Poll results for Doepfer_a100
2006-07-10 by Doepfer_a100@yahoogroups.com
The following Doepfer_a100 poll is now closed. Here are the final results: POLL QUESTION: Would you like Doepfer to release a Bit Processing/ Bit Swapping Module? [a new module with an Analogue to Digital converter, with analogue cv/audio inputs that accept the input analogue signals. then the module converts these to digital logic signals(gates from 0 to 5 volts). let's say that in this new module will be an 8-bit converter. (that means that the A to D converter changes the analogue input to various combinations of 8 bit's-meaning combinations of 0 and 1's / on and off gates) then we could have each of the 8 bits as digital outputs(0-5volts gate outputs) in the module's front panel and the user could send these 8 digital outputs to various processing modules like the a166 or the a162 gate delay or even the a137, or...... then the processed 8 bits could then be patched again via digital front panel minijack inputs to this new module and be converted by its onboard D to A conveter to analogue signals(cv's and audio) so, this could be an analogue/digital hubrid module that would offer the "digitized" sound for processing with the a100 modules(via digital minijack outputs on the front panel). then it would take the processed digitized bits(via its front panel digital minijack inputs) and reconvert them to analogue signals(audio and cv)] CHOICES AND RESULTS - Yes!, 14 votes, 56.00% - maybe..., 7 votes, 28.00% - no., 4 votes, 16.00% For more information about this group, please visit http://groups.yahoo.com/group/Doepfer_a100 For help with Yahoo! Groups, please visit http://help.yahoo.com/help/us/groups/
