Doepfer
RE: [Doepfer_a100] Wooden Doepfer cabinets?
2006-09-01 by David Salter
Thanks Dieter, couldn't see for looking.
Thank you again
Rgds
David
David Salter
Senior Consultant
PSG
Reuters Messaging: david.salter.reuters.com@reuters.net
(t) +44 (0)20 7542 2402 | (m) 07990562402 | (f) 52699
Get the latest news at Reuters.com <http://www.reuters.com/>
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of hardware@doepfer.de
Sent: 31 August 2006 16:39
Subject: AW: [Doepfer_a100] Wooden Doepfer cabinets?
David,
it's in their Mounting Profiles catalogue
http://www.proma-technologie.com/englisch/rundum_l/produkte/19zoll/pdf/tprof <http://www.proma-technologie.com/englisch/rundum_l/produkte/19zoll/pdf/tprof>
_e1.pdf
On the top right edge of page 1:
Mounting Profile 1, anodized, undrilled, 1000mm long, Item no.: 125 010 1000
For the A-100 the undrilled version of the profile is OK as no guide rails
for the pc boards are used. The drilled version is required only if guide
rails have to be used.
Best wishes
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com>
> [mailto:Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> ]Im Auftrag von David Salter
> Gesendet: Donnerstag, 31. August 2006 16:33
> An: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com>
> Betreff: RE: [Doepfer_a100] Wooden Doepfer cabinets?
> Dieter,
> I've just checked their PDF's and they only have part numbers for
> mounting profiles for lengths upto 432mm, is it possible for one
> of your purchasing people to provide the part number you order with?
> It maybe that it's a bespoke item as it's longer than a standard 19" rack?
> Many thanks
> David
> David Salter
> Senior Consultant
> PSG
> Reuters Messaging: david.salter.reuters.com@reuters.net <mailto:david.salter.reuters.com%40reuters.net>
> Get the latest news at Reuters.com <http://www.reuters.com/ <http://www.reuters.com/> >
> From: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com>
> [mailto:Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> ] On Behalf Of hardware@doepfer.de <mailto:hardware%40doepfer.de>
> Sent: 31 August 2006 15:17
> To: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com>
> David,
> ProMa has a representative in UK. You could order from them directly:
> Unimatic Engineers Ltd.
> 130 Granville Road
> GB London NW2 2LN
> Phone: 0044 (020) 8922 1000
> Fax: 0044 (020) 8922 1066
> E-Mail: sales@unimatic.com <mailto:sales%40unimatic.com>  <mailto:sales%40unimatic.com>
> The order numbers can be found in the brochure that is available
> as pdf file
> from ProMa's website. Representatives in other countries can be found on
> ProMa's website www.proma-technologie.com > English > ABOUT US > AGENCIES.
> Otherwise I could ask in our sales office for the shipping charges
> (approximately in the same range as for our keyboards as they are
> more than
> 1 m in length too).
> And don't forget to order the threaded inserts and self tapping screws if
> you need these parts too. Standard hexagon M3 nuts can be used too (much
> cheaper) but they will glide within the rails and it may be difficult to
> move them at the right positions.
> Best wishes
> Dieter Doepfer
> > Gesendet: Donnerstag, 31. August 2006 14:20
> <mailto:Doepfer_a100%40yahoogroups.com> ; hardware@doepfer.de <mailto:hardware%40doepfer.de>
> > Dieter ,
> > That sounds interesting, I could certainly use 4 of those for my
> > new cab (maybe 6).
> > Any idea how much to send to the UK?
> > Many thanks
> > David
> > David Salter
> > Senior Consultant
> > PSG
> hardware@doepfer.de <mailto:hardware%40doepfer.de>  <mailto:hardware%40doepfer.de>
> > Sent: 31 August 2006 10:43
> > Our supplier (ProMa, Germany) is able to deliver suitable rails
> > with 1 m in length (about 15 Euro each). We need these for our
> > A-100 monster cases. If they have to be shortened to a specific
> > length they ask for additional 18 Euro (!!!). We could order
> > these rails as special parts for interested customers but I
> > expect very high shipping charges because of the unusual length.
> > I recommend to look in your own country to find a supplier of rails.
> > The rails can be mounted to the wooden cases at both end with
> > suitable self-tapping screws (even available from ProMa or from
> > us) as described on the A-100 DIY page. Threaded inserts or
> > normal M3 screws can be inserted into the rails for module
> > mounting. If the length is not a multiple of 84HP the threaded
> > inserts have to be shortened as they are available only for 84HP
> > (not available with 1 m length).
> > Best wishes
> > Dieter Doepfer
> > > Gesendet: Donnerstag, 31. August 2006 10:00
> > > Yep Michaels experiences echo my own. My first DIY cab had wooden
> > > rails and it proved to be a real pain as my module collection
> > > increased and I needed to shuffle the modules around.
> > > My current cases use standard metal rails. These can be a tad tricky
> > > to install - especially as my cab is double width and you need to
> > > screw two together - but it's worth the extra effort.
> > > If your carpentry skills are non existent you can always track down a
> > > local cabinet maker. Important thing is to plan it out well.
> > > If you are having a sloped section remember to allow for module depth
> > > not interfering with the lower row of modules, either keep the slope
> > > shallow or include a spaced section - can be used for multiples (lots
> > > of
> > > them) :)
> > > Rgds
> > > David
> > > David Salter
> > > Senior Consultant
> > > PSG
> <http://www.reuters.com/ <http://www.reuters.com/> > >
> > > On Behalf Of Michael Wagner
> > > Sent: 30 August 2006 21:19
> > > Subject: Re: [Doepfer_a100] Wooden Doepfer cabinets?
> > > On 8/30/06, brownchonald <chonald@gmail.com <mailto:chonald%40gmail.com>
> > > > wrote:
> > > > Are there any cabinets, like the old Moog Modular cabinets, for
> > > > Doepfer modules?
> > > > I don't like the way the suitcases look. I want some wooden.
> > > > I know of www.nice-racks.com, but I'd like some that is a little
> > > > wider than just 19 inches. Is there anywhere I can get
> > something like this?
> > > I don't know about the ones you can buy, but I built one myself,
> > > although I'm not a good/experienced woodworker. In fact, I'm a quite
> > > bad one... The cabinet itself is not that big of a deal (well, you
> > > have to invest some time, but it's not that hard to build it
> > > accurately), but I had problems with the "rails", which in my case are
> > > wooden... I wouldn't do it that way anymore, instead I would go with
> > > the standard-rails, that Doepfer-cases use. It's hard to get good
> > > screws for wood in that tiny size, and if I want to move modules, I
> > > have to be very careful not to break the wooden bars. (I had to use
> > > thin ones because I built a sloped cabinet).
> > > Hope, that helps a bit,
> > > -Michael
> > > To find out more about Reuters visit www.about.reuters.com
> > > Any views expressed in this message are those of the individual
> > > sender, except where the sender specifically states them to be the
> > > views of Reuters Ltd.
> > > [Non-text portions of this message have been removed]
> > > Yahoo! Groups Links
> > Yahoo! Groups Links
> > the views of Reuters Ltd.
> > Yahoo! Groups Links
Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Reuters Ltd.
