Thank you Paul, I was hoping you would give me some words of wisdom on this subject.
I kind of like a warm tone, and also a selenium tone look if I can figure out a ink/paper combination that will give me these. Paul if you would be willing, what are the particle sizes and surface structure types of the carbon that you use or is in Eboni, or even the Daniel Smith carbon, that would give me a bench mark to very from and to experiment to get to something that suits my particular tastes.
The Paul Smith material is the most reasonable cost per unit size I have seen i.e. reasonable package size for the cost, likely due to less than rigorous QC and thus particle size distribution, but is still quite enticing. I guess Monday I will give them a call and see if they can give me specifics on size and surface area/structure of this product. 15% to 20% W/W in one of the C6 formulations sounds very enticing, as a quick and dirty jumping off point.
On the other hand.
Do you know anything about of the general performance characteristics (on real paper) of the CAB-O-JET product line from Cabot corp.? In specific do you know anything, performance wise again on paper, about their CAB-O-JET 400 product (newest in line) that obviously isn't shown in there product sheet.
http://www.cabot-corp.com/wcm/download/en-us/ij/CAB-O-JET%20200_0209.pdf
http://www.cabot-corp.com/wcm/download/en-us/ij/CAB-O-JET%20300_0209.pdf
http://www.cabot-corp.com/wcm/download/en-us/ij/CAB-O-JET400_0209.pdf
I realize these are aqueous solutions, and I am looking for a dry product but it is a starting point to make comparison to the particle sizes and concentrations to use of the dry products I might find available in reasonable sized package quantities, or even simply just use these products as is, as you suggest, if costs and performance characteristics are right.
Thanks Again
Larry Heath
Sent: Saturday, March 06, 2010 12:09 PM
Subject: [Digital BW] Re: Carbon Black, Lamp Black
"Larry Heath" <lgheath@...> wrote:
> I am wondering if anyone out there might be in the know as to what grades of Carbon Black/Lamp Black are good starting points for building B&W inks for inkjet printing from scratch. I have an Epson Pro 4000 that I am currently using the UT7 ink set in, it does a decent job, but I know it could be better. I am thinking more and more about Carbon on Cotton, with multiple dilutions of black. Plus it seems like a do-able task and if for no other reason to say I did.
I recommend you start with a pigment that has been prepared for inkjet printing. I've used Daniel Smith pigments to experiment with, but they appear to not be ground to as uniform dimensions and not have the dispersion (usually electrostatic) coating treatment that our inkjet pigments have.
For me, the trick was to find the most neutral carbon that was already prepared for inkjets. That way simple dilution is all the more that needs to be done.
Most of the carbon that you'll find for inkjets is warm. That's the main reason I start with Eboni for my matte printing. If you like warmer, there are lost of sources of carbon, including MIS's Photo Black.
Have fun.
