Doepfer
extra box
extra box
2007-01-11 by cray5656
i am thinking about making a separate 19" box with a joystick either
end, but not sure what else to put in there...i dont need vcos /a's
etc just controllers........any ideas?
Re: [Doepfer_a100] extra box
2007-01-11 by Florian Anwander
depends on the content of your purse ;-)
2 Joysticks (one autocentered, one without centering springs),
Theremins,
Light controlled CV
1 Comparator A-167 and 1 digital logic A-166 to control triggers
Slewlimiters
Ribboncontroller...
Florian
2007-01-11 by amnesia
is there a Doepfer Light Cintroller CV?
> Theremins,
> Light controlled CV
> Slewlimiters
> Ribboncontroller...
> Florian
2007-01-11 by James Husted
I have made the lower half of one of my portable cases into a
controller only section. I have a joystick (a AS unit bought before
Doepfer offered one) a custom panel with large pushbutton switches
providing manual gates, some LFOs and envelope generators and some
switch panels. Basically a good idea if you are heading towards a
live-type setup is to make a bunch of push button and toggle switch
panels and maybe some panels with large throw faders in them that can
be patched to anything. I suggested a mod/pitch bend wheel panel a
while back and the poll had positive results so maybe those will be
made and would be a great addition. That is one of the best things
about analogue synths - it is very easy to make controllers. I once
made a ribbon controller out of some 1/2" recording tape stretched
over a bare PCB. I once made a performance controller from some old
mercury switches taped into a ball. Surplus stores are your friends
here.  Old gear there will give you ideas.
If you want to see old electronic cases turned into the most
beautiful sound boxes ever - check out the stuff done at Folktek -
http://folktek.com/news.html - click on the links on the left side.
VERY cool stuff.
-James
James Husted
The ErsatZ Planet Graphics and Sound
http://homepage.mac.com/ersatzplanet/
james.husted@mac.com
"Welcome to the first day of the rest of your money..."
