Doepfer
A111 with A163
A111 with A163
2006-12-30 by bellenger_a
I have also something with my A111... it doesnt work with A163. When I plug square wave
into the A163... it works for 5 seconds then nothing. But the A163 worksok with A110 or
A196.
Can I do something to sort this out?
Best,
Alexandre
Re: [Doepfer_a100] A111 with A163
2006-12-30 by Jay
> A196.
"> I checked the A-163 with an A-111. A 47k resistor between the clock
input of
 > the A-163 and GND solves the problem.
 > Best wishes
 > Dieter Doepfer"
AW: [Doepfer_a100] A111 with A163
2007-01-08 by hardware@doepfer.de
Alexandre,
I think the solution for this problem was discussed alread earlier in the
group. The reason for the malfunction are the AC coupling capacitors at the
A-111 outputs. They cause problems in combination with A-117 (noise clock
input) or A-163. The simplest solution is to short the capacitors C9 and C10
of A-111. They are located on the small socket board of the A-111. After
this modification the outputs of the A-111 are no longer AC coupled but this
causes normally no problems as the audio inputs of signal processing modules
(e.g. filters, VCAs) have these AC coupling capacitors available.
Another solutions is a pull down resistor (about 100k) at the input of
A-117/A-163.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von bellenger_a
> Gesendet: Samstag, 30. Dezember 2006 22:07
> Betreff: [Doepfer_a100] A111 with A163
> A196.
> Best,
> Alexandre
