news (preliminary)
2006-11-17 by hardware@doepfer.de
Dear members, some "hidden" preliminary information has been added to our website (so far not available as links from other pages) A-100 LCD scope: www.doepfer.de/1972.htm A-100 universal AD/DA module: www.doepfer.de/A100_ADDA.htm DIY/OEM module with 64 inputs and Midi/USB output: www.doepfer.de/usb64.htm Have a nice weekend Dieter Doepfer
2006-11-21 by Richard
Hi I'm looking for some cross headed self tapping screws to attach doepfer and AS modules into a wooden rack rail - most I've found are too big to go through the holes in the modules anyone know of a UK source for these - or even a part number?? they are surprisingly difficult items to source! richard [Non-text portions of this message have been removed]
2006-11-21 by hardware@doepfer.de
Richard, 2.9 mm is a standard diameter for self tapping screws and these will fit to the 3 mm mounting holes of the A-100 panels (standard sizes are e.g. 2.9 x 6.5 mm, 9.5 x 9.5 mm and 2.9 x 13 mm). It should be no problem to get these screws in a hardware store or in a specialized screw shop. Best wishes Dieter Doepfer -----Urspr�ngliche Nachricht----- Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Richard Gesendet: Dienstag, 21. November 2006 17:56 An: Doepfer_a100@yahoogroups.com Betreff: [Doepfer_a100] self tapping screws Hi I'm looking for some cross headed self tapping screws to attach doepfer and AS modules into a wooden rack rail - most I've found are too big to go through the holes in the modules anyone know of a UK source for these - or even a part number?? they are surprisingly difficult items to source! richard [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
2006-11-23 by hardware@doepfer.de
Dear members, I designed a crossfader module based on Florian's suggestions. Here is the link for the preliminary info: www.doepfer.de/a138d.htm It is only a preliminary version and should be treated as as basis for discussions. From my point of view there are three possible ways: 1. A complete module similar to the suggested A-138d 2. An expansion module that has to be connected to an existing A-138 (a or b). This would be a little bit cheaper as the electronics of the A-138 can be used (but not much as the electromechanical parts remain the same and the electronics is not very expensive). For this solution the single outputs would not be available and a little bit of soldering is necessary (2 wires have to be soldered to the A-138). I don't think that this solution is meaningful. 3. same as 2. but only as a DIY project. It's very simple. Most of the work will be the front panel processing. The "electronics" is only a few resistors some potentiometers. I can publish the schematics on the A-100 DIY page. Bakis, maybe a poll will be helpful (thank you in advance ... :-). And of course ideas/improvements of the suggested A-138d. Best wishes Dieter Doepfer
2006-11-26 by bellenger_a
Hello, Me, somehow I really like the idea of extension for A138 with 5 channels... to make easy cheap 8 step sequencer with A160/161 and another A138... + Alexandre --- In Doepfer_a100@yahoogroups.com, <hardware@...> wrote:
> > Dear members, > > I designed a crossfader module based on Florian's suggestions. Here is the > link for the preliminary info: > > www.doepfer.de/a138d.htm > > It is only a preliminary version and should be treated as as basis for > discussions. From my point of view there are three possible ways: > > 1. A complete module similar to the suggested A-138d > > 2. An expansion module that has to be connected to an existing A-138 (a or > b). This would be a little bit cheaper as the electronics of the A-138 can > be used (but not much as the electromechanical parts remain the same and the > electronics is not very expensive). For this solution the single outputs > would not be available and a little bit of soldering is necessary (2 wires > have to be soldered to the A-138). I don't think that this solution is > meaningful. > > 3. same as 2. but only as a DIY project. It's very simple. Most of the work > will be the front panel processing. The "electronics" is only a few > resistors some potentiometers. I can publish the schematics on the A-100 DIY > page. > > Bakis, maybe a poll will be helpful (thank you in advance ... :-). And of > course ideas/improvements of the suggested A-138d. > > Best wishes > Dieter Doepfer >
2006-11-27 by hardware@doepfer.de
