Doepfer
Re: [Doepfer_a100] RE: [AH] wiring a doepfer system q's
2007-02-04 by Ross Goniakowski
i can infer some things from the info provided, but i don't see a clear <hot = x, neutral=y> for the 115v AC,  that's the main info i need...i assume from the scetches on the doepfer sire that the buss board is facing rightside up, and that the red line on the ribbon cables  are faced down...i think...
thanks,
rg
----- Original Message ----
To: Ross Goniakowski <carfull@sbcglobal.net>; analogue heaven <analogue@hyperreal.org>; Doepfer List <Doepfer_a100@yahoogroups.com>
Sent: Saturday, February 3, 2007 5:34:40 PM
Subject: [Doepfer_a100] RE: [AH] wiring a doepfer system q's
There are some diagrams here:
http://www.doepfer. de/a100_man/ a100m_e.htm
You may find other questions answered in the technical sections of the site.
--Chuck
> From: Ross Goniakowski [mailto:carfull@sbcglobal. net]
> Sent: Saturday, February 03, 2007 2:56 PM
> To: analogue heaven; Doepfer List
> Subject: [AH] wiring a doepfer system q's
> i'm putting together a doepfer expansion rack...i got most of it together,
> but i'm not 100% sure how to apply ac to the power supply (the psu2, the
> newer one)..i see how to hook the buss to the power supply...i'm mounting
> the power supply to steel rails and will run ground to the rack
> chassis/earth ground/ground the rails to the chassis...basically i just
> need to know which pins to put the hot and neutral ac to the doepfer pwoer
> supply, and i'll test the dc power out before plugging in and mods...also,
> i'm using an in-line fuse holder, i assume that goes on the ac hot?
> another thing: from the doepfer site, it's a bit unclear how to plug the
> mods into the buss..they all have the ribbon cable plugged in, where does
> the red wire go? thinking about it now i probably just have to look at the
> cb of the mod and match the singnal...
> i'm asking on AH/Doepfer List as Analogue Haven is closed until monday
> and i'm just plugging stuff in at this point, my self assembled rack case
> is ready to go...and i'll hold no one libel if i fuck up (haha)....please
> feel free to email me directly, i'm on the digest (AH)...
> thanks,
> rg
