Portable theremin in mini case?
2007-01-09 by travesty14850
So...the Doepfer web site depicts a little mini-theremin built into the new mini-case. But when you look closely at it, it doesn't contain an oscillator. I'd love to make something like this, but...can you actually fit a complete, independent working theremin into this case? There would have to be the two theremin controllers, an oscillator, and...an A-132? Would that work? Would it fit? I realize A-132 is not optimized for audio, but... An alternate question, then...it should be extremely easy to just buy a mini power supply and build one's own case, and then you could use a full-sized VCA. However, what if I wanted to...add a second oscillator? There are only four busses on the mini power supply...could a guy jerry-rig a splitter cable to power 5 modules off that tiny supply? Would there be enough mA available? Thanks!
