A-112 Help
2006-11-08 by beakanddune
Hi all, I have a new A--112 Sampler that I'm having trouble with and although I think its probably faulty I thought that I'd see whether any other users have experienced the issue I'm experiencing. I have a TR-606 plugged into the audio input and the audio output is plugged into a mixer. I have the top switch set to S1 (bank 1), the second switch set to 'REC' (record) and the third switch set to 'Normal' (centre position). I can monitor the output of the 606 through the module with these settings and if I adjust the 'tune' pot it audibly alters the sampling frequency as one would expect. I then press the 'trig' button for a second to sample some of the 606 output. The LED lights as one would expect. Then if I switch the second switch from 'REC' to 'PLAY' and press the 'trig' button again to listen to my sample I hear nothing but a loud click. I've tried gating the module with a Wiard joystick instead of using the trigger button, I've tried a different audio source, applied CV to the pitch CV in, changed all the switches and generally tried every permutation of possible permutations to get some noise out of the thing. The only noise that emanates is some strage noise that sometimes appears in 'REC' mode when nothing is plugged into the audio input. If anyone has any ideas or suggestions I'd be most appreciative. Cheers Simon
