshjani
Clayton,
Thank you for the review - as is usual for you, very succint yet informative.
The "cool ink tones" were achived with what settings? Using ABW?
Regards.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ClaytonJ" <cj@...> wrote:
> Hello All,
> Main points:
> Regards,
> Clayton
Hello Shilesh,
Nice to hear from you, it's been a long time since the old BO print exchange days.
Yes, the 2400 is all I have right now, not using any Eboni-based inks.
I have a default ABW setting of 2,8 that I use for the tests.  On EEM
and VFA this produces a slightly warm neutralish tone that is similar to what Eboni produces and forms a base line for my comparisons.
With that setting these papers produced cooler tones.  I had to warm it up a bit to nudge it back.  The degree of coolness also varied with the ink load (I do two test prints, at -0% and -5% ink load, to see which has better dmax).  The -0% version was cooler than the -5% one.  It's not unusual to see a tonal difference with different ink loads, but I was surprised by the degree of difference.  This paper really is different.  Hard to explain, but it just reacts differently than anything else I've tried.
Clayton
2010-01-01 by pr_roark
> 2) Both versions render cool ink tones.  ...
I agree these are very nice papers.  However, with dilute Eboni carbon inks they do not print with a cool tone.  See page 9 of http://www.paulroark.com/BW-Info/7800-Carbon-6.pdf  The Lab B of the non-OBA Alise is almost identical to H. Photo Rag.
Premier Art Smooth BW Fine Art paper prints with a notably more neutral tone with dilute Eboni.  It's what I'll continue to use and recommend for a neutral-cool image with the Eboni/Carbon-6 inksets.
Clayton,
Thank you. Yes it has been a while since the BO days. But, I still fire up the occasional BO print on my 4000; one of the best ever printer for the technique in my opinion. It gives very nice selenium-likle tones with Entrada papers.
Happy New Year. And give Steve Karrafylakis my best if you see him. He and I had done a few one-on-one print exchanges a while back.
Shilesh
> Hello Shilesh,
> Regards,
> Clayton
Hello Paul,
Ok, that's good to know.  How about with a pure undiluted Eboni-only  inkset (IOW, BO)?  Are you still using one of those sets?
Also, do you have a dmax reading for pure Eboni black?  Since I have no Eboni printer right now I can't test and update the Eboni side of my chart.  But if you have the Dmax readings I can add it.
Understood.
Clayton
Hi Clayton,
I just ran some Black Only on the 1400 with Eboni.  Briefly, the Gen. Alise Natural turned in an excellent performance.  I think it's the lowest Lab B rise I've seen with 100% carbon, going from Lab B = 1 to 3, then diving to -0.5 at 100%.  At 100% I'm getting Lab L in the 14's, with the lowest being 14.1.  This is mid-1.70's dmax.  Quite a paper.
I'll do more when I have some time.
Hello Paul,
Wonderful...but can you translate this into conversational English?  I'm not conversant with the LAB terms and really don't know what it's saying.
>At 100% I'm getting Lab L in the 14's, with the lowest being 14.1.  >This is mid-1.70's dmax.
Thanks very much.  If you can nail down an exact Dmax value I'll add it to my chart.
>Quite a paper.
Yes indeed.  Do you know of any other non-OBA paper with this kind of Dmax?  I've been using Soft Textured Art.  It's beautiful stuff but the Dmax with K3 is 1.62, good but not great.  And even at that it's one of the best I've found among natural papers.  Many are in the 1.5's, so I was happy to find it.  But this stuff blows everything else out of the water and it's less inexpensive as well. Imahappycamper <g>.
Clayton
Re: [Digital BW] Re: Generations Alise Papers - A Review
2010-01-01 by Michael King
Hi Clayton,
So the problem with dmax is that its paper AND ink dependent, as you know.
HPR is not so good with K3, but is great with Eboni - I am getting L= 14.0 -
14.2 very similar to what Paul is getting with the Alise Natural.
