RE: [Doepfer_a100] Thinking of getting a a-100 basic system
2006-04-18 by Andrew Capon
Hi Guys, Thanks to all those that have answered, it looks like I am going to have to put some more thought into this. Is there an overview document of all the modules I can download rather than looking on the Doepfer website? Cheers Andy ________________________________
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of sfrules Sent: 18 April 2006 13:33 To: Doepfer_a100@yahoogroups.com Subject: Re: [Doepfer_a100] Thinking of getting a a-100 basic system Hello, May I suggest for a basic system: Top Row Left-to-Right: HP2 Blank A-118 Noise A-111 High End VCO A-111 A-111 A-114 Dual Ring Mod A-138C Polarizing Mixer A-108 VCF8 A-131 Exp VCA Bottom Row L-R: A-190 Midi-CV A-165 Trig Mod A-146 LFO A-156 Dual Quantizer A-148 Dual S&H A-170 Dual Slew A-180 Multiples A-141 VC EG A-140 EG A-101-2 Low Pass Gate A-139 HPA The combination was inspired by the ARP 2600, but lacks the reverb. On the other hand it can do so much more. You have 3 Oscillators with hard and soft sync, all 4 waveforms, linear FM, and pulse width modulation. The polarizing mixer enables waveform addition AND subtraction. You have 2 different filters, one of which gives 4 slopes of lpf and bandpass simultaneously. You have two different VCA's. Five modules actually give double of the same function. You have midi in. ...and the Headphone amp provides a safe output voltage for external devices. In a portable case it's good to go! I'd send a graphic here but the list won't permit. Planning different configurations of your own system is going to be fun! Consider the other suggestions from the group, too. Good luck, sfrules ________________________________ YAHOO! GROUPS LINKS * Visit your group "Doepfer_a100 <http://groups.yahoo.com/group/Doepfer_a100> " on the web. * To unsubscribe from this group, send an email to: Doepfer_a100-unsubscribe@yahoogroups.com <mailto:Doepfer_a100-unsubscribe@yahoogroups.com?subject=Unsubscribe> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . ________________________________ [Non-text portions of this message have been removed]
