Doepfer
RS stuff with Doepfer based Euro Rack
2006-09-20 by southsubnotsubdude
i'm putting together a new rack to keep steady company with my A100
Basic...i've got a Doepfer PS2, bus rail (and a BBD 2048 hehe)....i'm
doing some window shopping and like the sound of the Analogue Systems
RS Putney filter and the features of other mods seem to compliment the
Doepfer nicely (don't worry Mr. Doepfer, i still love you)...so what
does it take to hook up the AS stuff to the doepfer PS2/bus rail? i
heard something about  a special plug or something...
Re: [Doepfer_a100] RS stuff with Doepfer based Euro Rack
2006-09-20 by Ross Goniakowski
i'd also like to hear a bit about any Analogue Systems mod experience...any favorites? anyone have the Putney filter?
  seems now that i'm going to have some space, i can use it to mix & match...seems like what the Eurorack format is really about, eh?
Re: RS stuff with Doepfer based Euro Rack
2006-09-21 by selfoscillate
you need a special cable to plug the AS modules into
a doepfer frame. i have a few, but won't sell them ;-)
i got them from "touched by sound" in germany, but i'm
sure that these can be obtained elsewhere too, or
you can build them on your own. i believe that a description
is in the files section of this group.
i also have to point out that some AS modules won't work
in a doepfer frame (f.e. the rs360 filterbank), so you should
contact AS and ask for compatibility of the desired module.
another important point is that some AS modules need additional
5 volts, so you probably need to ask for that too.
a 5 volts lowcost adapter is available from doepfer, which
is doing this job nicely for loads not exceeding 100 ma.
and mounting other brand modules into a doepfer frame will
probably void the warranty!!
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "southsubnotsubdude" <carfull@...>
you can find some sound examples on my homepage, where i
have roughly compared the rs500e with the a102 doide filter.
just check the modular examples section.
http://www.selfoscillate.de
i had the chance to try out the rs370 and the rs290
when i was visiting bakis and these two modules are
really marvelous, but also quite expensive.
from the AS modules i own i like most the rs510e and the rs120.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, Ross Goniakowski <carfull@...>
with my A100
hehe)....i'm
Systems
what
2006-09-21 by Brian Thurmond
www.bigcitymusic.com sells the adapter for plugging an Analogue
Systems module to a Doepfer power bus.
--- In Doepfer_a100@yahoogroups.com, "selfoscillate"
> best wishes
> ingo
<carfull@>
A100
hehe)....i'm
Systems
compliment
> the
what
i
Re: [Doepfer_a100] Re: RS stuff with Doepfer based Euro Rack
2006-09-21 by Ross Goniakowski
actually i ended up finding that....but thanks....
  actually to make ones one may be cheaper, but who knows, might be more of a pain in the ass...
  but you know,  it's pretty cool do be able to mix and match these resonably priced mods into a system to be reckoned with...
> best wishes
> ingo
<carfull@>
A100
hehe)....i'm
Systems
compliment
> the
what
i