Mike
2010/1/1 ClaytonJ <cj@...>
> Hello Paul,
> is mid-1.70's dmax.
> my chart.
> >Quite a paper.
> Regards,
> Clayton
Hello Mike,
Yes, same with VFA but in the other direction.  It's good but lower than HPR with Eboni, but it tops all others at 1.75 with K3.  It's been my #1 paper since I began using the 2400.  This Alise Natural is a VERY welcome addition.
>I am getting L= 14.0 - 14.2 very similar to what Paul is getting with the Alise Natural.
Is there a formula for translating these L numbers into Dmax numbers like 1.7 etc that Steve's Colorimeter produces?  I look at these 14.x numbers and they have no meaning for me.
Thanks for the report.  BTW, I just posted a revision about the color tone in my original report.  Dumb mistake.
Clayton
Clayton,
I will let Paul elaborate on the LAB coordinates question. But, when I read Paul's posts (and others' too), I get excited when the B coordinates remain in the 1 to 3 range. To my eyes this range appears quite neutral. B coordinates are positive=yellow, and negative=blue. I rarely base my prints on B only. A coordinates are positive=red, and negative=green. A absolutely hate A values anywhere in the negative range, prefering A to be above +1 at all densities.
My most prefered print hue is A going from +5 in shadows to +1 in highlights. While B should hover in the +3 to +1 across the entire shadows to highlight densities. With such a set up, provided the paper white is slight +A, and slight -B gives beautiful print tones IMO. Epson EEF can meet these conditions very well.
Let me know if you want me to send you a print of such a set up with my Epson 4000 custom ink set up.
Shilesh
> Hello Paul,
> >Quite a paper.
> Regards,
> Clayton
Clayton,
L=14 is approximately Density=1.76 - That is how I keep it in my head. Although I now print mostly with newer Baryta type  papers, so I am often looking at Densities greater than 2.5 after GLOP second pass.
Shilesh
> Hello Mike,
> Regards,
> Clayton
Hi Clayton,
Calculator is here
http://www.brucelindbloom.com/index.html?CompandCalculator.html
<http://www.brucelindbloom.com/index.html?CompandCalculator.html>Its funny
because I just don't get dmax, it increases as the image get darker !!
what's that all about.
I know where it comes from and hence why old timers :) use it, but L* is so
much more useful and spectros/software don't output dmax directly to my
knowledge. When you use your spectro how you get from L* to dmax? Or are you
using a reflective densitometer :)
Mike
> Hello Mike,
> Alise Natural.
> Regards,
> Clayton
Probably not.  But, in general, the simply way to compare warmth is with the Lab B (yellow-warm positive, blue-cool negative) numbers.  Lab A (red/magenta-warm positive, green negative) is also important, but it typically varies much less.
With respect to Lab A, usually the paper manufacturers set a slight positive Lab A value and the inks or profiles keep that relatively level or slightly rising from the paper white through the midtones.  I think in B&W we really want to avoid a negative Lab A, as it'll give the print a greenish tint.  On the other hand, a Lab A that is a bit more elevated is what we'd call a light "selenium" tone.  The Premier Art Smooth BW that I like has a relatively high Lab A, and with an image like my Disney Concert Center, it gives that metallic exterior building a true metal look.
But for simplicity, Lab B is the main variable.  It's not just the absolute Lab B value, however, that matters.  The eye will do a "white balance" on whatever large white area is around.  So, if you're displaying with typical natural (not bright) white matte board, that will, roughly and typically, have a Lab B=3 or more.  So, that becomes your white reference.
So, when a natural paper has a Lab B = 1 and the image peaks out at Lab B = 3, the image is going to look quite neutral.
With respect to the Alise Natural, even when I have the test strip on my desk along with brightened typing paper, the paper looks creamy, but the image looks fairly neutral.
