Doepfer
A-131 Increased Gain modification
2006-08-21 by Sean
I'm trying to modify my old style A-131 Exp. VCA module to get a
gain >1 as the output often seems weedy and I would like the option
of a little (or a lot of) overdrive.
I'm guessing that I can do this in 2 ways:
1. change the resistors connected to the audio In pots to a lower value.
2. change the resistor connected to the output voltage of the CV circuit.
So the question is... is there any information in english that will
help me identify the correct resistors to change?
Re: [Doepfer_a100] A-131 Increased Gain modification
2006-08-21 by Florian Anwander
hi Sean
I think the VCAs OTA is not the place where you should change the level.
Usually a change of amplification should be done by decreasing the
feedback resistor of an OpAmp. As far as I remember, the old A131 with
the Curtis CEM3382 does not use an separate buffer stage at the output
(thats where you might do this). So I suggest to modify a Mixer A-138,
where you could change either the feedback of the summing amp (to
amplify all four inputs), or change the input resistor of one channel.
Florian
AW: [Doepfer_a100] A-131 Increased Gain modification
2006-08-21 by hardware@doepfer.de
To increase the output level I'd recommend to increase R17 (is now 15k). To
increase the input level causing clipping/overdrive at higher input levels
I'd recommend to increase R12 (is now 47k) or to lower R13 (is now 10k).
Best wishes
Dieter Doepfer
P.S. These statements are valid only for the new version of the A-131 (not
for the CEM based old version).
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Sean
> Gesendet: Montag, 21. August 2006 13:29
> An: doepfer_a100@yahoogroups.com
> Betreff: [Doepfer_a100] A-131 Increased Gain modification
Sorry, I overlooked that Sean was asking for the old version of the A-131:
Increasing the input level: increase R10 (now 47k)
Increasing the output level: increase R12 (now 47k)
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Florian Anwander
> Gesendet: Montag, 21. August 2006 14:14
> Betreff: Re: [Doepfer_a100] A-131 Increased Gain modification
> hi Sean
> CV circuit.
> Florian
Re: A-131 Increased Gain modification
2006-08-21 by stupidpaddy
> Best wishes
> Dieter Doepfer
> > hi Sean
> > CV circuit.
> > Florian
> > Yahoo! Groups Links
hi Dieter
Is there a PDF available for the service manual for the A-131 to help me identify the
correct resistors?
vielen dank
sean
Re: [Doepfer_a100] Re: A-131 Increased Gain modification
2006-08-22 by Florian Anwander
Hi Sean
> correct resistors?
The numbers of the resistors are printed on the pcb.
Florian
AW: [Doepfer_a100] Re: A-131 Increased Gain modification
2006-08-22 by hardware@doepfer.de
Sean,
I'll send you the pcb silk screen to your email address.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von stupidpaddy
> Gesendet: Montag, 21. August 2006 19:51
> Betreff: [Doepfer_a100] Re: A-131 Increased Gain modification
> the A-131:
> > Best wishes
> > Dieter Doepfer
> > > hi Sean
> lower value.
> > > CV circuit.
> the level.
> > > Florian
> > > Yahoo! Groups Links
> hi Dieter
> correct resistors?
> vielen dank
> sean