Alexandre, It's possible to link two A-138 to obtain a 8 channel mixer. I can add a corresponding note to the DIY page. Let me know if you are interested (one integrated circuit has to be removed and two cables have to be soldered between the two A-138). An passive expansion module for the A-138 with 5 inputs would be possible but not cheaper as the expensive mechanical parts (potentiometers, knobs, sockets, front panel) are the same. But we will "design" such a simple electronics (it will take about 30 minutes) and see if there are suffient inquiries to produce that mixer expansion. Best wishes Dieter Doepfer -----Ursprüngliche Nachricht----- Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von bellenger_a Gesendet: Sonntag, 26. November 2006 11:32 An: Doepfer_a100@yahoogroups.com Betreff: [Doepfer_a100] Re: Crossfader module Hello, Me, somehow I really like the idea of extension for A138 with 5 channels... to make easy cheap 8 step sequencer with A160/161 and another A138... + Alexandre --- In Doepfer_a100@yahoogroups.com, <hardware@...> wrote: > > Dear members, > > I designed a crossfader module based on Florian's suggestions. Here is the > link for the preliminary info: > > www.doepfer.de/a138d.htm > > It is only a preliminary version and should be treated as as basis for > discussions. From my point of view there are three possible ways: > > 1. A complete module similar to the suggested A-138d > > 2. An expansion module that has to be connected to an existing A-138 (a or > b). This would be a little bit cheaper as the electronics of the A-138 can > be used (but not much as the electromechanical parts remain the same and the > electronics is not very expensive). For this solution the single outputs > would not be available and a little bit of soldering is necessary (2 wires > have to be soldered to the A-138). I don't think that this solution is > meaningful. > > 3. same as 2. but only as a DIY project. It's very simple. Most of the work > will be the front panel processing. The "electronics" is only a few > resistors some potentiometers. I can publish the schematics on the A-100 DIY > page. > > Bakis, maybe a poll will be helpful (thank you in advance ... :-). And of > course ideas/improvements of the suggested A-138d. > > Best wishes > Dieter Doepfer > [Non-text portions of this message have been removed]
2008-04-08 by Richard Scott
I am replying to an old thread. If anyone knows of a UK or German source for Doepfer compatible self tapping screws then please shout up they are: 2.9 mm or 2.5 mm pan head pozidrive self tapping screws (6.5mm 0r 9.5mm in length), they are also known as guage 3. all the UK shops and componant suppliers I tried now stock nothing below guage4 which is 3mm and too big for the a100 holes. Several places have told me that the guage 3 are no longer manufactured - which seems unbelievable.... but it appears to be true Richard
----- Original Message ----- From: <hardware@doepfer.de> To: <Doepfer_a100@yahoogroups.com> Sent: Tuesday, November 21, 2006 7:39 PM Subject: AW: [Doepfer_a100] self tapping screws Richard, 2.9 mm is a standard diameter for self tapping screws and these will fit to the 3 mm mounting holes of the A-100 panels (standard sizes are e.g. 2.9 x 6.5 mm, 9.5 x 9.5 mm and 2.9 x 13 mm). It should be no problem to get these screws in a hardware store or in a specialized screw shop. Best wishes Dieter Doepfer -----Ursprüngliche Nachricht----- Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Richard Gesendet: Dienstag, 21. November 2006 17:56 An: Doepfer_a100@yahoogroups.com Betreff: [Doepfer_a100] self tapping screws Hi I'm looking for some cross headed self tapping screws to attach doepfer and AS modules into a wooden rack rail - most I've found are too big to go through the holes in the modules anyone know of a UK source for these - or even a part number?? they are surprisingly difficult items to source! richard [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Yahoo! Groups Links -- I am using the free version of SPAMfighter for private users. It has removed 440 spam emails to date. Paying users do not have this message in their emails. Get the free SPAMfighter here: http://www.spamfighter.com/len
2008-04-08 by Floppy
have you tried schroff yet ? http://www.schroff.co.uk/internet/html_e/index.html Richard Scott schrieb: > > I am replying to an old thread. If anyone knows of a UK or German > source for > Doepfer compatible self tapping screws then please shout up > > they are: 2.9 mm or 2.5 mm pan head pozidrive self tapping screws > (6.5mm 0r > 9.5mm in length), they are also known as guage 3. > > all the UK shops and componant suppliers I tried now stock nothing below > guage4 which is 3mm and too big for the a100 holes. Several places > have told > me that the guage 3 are no longer manufactured - which seems > unbelievable.... but it appears to be true > > Richard > > ----- Original Message ----- > From: <hardware@doepfer.de <mailto:hardware%40doepfer.de>> > To: <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com>> > Sent: Tuesday, November 21, 2006 7:39 PM > Subject: AW: [Doepfer_a100] self tapping screws > > Richard, > > 2.9 mm is a standard diameter for self tapping screws and these will > fit to > the 3 mm mounting holes of the A-100 panels (standard sizes are e.g. 2.9 x > 6.5 mm, 9.5 x 9.5 mm and 2.9 x 13 mm). It should be no problem to get > these > screws in a hardware store or in a specialized screw shop. > Best wishes > Dieter Doepfer > > -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com > <mailto:Doepfer_a100%40yahoogroups.com> > [mailto:Doepfer_a100@yahoogroups.com > <mailto:Doepfer_a100%40yahoogroups.com>]Im > Auftrag von Richard > Gesendet: Dienstag, 21. November 2006 17:56 > An: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> > Betreff: [Doepfer_a100] self tapping screws > > Hi > > I'm looking for some cross headed self tapping screws to attach doepfer > and AS modules into a wooden rack rail - most I've found are too big to go > through the holes in the modules > > anyone know of a UK source for these - or even a part number?? > > they are surprisingly difficult items to source! > > richard > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > Yahoo! Groups Links > > -- > I am using the free version of SPAMfighter for private users. > It has removed 440 spam emails to date. > Paying users do not have this message in their emails. > Get the free SPAMfighter here: http://www.spamfighter.com/len > <http://www.spamfighter.com/len> > > [Non-text portions of this message have been removed]
2008-04-08 by David Salter
Hi Richard, I had the same requirement and found something suitable in my local B&Q Depot. Rgds David David Salter Senior Consultant PSG Reuters Messaging: david.salter.reuters.com@reuters.net (t) +44 (0)20 7542 2402 | (m) 07990562402 | (f) 52699 Get the latest news at Reuters.com <http://www.reuters.com/> ________________________________
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of Richard Scott Sent: 08 April 2008 09:43 To: Doepfer_a100@yahoogroups.com Subject: Re: [Doepfer_a100] self tapping screws I am replying to an old thread. If anyone knows of a UK or German source for Doepfer compatible self tapping screws then please shout up they are: 2.9 mm or 2.5 mm pan head pozidrive self tapping screws (6.5mm 0r 9.5mm in length), they are also known as guage 3. all the UK shops and componant suppliers I tried now stock nothing below guage4 which is 3mm and too big for the a100 holes. Several places have told me that the guage 3 are no longer manufactured - which seems unbelievable.... but it appears to be true Richard ----- Original Message ----- From: <hardware@doepfer.de <mailto:hardware%40doepfer.de> > To: <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> > Sent: Tuesday, November 21, 2006 7:39 PM Subject: AW: [Doepfer_a100] self tapping screws Richard, 2.9 mm is a standard diameter for self tapping screws and these will fit to the 3 mm mounting holes of the A-100 panels (standard sizes are e.g. 2.9 x 6.5 mm, 9.5 x 9.5 mm and 2.9 x 13 mm). It should be no problem to get these screws in a hardware store or in a specialized screw shop. Best wishes Dieter Doepfer -----Ursprüngliche Nachricht----- Von: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> [mailto:Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> ]Im Auftrag von Richard Gesendet: Dienstag, 21. November 2006 17:56 An: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> Betreff: [Doepfer_a100] self tapping screws Hi I'm looking for some cross headed self tapping screws to attach doepfer and AS modules into a wooden rack rail - most I've found are too big to go through the holes in the modules anyone know of a UK source for these - or even a part number?? they are surprisingly difficult items to source! richard [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Yahoo! Groups Links -- I am using the free version of SPAMfighter for private users. It has removed 440 spam emails to date. Paying users do not have this message in their emails. Get the free SPAMfighter here: http://www.spamfighter.com/len <http://www.spamfighter.com/len> This email was sent to you by Reuters, the global news and information company. To find out more about Reuters visit www.about.reuters.com Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Reuters Limited. Reuters Limited is part of the Reuters Group of companies, of which Reuters Group PLC is the ultimate parent company. Reuters Group PLC - Registered office address: The Reuters Building, South Colonnade, Canary Wharf, London E14 5EP, United Kingdom Registered No: 3296375 Registered in England and Wales [Non-text portions of this message have been removed]
2008-04-08 by charles kerr
Richard, Clerkenwell screws in London has them (they have everything!) very cheap if I remember correctly.. Charlie David Salter <david.salter@reuters.com> wrote: Hi Richard, I had the same requirement and found something suitable in my local B&Q Depot. Rgds David David Salter Senior Consultant PSG Reuters Messaging: david.salter.reuters.com@reuters.net (t) +44 (0)20 7542 2402 | (m) 07990562402 | (f) 52699 Get the latest news at Reuters.com <http://www.reuters.com/> ________________________________
Richard
Richard,
Best wishes
Dieter Doepfer
Auftrag von Richard
Hi
richard
Yahoo! Groups Links
Yahoo! for Good helps you make a difference
[Non-text portions of this message have been removed]2008-04-08 by Richard Scott
