Doepfer
Re: [Doepfer_a100] Failure of the A155 graphic VCO
2002-03-03 by davevosh@aol.com
In a message dated 3/3/2002 3:30:23 AM Eastern Standard Time,
synth_freak_2000@yahoo.com writes:
> that might mean that the pulse waveform from the a111
> isn't perfect square???
bakis,
whether perfectly square or a pulse shouldn`t matter, i would think, as the
circuitry should fire on the leading edge.
i recall that the a115 audio divider was picky about the a111 pulse output,
too.
weirder..........
best,
dave
Re: Failure of the A155 graphic VCO
2002-03-03 by duffnuff
pulse output,
> too.
yes, as well as the A113..
luckily i discovered this before buying a111s.  no probs w AS
vcos, everything tracks the pulse very well, including 155 as
graphic vco.  (and i think dieter's estimate of 10kHz ceiling is
accurate)
to switch gears real quick, i agree w joe on his argument for
need for improvements, and the a111 pulse output would be a
good place to start.
duff
2002-03-03 by bakis Sirros
hi dave,
roland mayer once told me that for the a155 clock
input to work right needs a perfect pulse with sharp
sguare egdes....
i guess that explains it all....
bakis.
> Standard Time,
> a111
> bakis,
> too.
> weirder..........
> best,
> dave
> removed]
synthfreak(parallel worlds)
athens-greece
[Doepfer_a100] group owner-moderator
Do You Yahoo!?
Yahoo! Sports - sign up for Fantasy Baseball
http://sports.yahoo.com