This varies not only with the ink, but also paper batch, printer, and how long the MK has "cured."  I suspect our spectros also vary.  With the 1400 and Eboni, my AliseN values vary from 14.1 to 14.8.  I'm not sure if the 14.1 was same day or after curing a few days.  It's what is recorded in my QTR linearization for one of my AliseN profiles, so I may well be a same-day reading (dried with a hair drier), in which case it would have broken into the Lab L = 13 range later -- very rare in my experience.
> >Quite a paper.
No, I've use a lot of Premier Art Smooth Fine Art 325, and with some printers I've seen a dmax of 1.69 with it.  On other printers or with different batches, it can be in the low 1.60's.  I used to like the PermaJet "Alpha" (oddly named -- it's Innova Soft Texture but on an cotton base, not alpha cellulose like the Innova version MIS sells, and it makes a big difference).  With PermaJet Alpha is was getting mid to sometimes high 1.60's with some printers.
>... this stuff blows everything else out of the water and it's less inexpensive as well. Imahappycamper <g>.
Yes, Premier Art may become a bigger player with this one.  I've been impressed with the company for some time.  They are close to me and have roots in the wet darkroom.  With paper they've been innovators and heavy into the longevity issue.  The Smooth BW I like, for example, does use OBAs, but the paper actually meets the silver print standards for the use of such.  They managed to negotiate a dual name with Epson on the "Epson Premier Art Scrapbook" paper, which may be Epson's most archival.  I think this enhances their credibility in that area, which, of course, was the point.  The Smooth BW that I use is, I'm told, the Scrapbook paper base with OBAs added to the coating.
By the way, I've found one source of some of the variables in my measurements.  The OBAs of typing paper under a sample being read influence the spectro measurments.  I now read only on a natural mat board.
2010-01-02 by pr_roark
Here is another effort at posting my Lab L - Density dmax cheat sheet. If the formatting doesn't work, it's posted at
http://www.paulroark.com/BW-Info/Density-Lab.pdf
Typical matte paper range:
Density Lab L
1.55    19.3
1.56    19
1.57    18.76
1.58    18.5
1.59    18.23
1.6     17.97
1.61    17.71
1.62    17.45
1.63    17.2
1.64    16.95
1.65    16.69
1.66    16.44
1.67    16.2
1.68    15.95
1.69    15.7
1.7     15.46
1.71    15.22
1.72    14.98
1.73    14.75
1.74    14.51
1.75    14.28
1.76    14.05
1.77    13.82
Typical glossy paper range:
Density Lab L
2       8.99
2.05    8.05
2.1     7.18
2.15    6.39
2.2     5.7
2.25    5.08
2.3     4.53
2.35    4.03
2.4     3.6
2.45    3.21
2.5     2.86
2.55    2.55
2.6     2.27
(Well, I'm not sure how to fool this forum's formatting into separating columns on my Lab L - Density cheat sheet.)
Moving on, I tried a 50-50 blend with the QTR sliders of Eboni BO and HP-PK in the 1400.  The tone curves are almost totally flat until a slow roll-off in the deep shadows.  That is, it's about as neutral as one can ever print.
2010-01-02 by ClaytonJ
Hello Mike,
> Calculator is here
Thanks for the link.  Unfortunately I can't view it because I need a java script plugin and I really don't want to get into that.  I took a look at the rest of his site and see that it's heavily into the technical side if things, which I have no patience for.  So I think I'll pass.
>Its funny because I just don't get dmax, it increases as the image
>get darker !!  what's that all about.
You're joking, I hope :)
>L* is so much more useful and spectros/software don't output dmax
>directly to my knowledge.
I suppose I'm an old timer, age 63 now and many years photo and darkroom experience (got first camera at age 8, first darkroom work at   19).  Dmax may be a simplistic number but it has practical meaning.  It's just a means of communication.
>L* to dmax? Or are you using a reflective densitometer
It's not mine, but I think that's what it is.  I take my test prints over to a friends house for the readings.  He puts a tethered device on a small spot on the prints, pushes a button, and the program puts a Dmax number on the screen.  He takes from 4 to 6 readings and calls them out and I write them down.  We can go through a stack of prints in just a few minutes.  That's about as technical I want to get.
