Insertmodule
2002-03-07 by Florian Anwander
I talked today to a guy, who owns a A-100 and who uses it on stage a lot.
He had a very nice idea:
He 'd like to have a simple, complete passive module which provides several
channels like the following:
+---Insertsend-o--->o-Insertreturn------o
o-Input-Jack-+ o------Output
^^^switching jacks ^^^Selector-Switch
Example for the usage: you have a sound, that is played by a sequence. No
you want to add live a module, lets say a phaser, but you don't want to
breakup the sound. If you installed this insert-module in the audio-flow,
you simply may add the phaser to one of the inserts (which should not be
selected by the selector switch). You do your setting and toggle the switch
-> now your phaser is there.
Now you may switch somply the pahser off, by toggling the switch again, or
you insert another module on the other insert line, and toggle then.
I think, this is something, that can be realized by everybodey, who can
differ the tip of a soldering iron of its end. So it is not needed to force
Doepfer to produce this module.
Florian
Florian Anwander |ConSol* HP-Support
Tel. +49.89.45841-133 |Consulting&Solutions Software GmbH
Fax +49.89.45841-139 |Franziskanerstr. 38, D-81669 München
email: florian.anwander@consol.de |http://www.consol.de
