Doepfer
ual Logic help
ual Logic help
2006-12-20 by cray5656
Hi all
I have just bought a dual logic and have no idea how to patch it up,
if it is suppose to be purely audio or cd,,,can some on give me a
patch idea say from a vco to dual logic
TIA
Re: ual Logic help
2006-12-20 by ilanode
Hello, the Dual Logic A166 is designed to combine 2 or more trigger
signals accdording to Boolean logic (re: page 3 of the manual) to
derive a new rhythmical pattern otherwise not present. Regards, Ingo
--- In Doepfer_a100@yahoogroups.com, "cray5656" <amnesia@...> wrote:
> Hi all
> TIA
Re: [Doepfer_a100] ual Logic help
2006-12-20 by Florian Anwander
Hi
The A-166 is intended for the usage with digital signals like gates and
triggers. its not intended for the direcct usage with audio (Though you
may be able to use it as killer distortion if you insert two or more ;-)).
Florian
Re: ual Logic help
2006-12-20 by Harry
Hi TIA,
In the manual you can find some patch examples.
http://www.doepfer.de/a100_man/a166_man.pdf
Harry.
> Hi all
> TIA