Hi thanks for the suggestions, but I am confused about the UK screw guages. some manufacturers list guage 4 as 3 mm which is too big for the doepfer holes and some list it as 2.9 which is fine... do any UK folks know if you bpought guage 4 or guage 3?? Richard
----- Original Message ----- From: charles kerr To: Doepfer_a100@yahoogroups.com Sent: Tuesday, April 08, 2008 11:55 AM Subject: RE: [Doepfer_a100] self tapping screws Richard, Clerkenwell screws in London has them (they have everything!) very cheap if I remember correctly.. Charlie David Salter <david.salter@reuters.com> wrote: Hi Richard, I had the same requirement and found something suitable in my local B&Q Depot. Rgds David David Salter Senior Consultant PSG Reuters Messaging: david.salter.reuters.com@reuters.net (t) +44 (0)20 7542 2402 | (m) 07990562402 | (f) 52699 Get the latest news at Reuters.com <http://www.reuters.com/> ________________________________ From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of Richard Scott Sent: 08 April 2008 09:43 To: Doepfer_a100@yahoogroups.com Subject: Re: [Doepfer_a100] self tapping screws I am replying to an old thread. If anyone knows of a UK or German source for Doepfer compatible self tapping screws then please shout up they are: 2.9 mm or 2.5 mm pan head pozidrive self tapping screws (6.5mm 0r 9.5mm in length), they are also known as guage 3. all the UK shops and componant suppliers I tried now stock nothing below guage4 which is 3mm and too big for the a100 holes. Several places have told me that the guage 3 are no longer manufactured - which seems unbelievable.... but it appears to be true Richard ----- Original Message ----- From: <hardware@doepfer.de <mailto:hardware%40doepfer.de> > To: <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> > Sent: Tuesday, November 21, 2006 7:39 PM Subject: AW: [Doepfer_a100] self tapping screws Richard, 2.9 mm is a standard diameter for self tapping screws and these will fit to the 3 mm mounting holes of the A-100 panels (standard sizes are e.g. 2.9 x 6.5 mm, 9.5 x 9.5 mm and 2.9 x 13 mm). It should be no problem to get these screws in a hardware store or in a specialized screw shop. Best wishes Dieter Doepfer -----Ursprüngliche Nachricht----- Von: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> [mailto:Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> ]Im Auftrag von Richard Gesendet: Dienstag, 21. November 2006 17:56 An: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> Betreff: [Doepfer_a100] self tapping screws Hi I'm looking for some cross headed self tapping screws to attach doepfer and AS modules into a wooden rack rail - most I've found are too big to go through the holes in the modules anyone know of a UK source for these - or even a part number?? they are surprisingly difficult items to source! richard [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Yahoo! Groups Links -- I am using the free version of SPAMfighter for private users. It has removed 440 spam emails to date. Paying users do not have this message in their emails. Get the free SPAMfighter here: http://www.spamfighter.com/len <http://www.spamfighter.com/len> This email was sent to you by Reuters, the global news and information company. To find out more about Reuters visit www.about.reuters.com Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Reuters Limited. Reuters Limited is part of the Reuters Group of companies, of which Reuters Group PLC is the ultimate parent company. Reuters Group PLC - Registered office address: The Reuters Building, South Colonnade, Canary Wharf, London E14 5EP, United Kingdom Registered No: 3296375 Registered in England and Wales [Non-text portions of this message have been removed] --------------------------------- Yahoo! for Good helps you make a difference [Non-text portions of this message have been removed] -- I am using the free version of SPAMfighter for private users. It has removed 440 spam emails to date. Paying users do not have this message in their emails. Get the free SPAMfighter here: http://www.spamfighter.com/len [Non-text portions of this message have been removed]
2008-04-09 by David Salter
Sorry Richard, I have no idea what gauge, but they did the job, just lucky I guess. David David Salter Senior Consultant PSG Reuters Messaging: david.salter.reuters.com@reuters.net (t) +44 (0)20 7542 2402 | (m) 07990562402 | (f) 52699 Get the latest news at Reuters.com <http://www.reuters.com/> ________________________________
