Paul I can't match the specifics of your setup, but here are some Lab numbers from QTR printing in calibration mode on an old Epson Pro 4000 using MIS inks Eboni (MP-PT-K) and Light Black (MP-PT-LK) on Optica One (100% cotton) from Breathing Color 300gsm. Dmax of 1.66 is seen in the K channel at 85% (16.4,0.6,1.1) then bounces around a bit on out to 100%, but is pretty much the same. The warmest point in the K channel is at around 15% to 20%, 15% (47.5,1.5,4.5) 20% (40.6,1.6,4.4). The LK channel is pretty warm throughout, 5% (85.3,1.0,4.5) peak is somewhere between about 35% to 40%, 35% (56.7,2.0,6.2), 40% (54.2,2.0,6.2) and stays warm out to 100% (38.3,2.0,5.3). The Optica One is a heavy (300gsm) 15.4 mil, smooth matte, you can get a 17" x 20' trail roll for around $30 http://www.breathingcolor.com/action/bc_shop/130/ . I do very little on glossy paper so I can only offer this paper as a suggestion as the warmest I've seen, and that isn't saying much.
Breathing Color claims this paper has OB's but I sure can't see it, as warm as this sample roll seems to print on my old Epson 4000. I used an X-Rite PhotoMunki for the Lab numbers, and I haven't had it long either. I have only printed one or two prints on this paper and it visually seems quite warm to me, again I like warm, so its all good for me. This base paper gives me a Lab of (97.0,0.2,3.1) they claim the paper has a Lab of (97.4,1.6,-4.3). Could very well be I am doing something wrong in the measuring process, don't know. Paper looks warm to me, prints warm to me, Lab numbers seem pretty warm to me, irrespective of what they say on there web site. Any way for $30 for a 20' roll (lot # 42-52B is what I am using now and just got it about a week ago) it might cheaply get your photo printed pleasantly warm, particularly given what I saw in the link below.
I hope all this stuff isn't a waste of your time.
Later Larry
PS thanks for the link to the articles on inks, I chased through a bunch of patents relating to inkjet inks at the patent office, that was REALLY enlightening!
Thanks again
Larry
Sent: Wednesday, March 10, 2010 11:37 PM
Subject: [Digital BW] Warm carbon
I've been exploring the best way to print a photo that, I think, benefits from a very warm image tone, if not full-on sepia. So far, I think MIS LK in the 1400 (currently with HP PK) seems to be the easiest.
See http://www.paulroark.com/BW-Info/Cayucus%20Water%20Tower.pdf
The shot was taken in Cayucus, CA last Friday.
The inkset in the printer has been my Eboni-6, HP PK combo -- see http://www.paulroark.com/BW-Info/Eb1400.pdf. So, I basically wanted to just see what MIS carbon would do in the easiest fashion possible without disrupting my current inkset options significantly.
UT14 has MIS LK and PK in the Lm-M positions. So, I grabbed my UT14 LM cart, but put it in the LC spot, so that it would be paired with the HP PK that was already in the C spot. I decided to use the Epson driver (and pre-made cross-over). I made a simple, straight line Photoshop curve that is just the Red Curve (cyan ink position) from 0 to 100. With the Epson driver set to Premium Photo Semi Gloss and No Color Adjustment, the 1400 prints almost a straight line. I put the curve and spectro information into an ICC using QTR's Create ICC-RGB. Then I printed the full image.
The monitor screen grab with the ICC used to soft proof the image is quite accurate. The graph of the Lab A & B show the warmth.
I think give the ease and lack of any need to mix a sepia toner will probably cause me to just stop here, maybe substituting MIS (or Epson K2) PK for a 100% carbon PK.
I have not spent much time exploring which papers are warmest with MIS carbon, but my impression is that the glossy ones have a higher gamut, that is, warmer tone, than the matte papers. Do any other papers come to mind that might print warmer than this with carbon?
