Doepfer
more a188/2 examples
2006-11-27 by selfoscillate
hello list,
some more a188/2 examples (again mono), now using
an envelope for modulation of the delay time.
1.
a simple synth sequence is used as audio input.
the 3328 stages output is patched to the feedback input.
manual delay time knob set to maximum (fully clockwise).
mix is set to center position (50/50 mix).
recorded directly from the a188/2 output, without filter.
in the beginning you hear the a188/2 without modulation,
then slowly the (negative) envelope is applied.
http://www.selfoscillate.de/a100files/a188-2-envmod1.mp3
2.
almost the same patch with different knob settings.
the recording starts with the mix knob fully counterclockwise
(dry original signal). then the mix knob is turned slowly
to center position (50/50 mix). the bbd output is filtered by
an a108 lowpass filter. the example is recorded from
the 48db output of the a108.
http://www.selfoscillate.de/a100files/a188-2-envmod2.mp3
3.
same as example 2, with different knob settings.
http://www.selfoscillate.de/a100files/a188-2-envmod3.mp3
4.
this time the attack and decay parameters of the envelope are
changed during recording. again the bbd output is filtered by
an a108 lowpass filter (using the 48db output).
http://www.selfoscillate.de/a100files/a188-2-envmod4.mp3
best wishes
ingo
Re: [Doepfer_a100] more a188/2 examples
2006-11-28 by Bakis Sirros
very nice!!
best regards,
Bakis.
--- selfoscillate <synaptic_music@yahoo.com> wrote:
> hello list,
> 1.
> input.
> clockwise).
> filter.
> modulation,
> 2.
> counterclockwise
> slowly
> filtered by
> 3.
> 4.
> envelope are
> filtered by
> best wishes
> ingo
Bakis Sirros - Parallel Worlds
[Doepfer_a100] group owner
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail beta.
http://new.mail.yahoo.com
2006-11-30 by J S
Thanks Ingo,
very nice indeed
Jean
2006/11/29, Bakis Sirros <synth_freak_2000@yahoo.com>:
>   very nice!!
> best regards,
> Bakis.
> --- selfoscillate <synaptic_music@yahoo.com <synaptic_music%40yahoo.com>>
> wrote:
> > hello list,
> > 1.
> > input.
> > clockwise).
> > filter.
> > modulation,
> > 2.
> > counterclockwise
> > slowly
> > filtered by
> > 3.
> > 4.
> > envelope are
> > filtered by
> > best wishes
> > ingo
> Athens-Greece
> Do you Yahoo!?