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of Richard Scott Sent: 08 April 2008 15:59 To: Doepfer_a100@yahoogroups.com Subject: Re: [Doepfer_a100] self tapping screws Hi thanks for the suggestions, but I am confused about the UK screw guages. some manufacturers list guage 4 as 3 mm which is too big for the doepfer holes and some list it as 2.9 which is fine... do any UK folks know if you bpought guage 4 or guage 3?? Richard ----- Original Message ----- From: charles kerr To: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> Sent: Tuesday, April 08, 2008 11:55 AM Subject: RE: [Doepfer_a100] self tapping screws Richard, Clerkenwell screws in London has them (they have everything!) very cheap if I remember correctly.. Charlie David Salter <david.salter@reuters.com <mailto:david.salter%40reuters.com> > wrote: Hi Richard, I had the same requirement and found something suitable in my local B&Q Depot. Rgds David David Salter Senior Consultant PSG Reuters Messaging: david.salter.reuters.com@reuters.net <mailto:david.salter.reuters.com%40reuters.net> (t) +44 (0)20 7542 2402 | (m) 07990562402 | (f) 52699 Get the latest news at Reuters.com <http://www.reuters.com/ <http://www.reuters.com/> > ________________________________ From: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> [mailto:Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> ] On Behalf Of Richard Scott Sent: 08 April 2008 09:43 To: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> Subject: Re: [Doepfer_a100] self tapping screws I am replying to an old thread. If anyone knows of a UK or German source for Doepfer compatible self tapping screws then please shout up they are: 2.9 mm or 2.5 mm pan head pozidrive self tapping screws (6.5mm 0r 9.5mm in length), they are also known as guage 3. all the UK shops and componant suppliers I tried now stock nothing below guage4 which is 3mm and too big for the a100 holes. Several places have told me that the guage 3 are no longer manufactured - which seems unbelievable.... but it appears to be true Richard ----- Original Message ----- From: <hardware@doepfer.de <mailto:hardware%40doepfer.de> <mailto:hardware%40doepfer.de> > To: <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> <mailto:Doepfer_a100%40yahoogroups.com> > Sent: Tuesday, November 21, 2006 7:39 PM Subject: AW: [Doepfer_a100] self tapping screws Richard, 2.9 mm is a standard diameter for self tapping screws and these will fit to the 3 mm mounting holes of the A-100 panels (standard sizes are e.g. 2.9 x 6.5 mm, 9.5 x 9.5 mm and 2.9 x 13 mm). It should be no problem to get these screws in a hardware store or in a specialized screw shop. Best wishes Dieter Doepfer -----Ursprüngliche Nachricht----- Von: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> <mailto:Doepfer_a100%40yahoogroups.com> [mailto:Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> <mailto:Doepfer_a100%40yahoogroups.com> ]Im Auftrag von Richard Gesendet: Dienstag, 21. November 2006 17:56 An: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> <mailto:Doepfer_a100%40yahoogroups.com> Betreff: [Doepfer_a100] self tapping screws Hi I'm looking for some cross headed self tapping screws to attach doepfer and AS modules into a wooden rack rail - most I've found are too big to go through the holes in the modules anyone know of a UK source for these - or even a part number?? they are surprisingly difficult items to source! richard [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Yahoo! Groups Links -- I am using the free version of SPAMfighter for private users. It has removed 440 spam emails to date. Paying users do not have this message in their emails. Get the free SPAMfighter here: http://www.spamfighter.com/len <http://www.spamfighter.com/len> <http://www.spamfighter.com/len <http://www.spamfighter.com/len> > This email was sent to you by Reuters, the global news and information company. To find out more about Reuters visit www.about.reuters.com Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Reuters Limited. Reuters Limited is part of the Reuters Group of companies, of which Reuters Group PLC is the ultimate parent company. Reuters Group PLC - Registered office address: The Reuters Building, South Colonnade, Canary Wharf, London E14 5EP, United Kingdom Registered No: 3296375 Registered in England and Wales [Non-text portions of this message have been removed] --------------------------------- Yahoo! for Good helps you make a difference [Non-text portions of this message have been removed] -- I am using the free version of SPAMfighter for private users. It has removed 440 spam emails to date. Paying users do not have this message in their emails. Get the free SPAMfighter here: http://www.spamfighter.com/len <http://www.spamfighter.com/len> [Non-text portions of this message have been removed] This email was sent to you by Reuters, the global news and information company. To find out more about Reuters visit www.about.reuters.com Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Reuters Limited. Reuters Limited is part of the Reuters Group of companies, of which Reuters Group PLC is the ultimate parent company. Reuters Group PLC - Registered office address: The Reuters Building, South Colonnade, Canary Wharf, London E14 5EP, United Kingdom Registered No: 3296375 Registered in England and Wales [Non-text portions of this message have been removed]
