Doepfer
New poll for Doepfer_a100
2006-07-04 by Doepfer_a100@yahoogroups.com
Enter your vote today!  A new poll has been created for the
Doepfer_a100 group:
<p>Should Doepfer make a module that features the conversion between voltage based gate signals and switched keycontrol connections.</p>
<p>General purpose: interface switched gear (like some Moog and Korg synths, footswitch controlers etc.) with voltage based gate gear (like A-100, Roland synths,...)</p>
<ul>Connectors:
<li> "Gate in tip" (3,5mm)
<li> "Gate in ring" (3,5mm) connected via socket switch to the inverted signal of "Gate in tip"
<li> "Gate out" (3,5mm)
<li> "Switched socket in" (2-poles 6,3mmm)
<li> "Switched socket out" (3-poles 6,3mmm)
</ul>
Manual switch:
<ul>
<li> "Gate out inverted/not-inverted"
</ul>
Functions:
<ul>
<li> closed connection bewteen tip and shaft of "Switched socket in"
  produces logical high signal (10V) at gate out (if manual switch is
  set to not-inverted), open connection between tip and shaft of
  "Switched socket in" produces logical low signal (10V) at gate out.
<li> logical high signal (>0.5V) at "gate in tip", nothing connected
  to "gate in ring", causes the connection tip/shaft to be closed
  and the connection ring/shaft to be opened.
<li> logical low at "gate in tip" causes the inverted setting of tip/shaft-
  and ring/shaft connections.
<li> inserting a cable to "Gate in ring" causes a separate control for the
  ring/shaft conection of "Switched socket out".
</ul>
Possible addon:
<ul>
- real switches (reed-relais) instead of transistor switching for
  the "Switched out socket"
</ul>
  o No
  o Yes  for the version without the reed-relais addon.
  o Yes for the version whith the reed-relais addon.
  o May be
To vote, please visit the following web page:
http://groups.yahoo.com/group/Doepfer_a100/surveys?id=12372305
Note: Please do not reply to this message. Poll votes are
not collected via email. To vote, you must go to the Yahoo! Groups
web site listed above.
Thanks!