When I first began the Paper Chase web page some years ago I used a visual comparison system to indicate the relative Dmax differences in papers.  I have a test image that has a solid black area.  I would sort the prints visually into groups and assign numbers from 1.0, 1.5, 2.0, etc up to 5.  It was never meant to be a high tech information site, just a resource to give people a general idea of what papers were like compared to others.  There were so many papers available and no place to compare them.
I initially got into trying a lot of papers because I was using Eboni BO and regularly used 5 or 6 different ones, depending on what suited the image.  I was always looking for the next best thing and they accumulated, so I began by listing the papers I had on hand.  I enjoyed the testing and web site work so I just kept at it and people sent me more papers to test.  Lots of people said it was a helpful resource so I kept it going.
But some of the more tech minded folks kept fussing at me for my relative rating system - they wanted numbers.  So when my friend Steve got the colorimeter he offered to do the readings for me.  So the relative Dmax ratings were replaced by real numbers.
I make my living as a computer programmer and IT guy who builds PCs for clients, so I'm not tech phobic.  I also do a fair job in Photoshop and very much enjoy that creative part, but when it comes to printing for some reason I have little patience with the high tech approach, from RIPs and curves to ink formulations.  I spent several years messing with QTR, curves, ink sets, blends, syringes, carts, chips and all of it...and got really tired of it all.  When the 2400 arrived in 2005 it was like a blessing from Heaven and I gradually retired from the ink wars.
Anyway, back to the original subject, that's why I need some Dmax numbers for Eboni.  I think this is an important new paper and there are lots of Eboni users, so I think it will be helpful to add that info to the chart.  Thanks very much for your input.
Clayton
Paul,
Thank you for taking the time, this is most helpful.
>...in general, the simply way to compare warmth is with the Lab B (yellow-warm positive, blue-cool negative) numbers.  Lab A (red/magenta-warm positive, green negative)...
Ok, this is like the ABW color circle, I can visualize it.
Understood.  Amazing that they have that much control.
This explains a lot, thank you.  I get the concept, the numbers don't automatically have meaning yet, it needs real world experience to make the connection.
Yes, I've noticed that.  It's really an interesting paper.  I'm seeing subtle things in the prints that I really like.  I'm printing an entire portrait job with it and the results so far are outstanding.  I will be very pleased to present them to the clients.
Steve mentioned hearing that this paper need curing time, so I waited 4 or 5 days before taking my prints over there.  I have no idea how accurate his device is.  Its a Colorvision Spectro Colorimeter.  I'm well aware how attributes can vary among batches (in ink as well!).
But I think you know my Paper Chase page is not promoted as a technical information site, but is just for general comparison purposes.  Since I gave in to demands and began using actual Dmax numbers I'm stuck with that and need a number.  In your last post you said mid 1.7's.  Are you comfortable with me posting 1.75 for Eboni with a caveat about the fickleness of these readings?
>>>Quite a paper.
>No, I've use a lot of Premier Art Smooth Fine Art 325, and with some printers I've seen a dmax of 1.69 with it.  On other printers or with different batches, it can be in the low 1.60's...
This has been my experience, mid 1.60's at best.
> Yes, Premier Art may become a bigger player with this one...With paper they've been innovators and heavy into the longevity issue.
That's good to hear.
It's been a source of frustration to me for a long time that people lump all OBAs together in a blanket judgement and are unwilling to rate a paper on it's individual merits.  It's easy to understand, of course, because there has never been a reliable source of trustworthy information.  Trade secrets, I guess.
Very interesting.  Well, I hope they do well because I want this paper to stay around for a long time.  And maybe they will be the ones to find a way to push matte paper Dmax even higher...
Amazing.  Steve will be interested to hear that.
Thanks very much, Paul.  This makes me feel that we're on the verge of a major technical breakthrough (which I've been hoping for for a long time).  I still like the matte papers best, just can't get into the Photo papers - can't stand the glare.
Clayton
